Question about Nintendo DS Lite Console
The top screen of my DS Lite shows everything in negative colors.
The top screen of my DS Lite has inverted colors (Everything shows up in negative). It happened after the DS got wet because of a leaky water bottle (probably why), so how do I get it dry quickly? And is there any way to fix this? Thanks!
SOURCE: Nintendo DS Lite got water damaged
Heat the DS in an oven. REMOVE BATTERY as it may become heat damaged. The DS lite's max rated temperature is 50 degrees celcius or 122 degrees fahrenheit. So set the oven to 120-125. As oven thermostats are not known for accuracy put a reliable temperature sensor in with it. Something like a turkey temperature probe, just in case your oven is way off. Do not do this with a hairdryer as localised hot spots may reach a higher temperatures. Leave it in there for a while, its up to you, maybe 2 hours would be considered a good suggestion. If your feeling adventurous you could take it apart and put it in the oven in bits. It would obviously dry out much quicker. Providing the cicuits haven't corroded that should do the trick. Next step would be to disassemble the DS (tutorial video at http://www.maxconsole.net/?mode=news&newsid=11484) and clean the motherboard with alcohol and a cotton bud.
note: you need a tri-wing screwdriver to disassemble the DS. you can get them on Ebay for a few quid.
Posted on Jan 18, 2008
  • 35 Answers
SOURCE: DS LITE GOT WET
I dont think so. Srry, but u gotta get a new one :(
Posted on Dec 27, 2007
  • 64 Answers
SOURCE: how to open ds lite
There are two cross head screws under the rubber feet at the slot1 side, there are two tri-wing screws on the left (stylus side) and inside the battery cover (under the battery) there is a cross head screw at the top and a tri-wing screw at the bottom (in the corner).
The screen is held together by 4 screws under the ruber pads and then the outer case slides up about 5mm and then pulls clear.
Take great care when putting it all back together to line up the volume and power switches and plastics as the power switch breaks quite easily.
HTH
Posted on Mar 02, 2008
SOURCE: nintendo ds lite
open it up and clean out the ds
Posted on Apr 12, 2008
  • 103 Answers
SOURCE: Nintendo DS not reading games
Looks like a defective Slot1. DS Games are using different pin-connectors in Slot1. There is a possibility that one of more connector-pins for using DS games are not making contact
Posted on Sep 22, 2008
Dent in screen with black spot oin screen and
looks like u broke the colour crystals in ur ds screen. soz to say that dat cant b fixed.
Mar 05, 2010 | Nintendo DS Lite Console
Nintendo ds lite keeps shutting off
you probably have a power shortage when you move the screen. the only way to fix this is to open the ds, make sure everything is in the right place, and put it back together. i cant promise this will work, but it should.
Jan 13, 2010 | Nintendo DS Lite Console
Mixed up colors on Top Screen of DS Lite
Needs new top LCD fitting --- get it done at DS DOCTOR
Dec 15, 2009 | Nintendo DS Lite Console
My nintendo ds top screen's color is off. It is
Unfortunately this is coming to be known as the "Green Screen of Death"... It is likely one or more of the components that create the image on the screen are damaged. This usually occurs if there has been an impact -- such as being dropped or hit -- to the Nintendo DS's screens. Your Nintendo DS system will need to be repaired.
You can give Nintendo a call at 1-800-255-3700 or contact them via their website:
http://www.nintendo.com/consumer/webform.jsp
Hope this helps!
Nov 27, 2009 | Nintendo DS Lite Console
Pastel colors in upper screen
Take it to get checked and lower the back light.
Aug 06, 2009 | Nintendo DS Lite Console
My top screen keeps changing colors
something is wrong with connection with the bottom and the top screen. If you have ever dropped it that could happen. If all is bad try a new battery.
Jul 15, 2009 | Nintendo DS Lite Console
DS Lite Top screen is all white after replaced for new one
you should use a crystal casing because every time you open the ds the wires get messed up or put some thing on the hinge so the ds hinge will not get loose.
May 12, 2009 | Nintendo DS Lite
Ds lite R4 prob
Moonshell not installed properly.
Please follow that crummy manual or google a better instruction on the internet. Plenty there. Upgrade to latest firm.
You are only allowed to have homebrew on there by the way.
Apr 16, 2009 | Nintendo DS Lite Console
Nintendo DS lite; changed touch screen and it won't start
Hi. this issue is normaly caused by bad screen (normaly top screen) or bad assembly in one of two screens, re insert carefully the flex cable again, if your screens are fine this must fix the issue
Mar 14, 2009 | Nintendo DS Lite
DS lite screen
Hahahahaha that is how it works but if you go to the little DS at the bottom of the touch screen and tap it there will be a fixer manual use it and when you are done the system will shut off and just turn it on again and also the touch screen is the most important thing on your ds so keep it scratchless and clean! On some games the top screen is an important thing and somtimes it doesnt show anything
Mar 02, 2009 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
418 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
