Question about Garden
RAIN BIRD SPRINKLER HEADS WILL NOT ROTATE HOW DO I FIX THEM 1 ONLY ROTATES IN ONE DIRECTION BUT WILL NOT RETURN
5 Suggested Answers
SOURCE: adjusting toro Super 600 PC-2.5 sprinkler heads
Try this. Should work.
www.mickman.com/irrigation/tips/toro600.html
Posted on Jun 25, 2009
  • 990 Answers
SOURCE: sprinkler head does not spray water
Make sure when you pull the head to ck the screen you turn the system on and blow out the line, then run a hose through the head to make sure it isn't plugged up anyway. Depending on the head and the cost of a new one will dictate cleaning or replacement.
Posted on Oct 04, 2009
aquaman987
  • 927 Answers
SOURCE: Rain Bird sprinkler timer blowing fuses
Disconnect all zone wires and see if timer blows fuses. If not, one of the zone valves is drawing too much amperage.
Posted on Nov 27, 2010
SOURCE: Nelson Sprinkler Rain Train Traveling
If it's going backwards, and assuming you didn't take it apart and put it together wrong, then the arms aren't going in the right direction. Looking down from the top, my unit should be moving clockwise if it's set up correctly. In any case, switch it so the water pushes the arms in the other direction. the transmission is pretty straightforward - if it's going in the wrong direction then the arms are spinning in the wrong direction.
Posted on Sep 16, 2011
Rainbird sprinkler manuals
The top of the head has a diagram that shows the pattern and the amount of water flow.
Sep 07, 2014 | Rainbird Rain Bird 5000S-PLPC-NP Part Cir....
Pop up rain bird gets stuck in one position, won't rotate correctly
it is dirty take apart and clean it or buy new sprinkler pretty cheap 10.00 jest buy new one install it
Aug 22, 2014 | Garden
No i don't just trying to help a elderly lady
It's not the sprinkler. The valve is not seating completely. You will notice the sprinkler it is leaking from is the lowest one in that particular zone. Don't take it out on the sprinkler it's not his fault. Think of it as if you didn't shut a hose bib off completely the leak doesn't drip at the bib it shows up at the end of the garden hose. Same principal. The valve is the hose bib.
Apr 17, 2013 | Rainbird Rain Bird 1806nsi Pop Up No Side...
My rain bird 1800 head keeps leaking how to fix it
if this is an older sprinkler ,it may just be worn.usually the leak is around the white plastic surrounding the popup shaft.in this event the cap needs to be replaced.
How to fix the problem on Rainbird sprinkler timer
There is no such thing as a impact rotor. It's one or the other. If it's a impact replace it with a rotor.
May 22, 2012 | Rainbird Rain Bird Ag5 Popup Impact Rotor...
Oct 02, 2010 | Rain Bird 4 Station Single Program...
I have low water pressure on my rainbird sprinkler system. how can i adjust it?
There are several ways to adjust water pressure on sprinkler systems. First you have to determine if there is a problem with the sprinkler system itself. Things to look for:
1.) make sure that all valves including the main are all the way open.
2.) Inspect the sprinkler heads for clogging. Sediment and debris can also clog your sprinkler heads. Some debris removal may be required.
3.) You make have too many sprinklers operating by one valve. You may need to divide a zone and add another valve to increase water pressure.
4.) If all else fails. You can install a breather intake cap to allow air into your sprinkler system thus increasing GPM (gallon per minute)flow.
5.) one of the biggest mistakes that peopel make is that they undersize the water pipe size to save money. Typically you want to use 3/4" PVC pipe for your main runs and tee into 1/2" PVC for your sprinkler heads.
Good luck. I hope this helps.
Jul 20, 2010 | Rain Bird Hardware & Accessories
Garden Logo
93 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
