Question about Dometic Rooftop RV Air Conditioner
Duo-Therm A/C can not find model number.
I have a Duo-Therm roof-top a/c unit and I can not find the model number. I found the tag on the outside, but it is sun faded and I can not read it. Is there another tag somewhere I can find it. I have the original installation instructions, but it list several models. It looks like a model 579xx.xxx from the pictures, but the rest of the model number is unknown. It could be 57912.005, 57912.006, 57915.005 or 57915.006. I need to replace the capacitors and they said I have to have the model number to cross reference the part numbers. Will the parts interchange? Is there anyone that can help me?
  • Keith Jul 16, 2013
    Did you get your answer? I have the EXACT same problem. I isolated my unit to the third one you listed based upon the one numer I could read (LRA 63). Just need a run capacitor and the specs on it.
    Genius:
  • Dometic Master
  • 1,363 Answers
Try to remove capacitor from mounting bracket might be able to read mfd on cap.
Posted on Aug 18, 2015
motor1258
  • 6674 Answers
SOURCE: dometic duo therm a/c for rv
If it's a dometic try ( http://www.dometic.com/enus/Americas/USA/RV-Products/climate/ac-display-page/?productdataid=66932 ) and if it's a coleman/RVP try ( http://www.rvcomfort.com/rvp/products/rooftop/LP_polarMach.php )
Posted on Aug 29, 2008
  • 10 Answers
SOURCE: I have a Duo Therm Roof top Camper air conditioner
how old is unit and does it have refrigerant in it
Posted on May 31, 2009
  • 27 Answers
SOURCE: ac blowing breaker
The unit will draw more current when hot. Check rating of the breaker against the rating recommended by the manufacturer.
Posted on Jun 16, 2009
carlsbiz
  • 1124 Answers
SOURCE: i have a duo therm brisk air model 57915-001 leak
Could be the drain path is clogged.. Take the cover off & see if you can get it cleaned..
Posted on Jul 09, 2009
  • 51 Answers
SOURCE: duo-therm mod # 57915 not cooling fan?????
need to get at the capacitor for the fan. Try spinning blower when it hums. If it runs then the cap is bad if not the motor.
Posted on Aug 14, 2009
I replaced the control module in the rear duo-therm 600 series roof top ducted unit. Now the thermostat does not see the rear unit.
Does the board have some type of personality module that needs to be transferred to the new board? Refresh the tstat to find new board.
May 15, 2017 | Heating & Cooling
Duo Therm 3109228.001
sounds like thermostat issue not communicating with relay modeule
Aug 01, 2014 | Dometic 3109228.001 Duo Therm Comfort...
Have A Duo-Therm air conditioner on top of my motorhome and it stoped cooling, the fan works fine. Is there a fuse in the box under the filter? It says there is on the out side. I am not sure where it...
Can you please reply with model number off bottom of upper (roof) unit. Should be able to see it when filter is removed from ceiling assy. Please include model of thermostat if possible. You say fan works, but when turned to cool, no compressor kicking in? Try shutting unit off, and turn off breaker at panel as well, give it a few minutes and retry and see if anything changes and let me know.
Aug 16, 2011 | Dometic Rooftop RV Air Conditioner
Installing rv roof airconditioner heat strip
I see what you see also in the manual. The difference is the Heat Strip package that part is optional and the 600212-001 with the optional heat strips becomes the new 600315-001 I talked to Dometic Duo-Therm and the models are the same but they both are not heat pumps but the new heat strip package comes on when told to go into heat mode when you change the thermostat to heat. The part you purchased will fit both model numbers you listed for your roof top air conditioner. Thanks, Sea Breeze
May 09, 2010 | Heating & Cooling
Can I put heat strip in my duo therm air condition unit I think it is ducked
Check your control box at ceiling assy., and see if you notice an extra plug in side or end, where the heat strip would connect first. If not, Write the model and serial number off the control box, as well as model number off the bottom of the upper unit (roof) which should be visible when ceiling assy, filter section is removed and call dometic customer service at 1-800-544-4881, and they will advise you as to proper control box required, and if anything else is required as well.
Apr 18, 2010 | Dometic Rooftop RV Air Conditioner
Duo Therm Penguin model 610115.311 AC unit no-power
Actually you should have fried you converter. What is the voltage reading you get for the air conitioner? supply? One should run off the generator and the other on shore powerIs it set up that way?.
Sep 28, 2009 | Heating & Cooling
No Power to Duo-Term Thermastat
Can you give me model #'s of thermostat & AC unit, as well as upper unit? Number of or at least a description of thermostat, and numbers for ceiling assy should be visible when filter taken off, as well as # for upper unit should be tagged on bottom of unit on roof.
Jul 17, 2009 | Heating & Cooling
Breaker turns off when air is turned on
The compressor has a short going to ground .when resetting breaker stand off to the side they can and do explode. you will need service. Tom
Jun 23, 2009 | Dometic Rooftop RV Air Conditioner
May 30, 2009 | Dometic Rooftop RV Air Conditioner
Location of Drain holes on Duo-Therm Model 630035.321
Good place to start is up on the roof. Look way under the unit (hard to see some times) along the bottom, between where the gasket sits on the roof and metal bottom of unit. Should see small round or similar sticking down from unit. There will be a hole in the side of them. Poke around with a wire or something to open them up. If you don't see water/condensation running across your roof from unit when it's operating, (usually in 2 directions, 1 each side of unit) then yup, there plugged.
Aug 05, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
429 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
