Question about Dometic Refrigerators
Dometic RM 2310. freezer is frozen ,but lower portion doesn't cool below 47 degrees F. on either electric or gas.
  • 9 Answers
SOURCE: Fridge does not cool below 40 degrees
This is a common problem and a design fault...
Posted on Sep 06, 2008
  • 51 Answers
SOURCE: Dometic RM 2804, freezer is
Adjust your temp control on the fins inside the fridge move it down it just slides on the fin. You may need a fan on the back of the coil to increase the air flow depending on the heat outside
Posted on Sep 08, 2008
  • 51 Answers
SOURCE: norcold rv refrigerator freezer
Make sure the thermister is attached firmly to the fins in the back. The boards on a Norcold can be reset a service center familiar with this process is your best bet. It takes disconecting the board and then shorting it out best to leave it to some one who is familiar.
  • 68 Answers
SOURCE: Dometic rm 2612. Shuts down on gas.
Ron;
Check the burner assembly. 1 screw, remove the sheet metal cover and clean it. The burner collects rust. This is the likely. Other issues would be the gas pressure usually checked with a manometer. Should 11" of water column. If your furnace works good then the gas pressure is probably ok. Also could have a faulty ignitor which sends a miliamp signal back to the circuit board. Check the burner first, after that leave the cover off and turn the fridge on. Watch the ingnitor attempt to lite the burner. Be sure the spark is going to the burner and not shorting out on the sheet metal it is mounted in. If it is shorting to the frame the ignitor needs replacing.
Thanks for using Fixya
Jerry
Posted on Mar 31, 2009
  • 10865 Answers
SOURCE: I have a Dometic RM 2652, the freezer works fine.
Here is the trouble shooting manual for your Dometic.
http://www.gasrefrigeration.net/dom_techdata/26121_2852SM.PDF
It will tell you what the possible problem is.
Posted on Jun 04, 2009
I have a dometic rm 2401 and it won't work on
yes, pretty common issue with that model
May 10, 2012 | Refrigerators
Help! In 2006 I purchased a used RV with a dometic model 2408 refrigerator that did not work. After reading up on Absorption refrigerators and repair facilities I had it rebuilt by RV Mobile in Everett,...
The evaporator coil is usually located in the freezer compartment, and there are ducts with dampers that send cool air to the refrigerator. It sounds to me like that may be your problem. It seems that if you move the appliance around a little, (cleaning it and the like), then for a short period you start to get a semblance of cooling. Hope this helps
Sep 10, 2009 | Refrigerators
Dometic rm 2310 on gaz only the freezer work but not down
we put the camper on level tank you we resolve the problem
Aug 20, 2009 | Dometic Refrigerators
Norcold rv refrigerator freezer
Aug 16, 2008 | Dometic NDR 1292 Refrigerator
AC,DC, gas RV fridge Dometic
You more than likely need to replace the control cable between the upper and lower board. It comes as a kit with the upper board. You can also do a bypass test by unplugging your thermoster from the circuit board. The thermoster is the temperature control for the refrigerator nothing to do with the freezer.
rvtech@myway.com
www.coachtech.info
734 777 6432
Jul 26, 2008 | Dometic NDR 1292 Refrigerator
Silhouette by Dometic RV fridge
Tuna, it sounds like your thermistor is bad. Once the fridge reaches 40 degrees, the thermistor is supposed to tell the board to stop cooling and maintain. You can test it with an Ohmmeter.
May 07, 2008 | Dometic RGE400 Top Freezer Refrigerator
Refrigerators Logo
191 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
4stevetaylor
Level 1 Expert
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
