Our front load washer has water left in the drum and won't spin on any cycle.
  • dankutch Apr 20, 2008
    HI,
    It's a GE Model GCVH6260 about one year old and yes, it wont spin on any wash mode. In fact when you select a wash mode, it (the drum) rotates once to the left then to the right then nothing else happens except the timer counts down the time. Also, water is left in the drum.
    I read some of the other posted comments about a "plugged filter" in the front of the washing machine behind the front lower panel (only three screws to take off) and indeed, it was very plugged with all kinds of coins, lint and other stuff. Once I drained the plugged filter into a bucket, all is well again. Thanx to all who post their solutions to similar problems as I am now. This turned out be be a five minute (free) repair I did myself.
    Master:
    Sergeant:
  • 462 Answers
Whats the model no and brand of your washing machine..?
Posted on Apr 20, 2008
  • 1 more comment
  • Mohamed Ismail
    Mohamed Ismail Apr 20, 2008
    Also do you mean to say that in any of the washing modes, he drum doesnt spin at all...?
  • Mohamed Ismail
    Dont worry sir, we will look into it and get back to you soon.
    Thankyou
  • Mohamed Ismail
    I once happen to disassmble my friends machine for the exact same reason you mentioned. And I mean completely. Not a screw still in place. It took 4 hours.
    Turns out in my case that electrolysis is the problem.
    What I mean by this is that behind the inner drum is a three pronged heavy metal piece made from galvanized steel which attaches to the inner drum by 6 large screws. Coming out of the center of this is a post which comes through the plastic drum housing into the back of the machine and hooks to the assembly your belt runs on. (This wheel for the belt looks a bit like a tire wheel well but thinner.)
    What the problem is for me is that the piece inside that attaches to the drum (the galvanized steel one) has completely corroded from electrolysis and broken. All three prongs have completely broken off making it impossible for the drum to turn. I am a little irritated with GE at the moment because had they used an appropriate metal, knowing it would be constantly bathed by the water from the laundry loads, I would not be in this predicament. I am a little disturbed that a 15 lb metal part has broken before the rubber belt even wore out!
    I mysel am on here right now trying to find the exact name of this part and possibly a part number so I can order it and replace it. My basement is currently a compete mess from this project and I have laundry waiting to be done.
    I am also looking to see if maybe this just might be a recall situation where we can get some help with getting the part due to what I feel is faulty manufacturing.
    In the meantime, unless you have the appropriate tools, plenty of time and plenty of patience, I don't suggest tearing into your machine like I have. It may be worth calling a appliance repair place for you.
    If you want to be certain that this is in fact the same problem with your washer, open your machine and see if you can freely move the drum around by pushing on it. If it isn't a good solid middle of the machine spin and has play in it wear you can lift the drum a bit in any direction, we have the same problem.
    Just from your description, I am betting we do.
    I hope this is helpful, and I'll let you know what I find out!
I have a Kenmore HE 2plus front load washer and during any wash cycle the drum won't spin and at end of cycle displays F01
Front-loading washer Kenmore HE2 plus - spinning not ...
www.shopyourway.com > Manage My Life > Questions
My Kenmore HE2 plus washer has problems with spin funciton. almost all of the ... or twins size blanket, it just won't spin, even with extra spin cycle only. ... Check to see if the washer will spin without any clothes at all in the basket. ... My HE2 will wash a very small load. ... Any bigger loads The drum will try and turn but wont.
Front Load Washer Won't Drain or Spin Video: Washing ...
? 1:54
https://www.youtube.com/watch?v=wlMoT9rgvAg
Jun 1, 2012 - Uploaded by searspartsdirect
... won't drain or spin. For more front load washing machineinformation and repai. ... If the cycle has completed and water is still left in the machine select "Drain and Spin" to remove anywater remaining in the washer. This can be caused .... I have aKenmore HE2 plus front load washer. I can't seem to get it ...
Kenmore HE2 Plus 3.6 cu. ft. Front-Load Super Capacity ...
www.kenmore.com > Laundry > Washers > Front-load Washers
KenmoreFront-Load Super Capacity Washing Machine (4753) .... super wet, and to spin the empty drum after each load to hear if anything was caught in that gap. .... 1st of all: You cannot use any other detergent than HE rated detergent - PERIOD. ... will create too many suds and clog up the machine, and the clothes won't be clean.
Jan 15, 2016 | Kenmore Washing Machines
Ge front load washer no spin cycle
You have no spin cycle cause the washer will NOT Drain the water left in the drum...Solution. You need a new Drain Pump! TaDa...!
It will fix it!
Dec 20, 2013 | Washing Machines
Mav4757aww leaks water during spin cycle with full loads only
Thanks for the quick responses.Pulled front cover,ran a load on high level, no leaks .Ran a load on super level and when drum spins when full of water water level rose and poured out of left front side on top of drum. Pulled plastic ring on top of drum and and found piece of seal missing where leak occured .Ordered upper tub seal, should solve problem
Jul 27, 2012 | Maytag Ensignia MAV4757AWW Top Load Washer
Going through full wash as normal but won,t go onto rinse or spin mode?
Most front load units must have two things, door must lock and must sense cold water for rinse. I would check the fill line for the cold water, if clogged with sand, it will not progress through cycle. If the unit doesn't drain it will not spin, is there water left inside the drum area?
I am here if you want more assistance
Aug 28, 2011 | Bosch Exxcel WFX 2467 Front Load Washer
I have a Maytag MAH4000AWW. Machine does not drain all of the water out after spin cycles - so clothes come out soaking wet and a little water is left in bottom of drum. Also the Door Lock light does not...
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 23, 2010 | Maytag Neptune MAH5500B Front Load Washer
Danby front load washer Will not spin motor runs
If the "Spinning Off" button is pushed in you will get this problem.
It happened to my wife last week.
If the drum is turning the belt is OK
Jan 25, 2009 | Danby DWM5500 Front Load Washer
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
