I keep getting an FP error on my front loading Whirlpool washing machine
  • 1 more comment
  • cronangel Apr 20, 2008
    My washing machine is a Whirlpool 6th sense. I have cleaned the filter part and checked the hoses and it is still not spinning and showing an FP error
  • cronangel Apr 25, 2008
    I have still not received another Reply and I am on day 6 without a washing machine that is working properly. I will have to get a reapir man next week to fix it as I have a 3 yo and a washing machine is a priority item.
    Your claim is that if you don't fix it I won't get charged. I have been charged and it is not fixed.
    Thanks Tanya
  • cronangel Apr 26, 2008
    Ismail
    I replied on the 20th and did not get another reply until you replied today.
    I do not think that my reply was late when the discussion started on the 20th with my problem. I received my first answer on the 20th which was great, but did not work. I replied to that effect on the 20th advising my model of washing machine and the fact that the first fix did not work. I received no reply until my new response today.
    Tanya
    Master:
    Sergeant:
  • 462 Answers
Whats the model no of your washing machine..?
Posted on Apr 20, 2008
  • 1 more comment
  • Mohamed Ismail
    Mohamed Ismail Apr 20, 2008
    Yes error code "FP" has to do with blocked outlet in some way or faulty pump.
    In my case i could not find any blocking in the filter so i remowed the front cover for the maskine AWM 8123 (3 screws behind the lower front plastic cover).
    Now i easily cold remove the pump to check the inlet and output hoses. But nothing was found.. then i interested me for the pump that is selling as a replace unit.
    When i took it apart.. the white plastic from the black i realize that when i pull the impeller in the enginepump part.. there is an area inside with washwater to... that is cooling the pump.. that hidden area in the engine part was full of sand and other debreze that caused malfunction to the pump.
    Cleaning.. some oil in the bottom... put all stuff together again and voaila... works perfect.....!!!!
  • Mohamed Ismail
    Mohamed Ismail Apr 26, 2008
    Sorry dont be dissapointed, well ur reply was quite late...!!!
    We will do our best
    Thankyou
    Ismail
    mohdismail_2@hotmail.com
  • Mohamed Ismail
    Well fine... I think since the solution i gave was our atmost best solution but still it didnt turn out well, this looks like there could be some damage in the mechanical parts of the motor in the washing machine, for which it will be difficult for u to handle it from ur side. So, i therefore request you to call a washing machine technician to take it for repair.
    All the Best..
    Thankyou
My washer keeps stopping 20 minutes b4 the end & displays fp & wont drain
one side of your timer circuit is out! replace timer circuit panel
Jan 13, 2010 | Whirlpool AWM8123 Front Load Washer
My whirlpool washing machine won't spin. In the digital display it is saying FP
Hi
Remove pump and check the pump for any foreign objects which is stopping the impellor from turning.
hope this will help.
Thanks for contacting fixya.com
Oct 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
When machine get to rinse cycle it stops and the letters FP appear.
FP means "faulty pump" but before buying a pump make sure to check your drain hoses first since any blockage may cause the same readout in display:
Opene the flap on the front lower right side and unscrew the cap. If it doesn't come out easily a bit of force will get it out - look for hair klips and fluff blocking the pump inlet/outlet hoses.
GOOD LUCK!
Aug 30, 2009 | Whirlpool AWM8143 Front Load Washer
My washer gets so far then says fp
fp indicates a pump failiure so either clean the pump filter, or if the pump filter is clear then you will need to replace the pump as this is indication of a knackerd pump
Jan 24, 2009 | Whirlpool AWM5125/1 Front Load Washer
FP code appearing on lcd disply
remove pump and check pump for foreign objects stopping impellor turning, worked for me hope this helps
Dec 26, 2008 | Whirlpool AWM8143 Front Load Washer
Fp fault
i have the same fault on the whirlpool AWM8163/3 it indicates a drainage problem so check the filter and pump housing and all the pipes for blockage, even the drain pipe, i have done all that but the problem still exists, I'm gunna have another crack at it now and i'll let you know how i get on
Jul 29, 2008 | Whirlpool AWM8103/1 Front Load Washer
Washing machine not spinning
have you checked the button trap, located at bottom front left. open flap unscrew betton trap lid and check pump impelor for blockages. put some towels on floor first as water will come out
Feb 17, 2008 | Whirlpool AWM6100 Front Load Washer
Help with whirlpool awm 8103/1
You probably need a new heater element
Nov 25, 2007 | Whirlpool AWM6120 Front Load Washer
Washing Machines Logo
476 people viewed this question
Top Washing Machines Experts
