Question about Gateway M285-E Notebook
Is there a way to repair a bios after a failed update
    Problem Solver:
  • 8 Answers
There are many solutions you can find from google. If you still fail, then go to www.biosxp.com
Posted on Sep 03, 2010
    Problem Solver:
  • 10 Answers
Recovering a damaged BIOS is simply a matter of replacing the missing or damaged code contained within the CMOS or EEPROM. This is not an easy task and some computer knowledge is strongly advised if attempting this.
You can solve the problem by removing the Lithium battery on the main board, wait a few minutes, then put the battery back in and reboot.
The BIOS will detect that there are no BIOS settings, and use some default settings. NOTE...It will tell you that some settings are erratic, but at least you are now able to press DEL to enter BIOS setup.
After entering setup you will be asked to choose either "Load default fail safe" or "Load optimal settings". The latter will work most of the time. Save these settings, reboot and see whether your attempts were successful. I've seen this type of boot failure on many machines and in case of bios update failure, this has worked 90% of the time.
If, by chance it does not work at once, try to keep the battery out a little longer, and short-circuit the + and - pins of the battery socket.
When you do get some life back into your PC don't forget to check that you indeed flashed the correct BIOS version that belongs to your motherboard. Maybe you flashed just a slightly different version. If so, find the correct BIOS version even if your PC seems to work after following the above steps, find the correct BIOS version and reflash.
I WISH YOU LUCK!
Posted on Jul 12, 2010
My laptop is not starting or boot
BIOS updates have gotten much less risky over time, but things can still go wrong. You need to get your system model number and check the SONY website to ensure that you did in fact install the correct BIOS. This is the most common problem when the BIOS update seems to work, but reboot fails. Some BIOS updates are restricted to certain countries and/or certain sub-models. You may find a procedure that will let you reload the original BIOS and get control of the machine back. If not, you may have what we refer to a "bricked" machine. You can probably send it back for repairs, but they are usually too costly to consider. It may be too late to say this, but I learned a long time ago a good set of rules about BIOS updates:
  1. BIOS updates will not fix hardware problems that pop up - if the old BIOS was working before, the new version won't make things right.
  2. BIOS updates should only be considered if you are upgrading hardware (and in some cases software) and find that the original BIOS does not support it. Ensure that the new one DOES support it before updating.
  3. The golden rule of BIOS updating is.....if the machine ain't broke....don't fix it. A perfectly functional machine will not function more perfectly with different code. The risk isn't worth the some unknown potential benefit.
Mar 06, 2015 | Sony VAIO Computers & Internet
Power failed during MSI P67A-C43 B3 bios update
Download the latest BIOS update from your computer manufacturer's website onto a USB flash drive. Refer to your user manual to obtain the manufacturer's website address. If the downloaded BIOS file is a zip archive, unzip the contents onto your USB flash drive. Jumper settings may need to be reconfigured on some motherboards to enter BIOS recovery mode. Most Intel-based motherboards have a jumper setting or switch near the on-board CMOS battery. The procedure for setting the jumpers will vary depending on your motherboard make and model, so refer to the motherboard documentation for specific instructions. Power on the computer and press "F2" to access the Setup Mode menu. If you are unable to access the setup menu, you will not be able to proceed with this repair. Take your computer to a repair shop, as the motherboard may need to be replaced. Use the arrow key to select "Boot Priority" or a similarly named field. Press the "Enter" key. Scroll down until "First boot priority" or "First boot drive" is selected and press "Enter." Select the USB flash drive as the first boot priority device. Press the "F10" key to save this setting and exit from the setup menu. Connect the USB flash drive to an open USB port on your computer. Then let your computer fully reboot. The USB flash drive should be detected and the BIOS should update automatically. When the update is complete, you may be prompted to restart your computer, or it may reboot automatically. If you are able to use your computer without any further problems of overheating or failure to recognize drives, your failed BIOS update has been resolved.
Apr 05, 2013 | MSI P67A-C43 B3 Desktop Motherboard -...
Gateway 504gr bios update failed
You maybe using the wrong version, it's already updated, or simply can not be upgraded.
Unless there is a TRUE need to flash, and usually there is not, I would stay away from. So many people try and fail, only to wipe the CMOS, leaving the system useless. Here is some sound advice on the subject.
http://www.techrepublic.com/blog/10things/10-common-mistakes-you-should-avoid-when-flashing-your-bios/357
Oct 01, 2012 | Gateway 504GR PC Desktop
How do i repair the cmos for satellite l500? Bios update failed
To reset the BIOS read the information from this link. Although article is about removing BIOS password the second, third and fourth methods pretty much will bring the BIOS to initial factory settings.
I would suggest getting Hiren's Boot CD and use Kill CMOS to wipe the BIOS to the factory settings.
Feb 10, 2011 | Toshiba Satellite L500 Series Notebook
Changed out the motherboard reformatted a blank hardrive, No issues in the reformat.Installed drivers then updated the bios.Currently will only boot to bios briefly then shuts down.Tried resetting the bios...
Sounds like your BIOS update did not complete successfully. Head to the board manufacturers website and check if there is some way you can reload the BIOS and recover from this. Most boards now have dual bios which means that if one bios chip fails or an update fails, you can reload the stored BIOS through the other chip. If you are unable to recover from a failed BIOS update, you may need to purchase a replacement BIOS chip from the board manufacturer. You may even be able to reload the original BIOS onto the chip through your local PC repair store so give them a call and enquire..
May 21, 2010 | HP Compaq Presario SR1300NX (PP195AA) PC...
I was given an L500. It powers but fails to POST, this happened after a recommended BIOS update. Any kind of debug ports or something to sort this out?
After a BIOS update, if it fails to post, the BIOS update got corrupted. This happens (rarely) and when it does, the only thing that can be done is to remove the BIOS chip and have it burned at a local repair shop (or sent into Toshiba for a replacement). Without the BIOS functioning properly, the computer can do nothing at all. If your BIOS is not on a removable chip, then the computer will have to be sent to Toshiba to have the BIOS replaced.
May 12, 2010 | Toshiba Satellite L500 Series Notebook
Hp dv9008 Tried to update the bios but somehow failed,now it
get it repaired under the limited warranty scheme
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us
Nov 08, 2009 | HP Pavilion dv9008nr Notebook
Will not power up after failed bios update
If the BIOS update failed it could have damaged the CMOS chip & may not be repairable without a new CMOS chip.
Oct 21, 2009 | Computers & Internet
I can't update my Travelmate 8104WLMi. Every time
it is not flashable then you dont ever update your bios unless it has a problem.
Oct 19, 2009 | Acer TravelMate 8104WLMi Notebook
Gateway M285-E Notebook Logo
185 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
