Question about Kenmore 53552 / 53554 / 53559
There is at least 3 to 4 inches of solid ice at the bottom of fre
There is at least 3 to 4 inches of solid ice at the bottom of my freezer, and water leaking on to floor(im not sure if the water is coming from the bottom of the unit) and the freezer is freezeing everything solid, even if i turn the freezer down to 1 for the cold my icecream is still solid
  • Kenmore Master
  • 43,501 Answers
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
Water Running in Refrigerator from Freezerthere is at least 3 to 4 inches of solid ice at th - 2_bing.gif
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Posted on Jul 13, 2010
Testimonial: "thanks for the info you saved me some money"
Bottom Ice Maker
is it getting water? if not it could be the water solenoid. if it is and there is ice in the ice maker frozen then it could be the icemaker its self. make sure arm is down in the running position. if water is not frozen solid then the freezer is not cold enough.
May 26, 2012 | Refrigerators
Ice buildup in bottom of freezer--puddle of water on floor
this sounds like your freezer is operating properly, except that the drainage of the water when going through the defrosting mode is not draining properly, pooling on the bottom of the freezer and then freezing. Check the drainage hose for the defrost in the lower pan. I would remove everything, place in ice chest, let the unit completely thaw out and then inspect. I hope this is beneficial.
Aug 05, 2009 | Freezers
We have a Hotpoint refrigerator/frezzer. It intermittently makes fan noises and stops making ice. Where do we find someone who can service the unit?
I hope your microwave doesn't make ice !!!
Are you in the GTA (Greater Toronto Area). If not I can tell you what is happening.
All fridges have a timer so that the freezer goes thru a defrosting mode for about 3hrs
In that 3hrs there are hearter in the walls of the freezer to melt the ice.
As the ice melts , there is a drain from the back of your freezer down to the bottom of the fridge is a vaporator tray. The hose could be blocked and the water can't drain and after the defrost mode all that water changes to ice and it stops the fan
Take the time to make sure that hose is fre from abstruction
Jul 14, 2010 | Microwave Ovens
The bottom freezer portion of my gladiator freezerator forms ice
heatman101
Nov 09, 2009 | Gladiator Freezerator Top Freezer...
Icemaker freezes up and deposits ice at the bottom of the compartment. My icemaker seems to freeze up and stop producing ice while dumping the water to the bottom of the freezer compartment where is...
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze and can't go where it's supposed to. You can take the water line off the valve and watch to see if it drips.
Nov 05, 2009 | Samsung RS2630SH Side by Side Refrigerator
Water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
the defroster isn't close enough to the drain to be effective. remove the back wall of the inside of the freezer, remove the excess ice. clear out the ice from the drain using hot water and a turkey baster. there is a kit from whirlpool that uses a piece of metal and a screw around the defrost rod, but I found out that a piece of 14 gauge solid core wire with the insulation stripped off works great too. stick the stripped wire into the drain, 2 to 3 inches, and wrap the rest around the defrost rod.
Jun 02, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Freezer has 1/4" ice on bottom, everyhing in freezer solid rock.
Your freezer should have a drain located in the bottom rear, usually behind an access panel that allows water to drain into the pan under the unit during the defrost cycle. If this drain becomes plugged, the defrost water has no place else to go but into the bottom of the freezer and turn into a block of ice. Clear the ice and poor hot water down the drain. You may also want to fish something (I use 1/4" water line) down the drain until the end gets to the pan underneath just in case there was something more solid stuck in the drain.
Mar 21, 2009 | Refrigerators
Freezer leaking water
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
Apr 09, 2008 | Freezers
Excessive Frost and Ice Build up in Freezer
Mar 20, 2008 | Refrigerators
Ice 2 inches thick in bottom of refrigerator
the defrost drain is more than likely plugged. unplugg the fridge, take the back pannel of the freezer. remove as much ice as you can from the drain trough (putty knife works good). Once you can see where the drain spout is use hot water and a turkey baister to clear the ice from the drain. this will stop the build up of water(ice) in the bottom. as for the eggs i know it souns simple but turn the fridge down a half point per 24 hrs. use a thermometer in a glass of water to check the tmp. can safley run between 33f and 40f. Good luck.
Sep 25, 2007 | Refrigerators
Kenmore 53552 / 53554 / 53559 Logo
101 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
