Question about Intel D102GGC2 Motherboard
I have a 512 mb 667mhz sdram on D102Ggc2 board.now i decided to up grade memory. Can i upgrade system memory without lose this 512 mb.
    Scholar:
  • 96 Answers
Yes you can. but make sure that you buy the exact same type of RAM stick that you have and put it in the other RAM slot so the Dual Channel feature will be active (dual channel makes data transmission/processing faster) and making your systems memory 1GB. However, your motherboard can utilize or handle up to 2GB or RAM so you can put also a 1GB RAM stick which will make your systems memory a total of 1.5GB (that will be the case if you really dont want to lose the 512MB that you currently have,
Hope this helps.
Posted on Jul 12, 2010
    President:
  • 2,571 Answers
If you have spare unused memory slots, then yes you can just add more.
If all the slots are filled you will have to remove some of the memory to fit a larger module
Your board has 2 slots, and can take a maximum of 2 GB
Here is your boards manual http://downloadmirror.intel.com/15112/eng/D102GGC2_TechProdSpec.pdf
I have intel pendium d d102ggc2 motherboard. am using 512 mb ram ddr2 667mhz. Now i want to upgrade it and use 2 gb ram. please suggest.
Mother board d102ggc2
• Support for DDR2 533 MHz and DDR2 400 MHz DIMMs
• Support for up to 2 GB of system memory
Dec 27, 2012 | Intel D102GGC2 Motherboard
Gt5082 what is the best sticks for gateway gt5082
Memory Upgrade for Gateway GT5082 Computer, the Gateway GT5082
Computer takes the PC3200 DDR SDRAM DIMMs. Supports Dual Channel DDR. Memory
Type, and comes installed with 2.0 GB = 512 MB (removable) + 512 MB (removable) + 512 MB (removable) + 512 MB (removable) of Memory. You can upgrade your
Gateway GT5082 Computer to up to a maximum of 4.0 GB Memory, the system has 4 sockets to install Memory, already with 2.0 GB = 512 MB (removable) + 512 MB (removable) + 512 MB (removable) + 512 MB (removable) standard Memory installed.
For best Computer performance use the maximum amount of allowed Memory per slot for your Computer.
Choose the following Memory Upgrade for Gateway GT5082 Computer.
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
hope it helps
Apr 14, 2012 | A-Data Technology 1GB kit (512MBX2)...
I have compaq presario 5000 series...and iwant upgrade my ram ...i have 128+128 sd ram so how much i upgrade my ram...can i upgrade 512+512 sd ram OR 256+256 sd ram...thank you
the RAM upgrade will depend on ur motherboard capacity and specification.
u need to check ur MB manual
if ur MB can have only SD RAM then only SD RAM upgrade is possible...DDR will not work....
so be careful while buying ur RAM
intelD845GLLy MB...the following details are from the intel website
http://www.intel.com/support/motherboards/desktop/d845glly/sb/CS-012825.htm
System Memory Features
The D845GLLY board provide the following memory features:
  • Two DIMM sockets supporting 3.3 V (only) 168-pin 133 MHz Single Data Rate (SDR) SDRAM DIMMs with gold-plated contacts
  • Unbuffered non-ECC DIMMs only
  • Maximum total system memory: 2 GB; minimum total system memory: 64 MB
  • Serial Presence Detect (SPD) DIMMs only
  • Suspend to RAM
Caution Do not use ECC DIMMs with the Desktop Board. Using ECC DIMMs could damage the Desktop Board.
Integrator's Notes:
  • Registered DIMMs are not supported on the Desktop Board.
  • This Desktop Board has been designed to support DIMMs based on 512 Mbit technology for a maximum onboard capacity of up to 2 GB, but this technology has not been validated on this board.
Note To be fully compliant with all applicable PCI33 SDRAM memory specifications, the board should be populated with DIMMs that support the Serial Presence Detect (SPD) data structure. This allows the BIOS to read the SPD data and program the chipset to accurately configure memory settings for optimum performance.
hope this helps
Reg....bye
Feb 24, 2010 | Intel D845GLLY Motherboard
Will Intel D102 Series Motherboard support Transcend 1 GB DDR2 667 Mhz RAM. Please confirm
According to Intel, this board will support a maximum of 2 x 1GB PC2-4200 533MHz Memory Modules, so your PC2-5300 667MHz Ram may not work.
Intel® Desktop Board D102GGC2 - System Memory Features:
The board has two 240-pin DIMM sockets and supports the following memory features:
1.8 V (only) DDR2 SDRAM DIMMs with gold-plated contacts
Unbuffered, single-sided or double-sided DIMMs with the following restriction: Double-sided DIMMs with x16 organization are not supported.
2 GB maximum total system memory
Minimum total system memory: 128 MB
Non-ECC DIMMs
DDR2 533 or DDR2 400 SDRAM DIMMs
Jan 12, 2010 | Intel D102GGC2 Motherboard
I want to upgrade my ram what type of ram should i use and how what is the maximum amount of ram i can upgrade to?
Memory Upgrade for Sony VAIO PCG-K35 Laptop, the Sony VAIO PCG-K35 Laptop takes the PC2100 DDR SDRAM SODIMMs Memory Type, and comes installed with 512 MB = 256 MB (removable) + 256 MB (removable) of Memory. You can upgrade your Sony VAIO PCG-K35 Laptop to up to a maximum of 1.0 GB Memory, the system has 2 sockets to install Memory, already with 512 MB = 256 MB (removable) + 256 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Regards
Jun 29, 2009 | Sony VAIO PCG-K35 Notebook
Can i connect one two 667mhz rams in INTEL D102GGC2 mother board?
Memory Two 240-pin DDR2 SDRAM Dual Inline Memory Module (DIMM) sockets Support for DDR2 533MHz and DDR2 400MHz DIMMs Support for up to 2GB of system memory
hope helpfull
May 29, 2009 | Intel D102GGC2 Motherboard
512 MB memory boards do not work in my Fujitsu Lifebook S2020
frquance is not set and it is not recommand that 2 different friquance ram is not working propaties
Jan 09, 2009 | Fujitsu LifeBook S2020 Notebook
RAM cuantity
The motherboard you mentioned supports DDR1 RAM.
For windows xp and general application 512 MB is enough.
But if you use memory intensive applications like image/video editing then you can opt for 1-2 GB RAM.
Nov 24, 2008 | Intel D845EPI (INTELKD845EPILPAK10)...
RAM NOT DETECTING
I had the same issue on this board where it came with a Samsung 512 MB 533 MHz PC2-4200 DDR2 DIMM. I put in a 1 GB Kingston with the same specs (533 MHz PC2-4200 DDR2) and it would not recongize the Samsung anymore with the system reading as 1 GB of RAM instead of 1.5 GB. Tried every configuration and would only see the Kingston. It would only see the Samsung if I pulled out the Kingston regarless of the slots I use. So, I just bought the exact same make/model of Kingston and it recognized that fine and the system now has 2 GB of memory (max this board allows). And, I had already installed the latest BIOS for this board from Intel before doing all this so wasn't an old BIOS. I'm figuring the board didn't like something about the Samsung memory (speed, module configuration, etc.) that made it not play nice with the Kingston. If interested I bought the DM8400A/1G Kingston modules. And, this board appears not to support dual channel memory. Only has channel A, slots 0 and 1, and I read need two channels to support dual channel (seems obvious). Boards that supports dual channel memory normally have 4 memory slots, two for channel A and two for channel B, then put in matching modules in slot 0 for channel A and B and have dual channel memory access. And if want more ram, then matching modules in slot 1 for channel A and B.
Jun 25, 2008 | Intel D102GGC2 Motherboard
Intel D102GGC2 Motherboard Logo
104 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
