Question about Dell Dimension B110 PC Desktop
WHEN I TURN IT ON IT DOSENT RECKONIZE THE KEY BOARD, MONITOR OR MOUSE. THE ORANGE LIGHT IS ON IN FRONT NOT THE GREEN LIGHT.
  • Dell Master
  • 4,806 Answers
Is the power button a steady abmber light?
If so follow the instruction below>>>>
Remove the power cord from the back of the computer. Then open the side casing of the tower and unplug the 24 pin block connector from the motherboard. The 24 pin block connector looks like this >>>>>
Once removed press the on/off button on the computer to dispel and residual power from the motherboard.
Then connect the block connector again and put the side panel back on and then plug the power cord back in and try to boot the computer up.
If its still the same then the power supply inside the computer may need replacing.
Good luck.
Posted on Jul 12, 2010
Not linking to iMac
Press the button on the top right side of the key board, if the green light lights up you have power in the key board. Turn your mouse over and the green light should be on if the mouse has power.
Apr 19, 2015 | Computers & Internet
Compaq will not turn on
im just guessing that you might have last used your compaq with a multimedia projector... it might still be on an "extended mode." you can check this using another cable and hook it up with a separate monitor and see if your desktop will appear on that monitor. if it does, right click on the mouse and choose "graphics properties." Click on the "hot keys" and check which keys you should press to enable your computer.
Jul 09, 2013 | Computers & Internet
My hp pavillion mx 50 montior dosent turn on and if it does the green light on turns to an orange what to do to fix it
Check your Monitor Cable at the back of your PC unplug it and chec for bad pin conection make sure your Monitor cable are plug in correclty....
Oct 01, 2010 | HP Pavilion MX50 15" CRT Monitor
My dell monitor turns on for 2 seconds then goes black and the green light blinks orange
I assume that you already try this monitor on another PC to verify that the problem is in the monitor, in this case you need to open it up and inspect the fuse, transitors, solder connections on the power/inverter board, see failed Dell monitors here for guide: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 23, 2010 | Dell E173FP 17" LCD Monitor
Green light comes on for a few seconds then turns orange
If you have a popped cap then the mosfets are blown. They blow as soon as the cap shorts and pops. You need to replace both mosfets and the 220uf caps and test the fuse with a multimeter I would bet its blown too.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Dec 17, 2009 | Acer AL1916W 19" LCD Monitor
Hi Master, can you help me how to fix mag innovision model 468P when i turn on the monitor in a second the monitor will automatically off display and change the light power from green to orange.? please...
from green to amber could be one of many things,1 video grapics card malfunction,,,2,, dry joints in the mother board..3 bad data cable ,,pc to monitor cable vga,,failing power supply,,,,i suggest you open the pc remove the data cable to you floppy while it is off remove memory stick clean with a damp soft rag or tissue reinsert when allowed to dry for 10 mins and then restart pc without the speakers web cam and anything except mouse keyboard and restart ,if it does same thing then your problem lies in *********** board,thus you need a new one
Oct 21, 2009 | Mag Innovision 771fs-s 17" CRT Monitor
The monitour will go from green light to orange after sitting for about 10 or 15 min. you move the mouse and it does not go from orange to green. you have to restart the computer.
Lower down the computer resolution and frequency rate from Video setting>>Advanced in control panel (personalize on Vista) replace the video cable.
If that does not help then the monitor is defective.
If there is a flashing led on front of the monitor, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1 The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours, sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occurr suddenly are a blown capacitor on power board, the inverter board powering up backlight lamp has blown, or a fault on main lcd controller board.
check also the video cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
Check connectors, try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact manufacturer to find out a service point.
If you want to repair at your own expenses, just locate any good qualified repairer.
Regards
Mar 06, 2009 | Computers & Internet
Computer monitor won't tur on
check the connector to the pc from the monitor. it may have come loose. if you have a mouse, try moving it and see if the light on the monitor turns to green. it is possible the video has failed.
Dec 02, 2008 | Dell Dimension 2400 PC Desktop
Dell Dimension B110 PC Desktop Logo
136 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
