Question about D-Link DIR-615 Router
It won't connect with laptop
When i was on line it dropped the connection.
    Problem Solver:
  • 7 Answers
Here are a few simple things to check:
If your PC is connected via wireless:
- Make sure you didn't go out of signal range
If your PC is connected via wired cable:
- Make sure the cable is secured into your router
If both check out:
- Check the cable between your router and internet modem.
If all connections are solid:
- Try using a different cable from the PC to the router, and from the router to your internet modem. Cables can go bad, and a new one could be an easy fix.
If all else fails, you may have experienced an intermitted connection issue:
- Try unplugging your internet modem and router for 30 seconds, then plug in your internet modem first and after 60 seconds plug in your router.
- Try restarting your PC
If none of those work, contact your Internet Service Provider.
Posted on Jul 12, 2010
I dropped my laptop and wherever the screen was white, there are now thin vertical blue lines
Rarely does anything good from a dropped laptop. Does it have the same issue if connected to a External Monitor? You can disassemble the laptop and search for loose connections on the motherboard/graphics adapter, screen, etc. That would be a start.
Feb 24, 2013 | HP Pavilion Computers & Internet
Computer won't stay connected to internet
This may be due to:
1.line drop. check your provider and splitter
2.may be your router is getting heated up. make an arrangement to get some cool air while working
3. mis configuration in router setting. goto 192.168.1.1 in your browser, type admin as username and password. press enter and check the settings one by one.
This all will solve the problem
Nov 28, 2012 | Computers & Internet
Laptop battery plugged in but not charging
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then -The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty.Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced.If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard.This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Jun 03, 2012 | Computers & Internet
Battery problem
Apr 10, 2012 | Panasonic Toughbook CF-27 Notebook
Medion E1210 notebook. Battery has suddenly stopped charging. Didn't get a fall. Laptop works fine when power supply connected, but if plugged out laptop shuts down immediately. When power plugged in...
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jun 21, 2011 | Computers & Internet
Will not connect to cable after powered on. Once power on it turns on and connects briefly but then looses connection to lan?
reset to factory default, flash firmware and test again.
Also take a Cross over CAT5 and a laptop, the laptop should (of cause) be on the same subnet for this test.
Then try to ping it... (command line of your laptop) ping IP-Address -t
see if the ping drops, should it drop the nic has issues and an RMA should be needed.
Thanks
Nov 24, 2010 | Avocent DSR1021 (DSR1021AM) 8-port KVM...
Lenovo thinkpad keeps dropping internet
Try restarting your router/modem
Also scan your system for viruses and malware as these can sometimes be a common source of these kinds of problems
May 20, 2010 | Lenovo ThinkPad SL400 Notebook
DSL connection keeps dropping off. Going to RED
well!! I have an answer for you.your comp is loosing the IP address.do this when you can go online. goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center,click on view status,goto propertiesand double click on internet protocol(tcp/ip) or IPv4.type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. ypur connection won`t drop after this.
Jul 10, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
Intel Proset wireless just drops connection
well!! I have an answer for you.your comp is loosing the IP address. goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center,click on view status,goto propertiesand double click on internet protocol(tcp/ip) or IPv4.type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
Jul 02, 2009 | Intel 3945ABG (WM3945AGM1WB) 802.11a/g/b...
Screen only showing vertical lines after being dropped
The damage could be either in the LCD screen or the connection cable. Open the screen assembly and check the connection cable first.
In case it doesn't work you can find replacement LCD screens here.
www.piezas.biz
Jul 02, 2008 | Toshiba Satellite M55-S135 Notebook
Open Questions:
cannnot connect to dlink. any ideas? OK, so here is the deal: about 6 months ago I purchased a brand new laptop and connected it to my DLink router that has been working on our PC for about 3 years now. I also have 2 Playstations and 2 other laptops connected to the D Link (all of which are working fine and NEVER have any problems whatsoever). About 3 weeks ago, I turned my laptop on and tried going online, but much to my surprise, it couldnt connect. Its supposed to automatically connect, but this time it didnt. I figured I would manually connect it. I opened up the window that displays all the routers that the laptop is picking up and i saw my D Link so I try to connect. It attempts, then says "connected" and the after 3 seconds or so, it says "Limited Access". I thought it was a problem with the internet so I checked the other laptops in the house and the Playstation and they are all working fine. I figured it was my laptop so I shut it off and restarted it but it did not work. Next, I tried unplugging the router and waited for 2 minutes or so and plugged it back in. Yay! It worked! I solved the problem! I began surfing the internet for a couple hours when, BAM! It suddenly went out again. I figured I would unplug the router once again to see if it was just some kind of glitch and would work fine this time. I unplug it and repeat the process over again. after 2 hours, it goes out. Everything else in this house seems to be working just fine on the router with no problems whatsoever, except mine. I have not messed with any of the configurations because I have not idea where to even begin so I know it cant be with the configurations. My laptop is new with windows 7, I'm using xfinity as a provider. Side note- I did a test and when I cant connect to the internet with my laptop it fails a "PING" test (no idea what that is), but when I unplug and plug up the router and the internet is fine on the laptop, it will pass the "PING" test. I'm completely clueless about all this, I really hope someone can help. If you have any questions, any at all that might help you diagnose the problem, please ask and I'll try to answer as quickly as possible, I really need this problem fixed. Its horrible having to reset the router every 2 to 4 hours. Recap: New laptop with windows 7, all other laptops and PS3's work just fine even when MY laptop isnt, fails "PING" test when it cant connect to internet, passes "PING" test when it can connect to internet, unplugging the router and plugging it back in will give me internet for a few hours, when laptop cant connect it says "LIMITED ACCESS". any ideas? Thanks to all who help. P.S. Like I have mentioned before, I'm a complete newb and dont really understand too much of the lingo, please break it down barney style for me. Thanks again.
Feb 26, 2017 | D-Link DIR-615 Router
D-Link DIR-615 Router Logo
77 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
