Front load washer
Our GE front load washer wont function past one slight spin each way then do nothing for the rest of the cycle. There is water that wont drain and the machine want spin.
  • 1 more comment
  • dankutch Apr 20, 2008
    I couldnt figure out how to check the pump turbine.
  • dankutch Apr 21, 2008
    I took the pump out, cleaned it as suggested along with the filter and drain hoses and YAHOO it works again!!
  • Anonymous Mar 24, 2014
    lg front load with a 0e code
    Champion:
  • 207 Answers
  1. Turn off machine and unplug it.
  2. Open filter it and clean it.
  3. Check if in pump turbine is clogged or jammed with foreign object. On some pumps you can test if turbine it rotates free using screwdriver or a finger.
  4. Check if the drain outlet pipe is clogged.
Unless pump motor is dead I'm 99% sure that either filter, pump and/or drain pipe are clogged.
Posted on Apr 20, 2008
My ge front load washer fills then stops during cycle and does nothing else. It spins in the beginning then will not drain at the end
It sounds like the drain pump itself is damaged--the important clue was the humming noise. It could be bound up mechanically or the impeller could be damaged and just vibrating instead of spinning. The part number for the drain pump is WH23X10026. The fact that the pump was humming tells me that the 120v supply is being turned on by the main control board and that the wiring is good all the way to the pump. When I service customers, I try to save the pump if possible in clog cases. Most of the time, they aren't damaged from a simple clog. But, occasionally, the impeller cracks, or the nylon blade gets loose on the shaft, or the motor windings have defects from heat, etc.
Jul 23, 2015 | GE Energy Star WCVH6260F Front Load Washer
Washer wont drain. fills with water. goes through wash cycle but wont drain. once it gets to the spin cycle, it spins for a few seconds and then stops and rinse light comes back on.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 21, 2011 | GE Washing Machines
Hello: I have a tenant who is having problems with a GE Spacemaker washer/dryer -Stylemaster # is 622866-A. Here is how she describes the problem: ...it seems as though the washer isn't functioning...
If a spin and drain problem you can pull the front off to see if perhaps a small item (ie. sock or like size item) is stuck between basket and tub or in the drain hose? If it is a wash time problem that would be another direction.
Oct 06, 2010 | GE Spacemaker Washer and Dryer Electric...
Why won't my washer won't spin or drain
If the water is not removed first, the spin will not occur. Do you hear the pump run when it starts the spin cycle? If nothing, the pump may be jammed with debris, or the motor itself may have failed. If the motor runs, but no water comes out of the drain, then look for a kinked drain hose (inside the cabinet) or possibly a stray sock lodged in the drain outlet under the outer tub. Sometimes the pump impeller will come loose from the motor shaft causing loss of pump action. Hope that some of this helps!
Apr 06, 2010 | Tecnik TKL9260 Front Load Washer
My washer wont go into the spin cycle
has the water drained if not check pump/filter
Mar 02, 2010 | GE WCVH6260F Front Load Washer
Ge front load washer won't go into rinse cycle.
Check the cold water hose. My brand new machine had this behavior until I discovered a kink in the cold water hose - works great now.
Jun 03, 2009 | GE WSXH208A Front Load Washer
GE front loading washer not draining water
Something must have gotten into the drain pump. You drop the fromt panel on most of theses and open the pump sump, get the coin or whatever out of it.
Mar 11, 2009 | GE Energy Star WCVH6260F Front Load Washer
GE WBSR3140D
I have the same problem. The water drains, but I have no spin leaving the clothes soaked. I get a humming sound and thats it. The rest of the washer works fine. Any help would be great.
Jan 13, 2008 | GE WBSR3140D Top Load Washer
Washing Machines Logo
223 people viewed this question
Top Washing Machines Experts
