Question about Weber Performer Grill
Can not light gas grill - Weber 8006 Have done all suggested thing such as full tank of gas, regulator checked, check for spider webs. No gas seems to be reaching burners.
Assuming that you have fuel and spark, check the following.
Mine did this, it was spiders, web and egg debris in the air inlet tube. It does not take much dirt to kill the ignition process.
If you have the perforated and hinged black plastic air inlet covers open them up and clean out the dirt. Reinstall the covers when done.
Posted on May 02, 2011
This grill is definitely worth fixing. I have had similar problems with several weber 8006 grills. It is usually something obstructing or diluting the flow of fuel. If you have a new tank and your igniter is working (you have tried using a propane hand-held lighter, I assume) then it seems that it must be either the hose/gas line or the burner tubes. I would first check the main tubes and cross tube carefully for places that are rusted through. Holes can lower the pressure in the tubes and make them difficult to light (try just turning on and lighting the front burner). I would then clean the tubes at the spider trap/air vent end, which is nearest the propane tank. The spider traps, if you have them, are little plastic cages and the edges snap together. You can use a vacuum to gently clean out the tubes. If this does not work, you can buy or borrow a similar, but working hose. As they say, "it is always the last thing you try that fixes the problem".
Posted on Sep 20, 2010
We can't light the burners and there seems to be no gas or very little going through the regulator. The propane tank is full. Do I need a new regulator?
That effect is sometimes caused by foreign material (often spiders) in the valve of the tank. If there was a recent tank change, this could be the culprit. Open connection and blow out with puff of air. Also, the tank can be a suspect as the valves do sometimes fail. Lastly, it could certainly be the regulator, but they are pretty hearty as a rule.
Aug 23, 2010 | Weber Genesis Silver B Grill
Poor flame, low heat
You probably have regulator problems.
Apr 14, 2010 | Weber Baby Q Grill
Doesn't seem to be enough gas going into the
Hi am welcome to FixYa. I am Kelly.
1. Does the LPG tank have gas in it?
2. Is it one gas control or more that gives you this symptom? If it is more than one and there is gas in the LPG tank then the LPG regulator can be the problem.
3. There can be debris on the face of the gas orifice where the burner mates to to the gas control selector assy. (Spider webs / grease /dirt)
4. The air hole in the burner can be partially blocked with something (same as above Grease, dirt, cob webs)
5. The holes in the burner itself can be corroded or blocked with something. (This one would be pretty obvious)
6. The gas valve 'heat control may not be functioning properly.
7. There is a very remote possibility that the LPG hose has collapsed.
I would check the orifice and the burner holes for obstructions after verifying the LPG tank is usable. Then the next suspect would be the LPG regulator.
Thanks for using FixYa,
Kelly
Apr 07, 2010 | Weber Genesis Silver C Grill
Burners won't fully heat
Check your venturi tubes(the ones that feed the burners) for spider webs.
Eric
Oct 12, 2009 | Weber Genesis E-310 Gas Grill
My Weber Genesis is 11 years old
Before you go replacing things check them out. If the burner is in poor shape (holes that are rusted out) it needs replaced. You also need to replace the ventura tubes or at least clean them out. One little spider web will cause a lot of problems on a grill burner. You also need to check and see if your regulator is working at the proper pressure
Aug 05, 2009 | Weber Genesis E-310 Gas Grill
Grill will not light, i have gas in tank but can not hear gas
If your bottle is full , could be the regulator or spiders have webbed up the lines , check theses potential problems. Hopefully this helps you out.
Jul 26, 2009 | Weber Genesis Gold B Grill
Low/weak flame on Weber Genesis Silver B Grill.
hi my name is mark, could be one of two things the regulator on the propane tank try gently tapping on regulator it could be sticking, and make sure the vent on regulator does not have a spiders web . or the orifices to the burners are restricted. check regulator some are ajustable, some are not. hope that helps. thanks for your question.
Mar 14, 2009 | Weber Genesis Silver B Grill
Weber Performer Grill Logo
1,073 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Marvin
Marvin
Are you a Weber Grilling Expert? Answer questions, earn points and help others
