Question about Dishwashers
Normal or pots & pan light blinking and or sometimes both blinking and will not cancel and therefore we cannot turn on.this is a whirlpool quiet pardner ii.
    Genius:
  • 1,416 Answers
the problem is from powering on wiring connection from the [power supply consult a technician to give you an helping hand
thank you for using fixya.
Posted on Jul 12, 2010
My whirlpool quiet partner II imperial series Dishwasher will only work on light wash mode. Normal wash, heavy wash or pots and pans cycle will not work at all.
This is ordinarily a problem with the touchpad. Can you give me the specific model number of yours (ordinarily on a sticker on the inside edge of the door or on the door opening)?
Mar 06, 2016 | Whirlpool Dishwashers
Gold Quiet Partner lll. Why are lights flashing on normal, pots and pans, and cancel?
I had this happen and I was unable to cancel, so I believe I resolved it by flipping the breaker off, then back on, and it's been working fine for a several years since then. Your electric panel should have a separate switch/fuse for the dishwasher. Some have a plug under the sink, but most are "hardwired". Cheers.
Dec 26, 2015 | Whirlpool Dishwashers
Quiet Partner IV. Why is the pots and pans light blinking and it won't run?
Its normal for the drain pump to run for 5 to 15 seconds and then your washer should fill and you wash pump should run if your was pump is not running and just makes a humming sound then your start capacitor may need changing see the link below this is a simple task and not expensive. When ordering a new capacitor make sure it is the same size in ?F.
Washer Motor Capacitor part 8572717 How To Replace
May 28, 2015 | Whirlpool Dishwashers
Whirpool dishwasher quiet partner 2 clean light blinking wont cancel or run a cycle
press normal heated dryer normal heated dry normal the dishwasher should reset and start. You will need to check the heater this happens because the heater normally fails. Let me know,
http://www.appliancerepairlesson.com/
Mar 07, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
I have a whirlpool gold quiet partner iv; will not turn on; the light is blinking between normal and pots and pans cycle. Thanks
it may be a door inter lock or program board failure . need model # to tell you more about it . but it sounds like p c board ., you can try turning of power for 15 min then try it again .. . if this doesnot you may need a tec ..
Nov 22, 2009 | Refrigerators
Miele g892 and just like everyone the red light comes on and dishwasher stops running> why cant you answer thic common problem>
The red light tell you there is a fault. You have to read the fault code and it will give you a general idea of the problem - to do this you have to enter the service mode of operation - close the door and turn the dishwasher on.
The Start/Stop light must be blinking. If the Start/Stop light is not blinking, press and hold
the Start/Stop button for at least 3 seconds to exit the cycle. The Start/Stop light should now be blinking.
Press and hold the Start/Stop button while turning the dishwasher on. Release the
Start/Stop button and immediately press it 2 more times. Flashing Intake/Drain and
Salt lamps and a lit Rinse lamp indicates successful accessing of services mode
Fault codes
F00 Pots & Pans Lit
F01 Sani Wash Lit
F02 Normal Plus Lit
F03 Normal Lit
F04 Economy Lit
F05 Rinse & Hold Lit
F06 Pots & Pans Lit
F07 Sani Wash Lit
F08 Normal Plus Lit
F09 Normal Lit Flashing
Sep 19, 2009 | Miele G880 Dishwasher
Whirlpool Quiet Partner 980
Bad control board ,replace it.
May 26, 2008 | Dishwashers
Dishwashers Logo
400 people viewed this question
Top Dishwashers Experts
Owen Barnes
