Question about Mastercool 67680 Evaporative Cooler Air Conditioner
We have a mastercool swamp cooler model #mc63c and the low speed has never worked only the high speed. We're trying to determine if we need a different motor or a new control box.thanks randy
boysor2933
  • 293 Answers
SOURCE: Frequent short cycles of the Mastercool swamp cooler
Try to replace the thermostat. Short cycling of motor only happens when the thermostat is set to a very high temperature.
Posted on May 27, 2009
co7196
  • 3433 Answers
SOURCE: Remove the front and rear panels off of a MasterCool P12
Lift yhe panel and pull out at bottom. The ones that come out usually have hand slots
Posted on Jun 09, 2009
  • 4 Answers
SOURCE: I have a Mastercool 2 speed 1Hp 220 volt cooler
Go manual turn switch, sounds like an overload problem. I have a Mastercool unit and going on 12 years with same motor.
Posted on May 10, 2010
  • 588 Answers
SOURCE: high speed does not work but low speed does
If your motor only works on low speed and not on high speed first check to see if you have the proper voltage to high speed. Check with a voltmeter or multimeter, check from common on the motor to high speed on the motor at the switch. If you have the proper voltage then you have an open winding on high speed and the motor needs replaced. If you don’t have the proper voltage or any volts, then the switch is bad and needs replaced. This also will be the same if, medium speed won’t work and low speed does.
Posted on May 30, 2010
Testimonial: "great answer - I'll check it today"
SOURCE: I have a Mastercool Evaporative cooler and had the
Several of us add scented fabric softener at start-up each year, and later add a bar of ivory soap. I also have an in-line 'scale eliminator' and an anode inside , as well as a purge pump, which changes out all the water every 8-12 hours. These things combine to keep fresh water in the cooler, and suspend minerals. With clean pads, that should keep foul smells away.
Posted on Jul 04, 2010
Swamp coolers
Does it come back on automatically and how long does it take?
May 16, 2014 | Mastercool 67680 Evaporative Cooler Air...
We have an older swamp cooler and need to have some windows in our home open to get best cooling. Does a mastercool need to have some windows open in our home to give max cooling?
The solution is to install "up ducts" These devices are easy to install and are fairly cheap. With a swamp cooler the best way to use them is to allow them to draft outside with the "up duct" you get the drafting to the outside but also get to remove attic heat too.
Apr 24, 2011 | Mastercool 67680 Evaporative Cooler Air...
Need to find blower motor for mastercool swamp cooler mod. # mmb12b
easiest way would be to take the motor to a local Electric Motor repair or replacement shop. All mediaum to large cities have them...
Aug 20, 2010 | AdobeAir Mobile Swamp Evaporative Air...
High speed does not work but low speed does. Is there an easy fix, or will this require a motor replacement to get both speeds working again? The cooler is a Mastercool model MC64C
May 29, 2010 | Mastercool 67680 Evaporative Cooler Air...
My Mastercool Trio System has experience a failure od the compressor fan. ACExperts, the installer and only dealer in El Paso has gone out business.
is this not a Evaporative cooler if so there is no compressor the only two motors one for the Fan and a Sump pump. and most you spend 200 for fan motor. this is swamp cooler!
Jul 04, 2009 | Mastercool 67471 Evaporative Cooler Air...
Jun 09, 2009 | AdobeAir Mobile Swamp Evaporative Air...
No low speed on my mobile master cooler module no mmb12c
Could be as simple as the switch, could be as complex as a pole burned out on the motor. If you reverse the connections on the speed selector switch and you end up with low speed and no high speed then you know it's just an inexpensive switch.
May 30, 2009 | Cfm 2000 Swamp Air Cooler MMB10 MasterCool...
Short cycling can also occur in a thermally protected motor if it is overheating. If the other solution did not work, make sure the belt on the motor is not too tight or too loose. A handy person can check the amperage with an amp probe to make sure it is in limits. The adjust the pulley to put it into specs.
May 27, 2009 | Mastercool 67680 Evaporative Cooler Air...
Replacing pads
How do I replace a rigid pad on my Mastercool swamp cooler?
May 22, 2008 | Mastercool 67680 Evaporative Cooler Air...
Mastercool 67680 Evaporative Cooler Air Conditioner Logo
256 people viewed this question
Top Mastercool Heating & Cooling Experts
Bill Long
acrman404a
Level 1 Expert
Steve F
Are you a Mastercool Heating and Cooling Expert? Answer questions, earn points and help others
