Question about Onkyo DR90
Hii bought my Onkyo DR-90 with no remote. I have a problem where the dvd only played the trailer and up to the main menu. I was not able to proceed further even when I press the play button numerous time. i have download the manual from the internet and try to reset the parental setting (just in case if it is lock) but when I press the enter buttun on the unit the only display that come out was a selection to activate the subwoofer. No parental control selection appear either on the display window or the tv. i have also tried buying a universal remote and have a programming code in. Everything seems to work fine except the dvd. It is still stuck at main menu without being able to proceed to movie viewing. another problem is when I press set up on the unit there is no menu appearing on the tv screen for me to do my selection. I'm stuck and I really don't know what to do next. Need your help to solve the problem as it is a pity to throw the reciever away while everything works fine. Help... P
techman
  • 3130 Answers
SOURCE: Onkyo DR-C500 won't recognize discs
Onkyo units as well as several other manufacturers have a common problem where the spindle motor gets intermittant or wont come up to speed.Its not hard to replace this motor, but could be a trick to adjust the platter height. Also the unit probably needs a servo alighnment as well. This unit could also have a simple problem as a dirty laser lens. You can try to use a disc lens cleaner to see if that helps. Good Luck
Posted on Jun 24, 2006
  • 3422 Answers
SOURCE: Onkyo DV-CP702 will not load any disks!
HI,
Yes, it may be a mechanical misalignment. You may be able to find a way to readjust the tray, etc., but probably the focusing of the laser diode needs reset. For a dvd player this old, you are lucky to the extreme that it still works at all.
Any dvd player over two years of age that needs major repair should be replaced as the cost of repairs will be greater than the cost of a new set! Sad but true. You will not be able to get the focus adjustment done for less than $50!
So, my strong advice is to get a new dvd player.
FEW TROUBLESHOOTING STEPS YOU CAN TRY:
Does the player make squealing noises or is it totally quiet? Squealing noises may indicate that the player is trying to synchronize with the disc but can't due to an obstruction on the lens or in the laser path inside the pickup or a defect in the pickup. This can also be caused by an intermittent signal problem due to a faulty ribbon cable.
Totally silent means that the photo sensor is not getting any usable input from the laser at all, meaning that the pickup is "blind" for lack of a better word.
This can be caused by an obstruction of the beam by foreign matter on the lens or inside the pickup all the way to a marginal or failed laser diode and/or photosensor array. This can also be caused by a bad ribbon cable with one or more severed traces.
You could try to clean the optics. This is the most common malfunction as far as i know in all disc players. It would involve taking the cover off and finding a way to expose the lense, and then cleaning it with a very gentle brush. some players have a cover for the lense that swings to the side during playing, this greatly reduces the chance of dust accumulating, but its still worth the try.
If you actually see dust on the lense, then its just that simple. clean, close, play.
It may also be worth your while to check on the small shafting that guides the carriage of the laser pickup. Dirt, grome, dust and solidified lubricant can cause stoppage of the carriage and the laser eye then fails to read the next track. Please refer to the image below.
Goodluck,
Please don't forget to rate the solution.
Posted on Mar 29, 2008
ginko
  • 19396 Answers
SOURCE: Multi region code for DVD
You need to hack the dvd reinstalled firmware, I can see if I find hacked firmware for your dvd
Posted on May 01, 2008
  • 4234 Answers
SOURCE: Onkyo TX-SR575 I
The unit is in protect mode. The outputs are fried in all likelyhood. This can be repaired. Figure on $5-$15 for parts plus the local labor rate for the total repair cost.
Dan
Posted on May 21, 2008
SOURCE: Remote control via RI terminal on Onkyo Receiver
Not sure I can solve, but maybe help. I am having a similiar problem. However, make sure you Analog Audio (RCA type) cable are connected even if using Digital connection between the two. They use those cable to send the Commands (Mentioned in the documentation).
If you did get yours to work, please give me a hint... I upgraded mine from a 603 to a 701 and haven't been able to get it to work since.
Posted on Feb 14, 2009
Will only play DVDs in Black and White
Onkyo DV-CP706B 6-Disc DVD Player (Black) - Amazon.com
www.amazon.com/Onkyo...Player-Black/.../B001AMS...
Amazon.com, Inc.Color: BlackChange .... It's quieter than it was before, and it plays ALL DVDs, even if you can see some visible damage ..... THere was no color-just black & white.
Onkyo dvd player no color only black white Questions ...
www.fixya.com > Forum > Tags > dvd player no color only black white
Onkyo dvd player no color only black white related problems. Ask your Onkyo dvd player no color only black white questions. Get free help, advice & support ...
Onkyo dvd player plays black white Questions & Answer
Dec 29, 2015 | Onkyo Dr-s2.2 5.1 Dvd Home Theater...
Do I need a remote control to control the Philips magnavox model DVD 815AT. It plays the commercials on the video disc. When it comes to playing the movie, it keeps repeating itself and it won't go...
Usually most DVD's play movie trailers and sometimes advertisement before the movie will play. Once the ads or trailers are done it should go to the menu screen and at that point "play" or something like that should be underlined. If it is you can press play or select on the DVD player then the movie should start : )
Jul 27, 2011 | Philips DVD815AT DVD Player
I bought mu D-R2 DVR without original remote. Got one GE universal and just set it up and got to the main menu.And this was my 1-st time to get there.Checking settings, I changed from DR-1 to DR-3 and...
hello inira. DR-1 and DR-3 are two separate but similar toshiba model types.
Your machine must offer both in that one machine. Your best bet is to replace the remote with a new original remote control.
here is a link where you can purchase one
http://www.replacementremotes.com/
Joe
Apr 29, 2011 | Toshiba D-R2 DVD Recorder
How to get unit to play without remote
You can probably use the front panel buttons (STOP PLAY OPEN/CLOSE etc) manually, the only thing you cannot do without the remote is access certain DVD menus, including subtitles/language/special features etc. You can always obtain and use a universal remote for basic menu functions later on if necessary.
To play a DVD movie without the remote, simply load your preferred disc, wait for the player to finish reading its contents, then to skip copyright warnings and/or the 'play movie' menu screen, press STOP, then PLAY, or simply press PLAY button where 'play movie' (or whatever function) is highlighted in the menu. These buttons should be on the front of the main unit. Doing this should encourage the player to detect the appropriate title (the movie) and play it (basic playback operation may not be possible with some DVD releases due to the numerous interactive menus and title pages, such as film trailers).
If basic manual operation is not completely possible with some DVD titles, consider a universal remote for your player if you have either lost your original, or the player was purchased/received without one. Such remotes are relatively inexpensive to purchase, and are available just about everywhere.
Apr 22, 2011 | Panasonic Televison & Video
I have an Onkyo DR-S2.0 dvd Receiver that will not turn on. That aside I'm trying to find codes for the remote in order for it to learn my Philips tv and my Yamaha stereo receiver. The remote is a RC-437M....
Can't help you with the turning on problem, but the remote doesnt use codes to control other devices it learns the signals from that devices remote. heres a link to the users manual:
http://www.intl.onkyo.com/downloads/manuals/pdf/dr-s2.0_manual_e.pdf
the programing procedure is on page 63
May 21, 2010 | Onkyo RC-549M LCD Remote Control
DR 389 DVD player
Try one of these:
1) Press 'setup' on remote control
2) Move down to the 'lock' picture
3) Press '0000000'
4) Select region code as '0'
Or
1) Power on player with no disc in tray
2) Press PAUSE
3) Key in 314159
5) For multi-region, select 0
6) Press PAUSE again
7) Power off player
8) Wait a minute turn it on.
Apr 22, 2009 | Televison & Video
Need Remote Codes
The manual on Page 10 says that with these modes (DVD,CD,MD,CDR,HDD) on the Remote you can control an Onkyo DVD player and CD/MD/CDR/HDD player/recorder.
For DVD, on page 12, it says to just push the DVD button (top right) and the following buttons will functions as stated.
ON/STANDBY button
This button sets the DVD player to On or Standby.
Number buttons
These buttons are used to enter title, chapter, and
track numbers and to enter times for locating specific
points in time.
DISC +/– button
This button selects discs on a DVD changer.
TOP MENU button
This button is used to select a DVD’s top menu.
Arrow [UP]/[DOWN]/[LEFT]/[RIGHT] & ENTER buttons
These buttons are used to navigate DVD menus and
the DVD player’s onscreen setup menus.
RETURN button
This button is used to exit the DVD player’s
onscreen setup menu and to restart menu playback.
Playback buttons
From left to right: Pause, Play, Stop, Fast Reverse,
Fast Forward, Previous, and Next.
SUBTITLE button
This button is used to select subtitles.
AUDIO button
This button selects foreign language soundtracks
and audio formats (e.g., Dolby Digital or DTS).
DISPLAY button
This button is used to display information about the
current disc, title, chapter, or track on the DVD
player’s display, including the elapsed time, remaining
time, total time, and so on.
CLR button
This button is used to cancel functions and to clear
entered numbers.
MENU button
This button is used to display a DVD’s menu.
SETUP button
This button is used to access the DVD player’s
RANDOM button
This button is used with the random playback function.
REPEAT button
This button is used to set the repeat playback functions.
PLAY MODE button
This button is used to select play modes on a component
with selectable play modes.
Feb 05, 2009 | Onkyo TX-SR304 Receiver
ONKYO DR-90
Hello, I am sorry about your issue. I would think that the cost of the repair would be more than the value. There also could be an issue with parts availability. Thank you, Onkyo USA
Jun 21, 2017 | Onkyo DR90
Code for Sony BDP-S300 Blu-ray player on Onkyo remote
Player can be made to work without remote. But it is a pain.
You need to press pause then play in the right combination.and you can get both DVDs and Blu Ray disks to work. I bought a store floor model that did not have a remote. I went through the same problem when I would lose the remote for the HD-DVD player. My four year old daughter knows this trick pause pause play for DVDs and pause play pause play for blu
Feb 21, 2008 | Onkyo TX-SR605 Receiver
Onkyo DR-UN7 DVD Receiver remote control code
Nowdays there are CLONE type remotes available form electrical stores.
These clone type remotes carry all the codes necessary to work TV, Vdeos, CD players and other domestic sound systems.
I would suggest that you visit one of these stores and see what they have for your ONKYO system, the cost is not great and you will walk out with a complete remote for your system that will work all the other controls as well..
The stores have a fold out paper list, (thats very long) showing model and manufacturer detail for what codes you need to enter into the new remote to make it compatible wuith your ONKYO system.
Cheers From YUBEUT
Feb 11, 2008 | Audio Players & Recorders
Onkyo DR90 Logo
231 people viewed this question
Top Onkyo Televison & Video Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you an Onkyo Televison and Video Expert? Answer questions, earn points and help others
