Question about HP LaserJet 4600 Printer
How do I install my HP 4600 Printer toner cartridge? Which tab do I pull?
    Problem Solver:
  • 7 Answers
There should be a tab on the end of the cartridge that you pull. As you pull it you will pull a long plastic strip out of the cartridge. This releases the toner so you can use the cartridge.
The printing or handle of some sort will be readable when you install the cartridge. If you look at the side that goes into the printer, you will see some contacts or a small circuit board that will make contact when you slide the cartridge into the printer.
It will go into the printer the same way you will be taking out the old cartridge.
Posted on Jul 14, 2010
4600 hp printer red stripe
Defective Magenta Toner Cartridge...replace it
Feb 23, 2014 | HP LaserJet 4600 Printer
Hp 9500 Toner Powder
Depends up on the properties HP designed the TONER.. You can't refill the cartridge with another normal toner with this one, pl submit the cartridge to best re-filler or pour specified compatible toner needed to re-fill
Jan 30, 2012 | HP LaserJet 9500mfp Printer
How do I insert a new toner cartridge to my Samsung SCX 4600 ? Ken Mallinson.
Hi
The toner cartridge door is located above the paper tray, Just pull it off and remove the toner cartridge.
Jan 13, 2011 | Samsung ML 2010 Laser Printer
HP printer problem
If its a new toner cartridge check that you pulled the tab and that its installed correctly.
Jan 20, 2010 | HP LaserJet 4 plus Printer
It leaks. It's all over the inside of machine. We don't use this printer a lot because we do design on-line; so it's not from overuse or worn out parts. It just leaks and then causes the printer to stop...
I have had problems with a number of brand new genuine HP toner cartridges leaking on this printer. Strangely, I have had almost no problems with non-OEM cartridges from Cartridge World.
I can’t explain this...and wouldn’t have believed this if I hadn’t experienced it myself.
Try removing all toner cartridges, and carefully cleaning out the printer with canned air. Then replace the leaky toner cartridges with Cartridge World cartridges. This has been my recipe for success with the HP Laserjet 4600.
Nov 16, 2009 | HP LaserJet 4600 Printer
How do i install a toner chip on my hp Cp2025
TONER CHIP on CP2025 printer:
This resource may help
http://resources.lasertekservices.com/hp-smart-chips-overriding-this-lockout-mechanism-with-reset-chips/
Gives types of chips to use, sales in USA, and certain things to take note of.
The toner reset chip replaces the original HP ID chip and is designed to be used only on refilled HP cartridges.
It is not recommended to force toner cartridges to run on empty, as this can cause damage to both the printer and the toner cartridge.
The reset chips are dedicated to one color only, so that user can not swap toners.
As for actual physical installation, just push the new ID chip in until it clicks into place. The correctly manufactured ones should be a snug fit.
I have seen techs using a drop of contact glue behind the chip-board to secure it.
Copper pads face outwards towards matching printer pins.
See photo for polarity 'square' pad.
My printer is Samsung, not HP, so your toner cartridge may be a different shape.
Nov 07, 2009 | HP Color LaserJet 2550n printer + HP Color...
Pull tab from toner cartridge
Try turning the printer off wait a few minutes and turn back on. also clean the contacts on the side of the printer (inside of the machine.) If not it could be a main board issue.
Jul 31, 2009 | HP LaserJet 4200 Printer
Cant instal this ink cartridge
This pull tab is on the cartridge to prevent it from leaking during shipment. You have to remove it to let the toner get to the drum.
Mar 06, 2009 | HP LaserJet 1500 Printer
I am using the workcentre 4150 and the printer keeps giving me an error saying. "toner supply failed, remove seal tape from toner cartridge and reinstall" I can't find any tape on toner...
The seal tape might be inside the cartridge, attached to a pull-tab.
I am only specifically familiar with the HP toner cartridges, which have a colored plastic pull-tab attached to the tape which seals the toner drum during transit. You have to pull on the tab which in turns yanks the sealing tape out after it.
Each HP cartridge has a small instruction sheet included which shows the location of the pull-tab. Perhaps your Xerox cartridge came with a similar diagram sheet?
Apr 03, 2008 | Office Equipment & Supplies
HP LaserJet 4600 Printer Logo
216 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
