Question about Microsoft Xbox 360 Console
My monder 2 has ciercl lines arond the edg and now it is not working
    Scholar:
  • 93 Answers
I assume you mean modern 2, as in Modern Warfare 2. Using details will help us help you alot easier. Purchase some scratch out disk cleaner, or as I prefer, you can buy vehicle rubbing compound, buff the scratch out with a terri cotton cloth and, pretend like you are sanding it, which is what you are doing on a fine scale. Use a clean cloth to clear it off once you rubbed it in in smooth circles. It is recommended to wipe from the center out, but is way too time consuming. Now play the disk once you have it looking smooth.
Posted on Jul 17, 2010
Just got a Worx GT151 trimmer. For trimming grass has worked fine. Problem is in edging the sidewalk. I start edging and it takes littleraly 2 seconds to wear the string to half it's length, needing to...
Hi Dave.
When you are using a strimmer against stone or concrete you have to just barely allow the tip of the line to touch the ground. If too much of the line slaps off the concrete, any sharp edges or roughness on the concrete will tend to snap it. What you could try is heavier gauge strimmer line which might last longer. I used to use petrol strimmer line on my Black and Decker strimmer which was 350 watt rated. I'm not sure what effect it would have in the long term though and may wear the bearings due to the extra weight.
Jul 04, 2011 | Worx GT WG150 10 in. 18 Volt Cordless...
Passenger tail light tail light works but when i apply the brake it the tail light goes out, brake light won't light
remove the bulb from the scoket.you will see 2 or 3 little ground wire arond the socket ,take a piece of sand paper and sand them a little then bend them out just a frog hair and put it back together,,,,,,,,,,,,works on mine
Apr 04, 2011 | 2000 Jeep Grand Cherokee
I took my xbox apart and the dice will not spin
burnt up hard drive pull the model of the hard drive and can be purchased on-line for arond 38 dollars
Feb 20, 2011 | Microsoft Xbox 360 Console
Will not turn on says door
There are 3 door switches arond the door that can throw up this error but if the 2 fuses are blown also it will throw up this error. You can ohm out any of the fuses or even the door switches but until you repair them it wont work. I have even found both fuses to be blown. If you are nervous about pulling apart your stove make sure whoever does is very familiar with this line of Kitchenaid. Hopefully this helps.
Jan 30, 2010 | KitchenAid KBMC140H Convection Microwave...
Ice build up around the fan. the water freezes arond the drain hole.. i've melted the ice, cleaned out the drain hole and about 2 weeks later all frozen over.
Did you go through the drain line all the way to the condensate pan below the refrigerator? Sometimes if a refrigerator leans slightly the water will pool until it slowly closes the drain but most times the drain line has gunk in it and until that is removed the problem will come again. Sea Breeze
Dec 16, 2009 | GE Refrigerators
Mitsubishi 50 inch projection tv
you probably have a problem with the convergence board.
Nov 13, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Phone messed up
It is better for you to purchase a new mobile , most phones that have been wet most times even after service always give problems still......replacing parts will be to expensive.
May 12, 2008 | Samsung SCH-u540 Cellular Phone
I have a malicious code found in the c:\windows\system.32\mijgh.dll infection: packed. win32.monder.gen
Download AVG free edition and scan your PC - that should shift it. Also install Spybot and check your computer. Make sure you get the latest updates to these progs
http://free.grisoft.com/
http://www.spybot.info/en/index.html
Good luck
Apr 14, 2008 | Computers & Internet
Microsoft Xbox 360 Console Logo
26 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
