Question about HP Photosmart C4280 All-in-One InkJet Printer
How do I set up my printer defaults to print in draft format and in Black & white. My printer currently prints in Normal and in color.
  • 34 Answers
Select "print" from the "File" menu when the printer dialog box opens select "Properties" then "Printer Shortcuts" go to the "Print Quality" box and select "Fast Draft" now at the top of the window the last tab is "Color", go there and select "Print in Grayscale".
Posted on Jul 12, 2010
Even though my black cartridge is full, my black and white documents are so light they are unreadable. My color cartridges are close to being empty. Can this be the cause?
printers use all cartridges to get the correct colour even black
best get a new colour cartridge then realign the printer with a test pattern
Apr 05, 2015 | Office Equipment & Supplies
HP 722C has quit printing black in color draft
WORKAROUND: Select EconoFast or Draft as the print quality setting in the printer properties. This will prevent the color cartridge from being used. - Or - Try another color cartridge. The color cartridge is used to print grayscale images in Normal or Best print modes, so if one color has run out, the printout will have the wrong tint. With a full color cartridge, the colors can be properly combined to create a composite black. CAUSE: When printing with Normal or Best as the print quality setting, the HP Deskjet 710C or 720C or 722C series printer will use the color ink to improve print quality output, even when printing a grayscale image.
Sep 07, 2007 | HP DeskJet 722c InkJet Printer
Do I have to have a color cartridge in order to print? Can I just use a black ink cartridge?
The HP DeskJet 6122 can print with both or only one ink cartridge installed. The printer driver includes an option to print in gray scale as a substitution for color. If you choose to print a document that has a color other than black and white with only a black cartridge installed, I recommend you select the gray scale print option. To select gray scale, select the printer properties and check the box for gray scale rather than color printing. This selection can be made either at the time a document is ready to print (ie., a one time selection, using the "Properties" box in the print options window), OR as a permenant setting using the Control Panel, Printers, HP DeskJet 6122, "Properties" window. Once changed in the general printer properties, these settings remain active anytime the HP DeskJet 6122 printer is selected to print a document.
Sep 03, 2013 | HP DeskJet 6122 InkJet Printer
Lexmark 3600-4600 stops at 34% when trying to print a test page. Color ink is low, but I only want black in any event.
If your color ink is already empty or not substantial for printing, then you must replace it with a new cartridge. The Lexmark printer will continue to print when there's substantial ink in the cartridges.
If you prefer to print in black and white as your default print setting, please follow the steps below: (make sure your black and color cartridges ink levels are good)
For Windows OS:
1. Go to Control Panel.
2. Open Printers and Faxes.
3. Right-click on Lexmark 3600-4600 Series print object and click on Properties.
4. In the Lexmark 3600-4600 Series Properties window, go to Advanced tab. Click on Printing Defaults.
5. In the Lexmark 3600-4600 Series Printing Preferences window, under Ink Use, select Print using black ink only. Click OK.
6. Click OK button in the Lexmark 3600-4600 Series Properties window to save the changes.
Your printer will print in black and white draft mode the next time you send a print job to the printer.
For Mac OS:
1. With the file (you wish to print) open, go to Print. A window will pop up.
2. Select the Lexmark printer.
3. Expand the arrow pointing down beside printer name if you're not able to see other options for printing. Look for Quality and Media.
4. Under Paper tab, select Print in Black and White.
5. Save this as your default print setting. Click Presets option and choose Save as. You can personalize the name for this default print setting (e.g. Black and White Draft or My Setting).
Select this Preset name every time you print your files/documents.
Aug 31, 2011 | Lexmark X4690 Wireless InkJet Printer
How can I get my HP 6500a plus printer to PERMANENTLY default to black printing? I am needlessly using too much color and the default setting is only for a single document.
Hi
Go to right click at the printer icon on your computer and choose printer properties or printing preferences and from there choose the color setting to print in black alone. Regards
Jun 23, 2011 | HP Officejet 6500 Wireless All-in-One...
I have mp210 and want to change my printer to just black and white as I don't do much color printing but my cartridge run's out and I have to keep replacing my color cartridge as well?
1. In Windows: Go to Start>Devices and Printers>Right click on your default printer. Select printing preferences.
2. In the area that reads: Additional Features in the middle of the window, you'll see a selection that reads: Grayscale Printing Put a check in that box. This will print everything in black and white.
3. Go down to the bottom of that window and put a check on the box that reads: Always print with Current Settings.
4. Click Apply
5. Click OK.
Once you are just printing in black and white, the only cartridge you will have to replace is black ink-unless you change it back to color in the future-then you will have to replace the color cartridge as well when it is low.
Apr 17, 2011 | Canon PIXMA MP210 InkJet Printer
If the black ink runs out does the printer automatically use color ink to print black?
Hi. When you are printing in black but "black and white" is not selected in the printer "properties", the printer will use some of your colored ink to print grays. If the black ink goes out, it will give you an error and will not print using colored ink even if you are printing black only. Hope this helps.
Feb 03, 2011 | Canon PIXMA MP210 InkJet Printer
My printer will not print in black. It will use the other colors, but not black. When I try to print a black and white document, it prints in blue.
if u want to print selected document in black than open the document select print go to printer properties select grayscale printing
always print in black
go to printer properties than go to maintenance than go to ink cartridge setting select ink cartridge black only for balck and white printing only.
OR
CHANGE CARTRIDGE
Jun 18, 2010 | Brother MFC 240C All-In-One InkJet Printer
Canon mx310 how to print color document in black
When you go to save it or just before that you select file then go to print properties under that there should be a selection to print it in black and white.
Let us know ether way but its done under printer properties.
Thanks and please do be considerate that we are trying to help when you leave your positive ratings and feedback, thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 26, 2010 | Canon PIXMA MX310 All-In-One Printer
I have it set to print in black only but it uses up the color ink anyway. What gives?
On the printer driver, (after click "print" and the menu for selecting the printer appears and you can select the number of copies etc...go to"properties") . Here go to the "Color" tab.. if you truly only want to use black ink, then select "Print in greyscale" and select "Black only". After that just Click "OK" at the bottom and "Ok" to print your job in truly just black ink. :)
Cheers, Ed
Nov 22, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C4280 All-in-One InkJet Printer Logo
99 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
