Question about Microsoft Computers & Internet
CAN WINDOWS PREMIMUM RUN MY PROGRAMS THAT NOW RUN ON MY XP HOME OPERATIG SYSTEM AND WHAT IS DIFFERENCE BETWEEN THE 32 OR 64 OF WINDOWS 7
    President:
  • 2,571 Answers
Some will work some wont, Check here for what may work http://www.microsoft.com/windows/compatibility/windows-7/en-us/default.aspx
Windows 64bit can use more memory than the 3gb 32bit versions can use, however 64bit versions have far more problems with program compatability, I would stick with 32
Posted on Jul 12, 2010
System Manufacturer and Model: Gateway LT20 Operating System: Microsoft Windows XP Home Edition (5.2, Build 2600) BIOS: InsydeH20 Version V1.08 Processor: Intel Atom CPU N270 @ 1.60GHz (2 CPUs) Been...
In a situation like this it's most likely you have come across a virus, whether it be a trojen, worm, ect. Backup all your important files from your computer, documents, pictures, movies, music. Once this is done, reinstall your copy of Windows XP, and make sure you have a good anitvirus, malware, and spyware programs I recommend using either Avira Anti-Virus or AVG for virus protection, Malware Bytes for malware, and Super Anti Spyware for spyware, all of which can be obtained freely. You can find these programs on www.filehippo.com Just search for them, and you can download them from this site. Install your protection after installing XP, then run a scan on your backup data before you put it back onto the computer, just in case any of these files may be infected!
Aug 25, 2011 | Microsoft Windows XP Home Edition
Tip
DRIVER NEEDED: Hitachi hl-dt-st rw/dvd gcc-4241n (Windows XP Home)
DRIVER NEEDED: Hitachi hl-dt-st rw/dvd gcc-4241n (Windows XP) [IDE]
Simple solution:
Situation
There is a yellow exclamation mark for CD/DVD drives in Device Manager. The device status in the properties of the driver might indicate an error code, for example 32, 37, or 39. Or the drive simply does not appear in My Computer or Device Manager.
Solution
To solve the issue, you have to edit the Windows Registry:
Click Start, then Run, type REGEDT32 and click OK.
Locate and then remove the following registry values:
HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlCl ***{4D36E965-E325-11CE-BFC1-08002BE10318}LowerFilters
HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlCl ***{4D36E965-E325-11CE-BFC1-08002BE10318}UpperFilters
Close Registry Editor.
Reboot the system for the changes to take effect.
Note: Some programs are unable to detect the CD/DVD drive after these steps. To solve this, simply re-install the program in question, eg: usually your recording software. Also, in few instances the order in which the programs are (re-)installed can make a difference.
on Sep 12, 2010 | Computers & Internet
What is the procedure to install a 32-bit softwares in to my laptop(windows 7,home premium,64-bit) ?
Most programs designed for the 32-bit version of Windows will work on the 64-bit version of Windows. Notable exceptions are many antivirus programs.
Device drivers designed for 32-bit versions of Windows won't work on computers running a 64-bit version of Windows. If you're trying to install a printer or other device that only has 32-bit drivers available, it won't work correctly on a 64-bit version of Windows.
Windows 7 64bit does run programs that will run on windows 7 32bit, see here
How Windows 7 / Vista 64 Support 32 bit Applications
BUT not ALL 32bit programs will run on Windows 7!!! There are many programs that will run on Windows XP and before that will not run on Windows 7. IF you had Windows 7 Pro version (or upgrade) there is a program you can download from Microsoft that will simulate an XP environment to allow programs to run called "XP MODE".
Try to install the 32bit software first. If installation not succeed, it would be better if you first look into a newer version of the program you want to run.You have to consider that a newer version of your program might not be that much more expensive than upgrading to pro, and with the newer version, usually comes newer features.
Hope this help and if helpful RATE please.
Feb 17, 2011 | Microsoft Windows 7 Home Premium 64BIT...
Will not function with Windows 7, what is wrong?
Not all programs that worked in Windows XP will run in Windows Vista or Windows 7.
I suggest you try compatibility mode to see if it helps.
If the program is not compatible, then you may try to install and run the program in compatibility mode.
Use the following steps:
1) Right click on the Program
2) Click on Properties
3) Click on Compatibility tab
4) Select Run this program in compatibility mode and select Windows Vista or whatever operating system the program was running successfully.
Refer to the link here: Make older programs run in this version of Windows
http://windows.microsoft.com/en-us/windows7/Make-older-programs-run-in-this-version-of-Windows
If the compatibility is not successful, then try and runthe Program Compatibility troubleshooter:
1. Open the Program Compatibility troubleshooter by clicking theStart button.
Then click Control Panel. In the search box, type troubleshooter, and then clickTroubleshooting. Under Programs, clickRun programs made for previous versions of Windows.
2. Follow the instructions in the troubleshooter.
If you cannot install a program, insert the installation disc for the program and, using the troubleshooter, browse to the program's setup file, usually called Setup.exe, Install.exe, or something similar. The troubleshooter is not designed to work on programs that have an .msi file name extension.
If you run Windows 7 Professional or Ultimate version, install Windows Virtual PC and Windows XP mode (http://www.microsoft.com/windows/virtual-pc/default.aspx) and execute your software in Windows XP.
If you run Windows 7 Home Premium, try VirtualBox (www.virtualbox.org) or VMware Player (www.vmware.com) and install a separate copy of Windows XP (either Home Edition or Professional) for that purpose.You can find virtualization software free of charge that will run on Windows 7 Home Premium.
Hope this helps.
Oct 28, 2010 | MGI Software PhotoSuite 3 for PC
I have a problem with my PC: When I try to turn off the windows XP home edition SP3 the pc don't stop he restart, but i think the HDD C: where windows is install stop and then restart all sistem (like in...
It Seems Some System Files are Corrupted or Deleted By Antivirus Application in the Process of Removing Virus from your System ....
Method 1:
1. Put your Windows XP CD in your CD-Drive
2. Open RUN Dialogue Box From Start Menu
3. Type "SFC /SCANNOW" -- Copy and Paste the Command exactly
With out Quotes
4. Wait Until It Completes everything...
5.Restart and Check your Problem ....
Method 2:
1.Login to your Windows XP
2. Put your Windows XP Home CD in your CD-Drive
3. Click Install Windows XP From Autorun Window.Start Windows XP Autorun Screen if its not opened, by Clicking on the Windows XP CD Drive icon under your My Computer ...
4.Select Same Drive as your Windows XP Now Installed then Select Upgrade Method to Install...
5.Complete Installation and Restart your System ...
Note: in Upgrade You'll never lost your Installed Programs and Files ...
Feb 20, 2010 | Microsoft Windows XP Home Edition
I am using toshiba l310 laptop with windows xp installed onit.NOW I WANT TO CHANGE MY OPERATING SYSTEM FROM XP TO WINDOWS 7,MY QUESTION IS THAT CAN I USE SAME DRIVERS FOR WINDOWS 7 WHICH I USE ON XP ...
You will need new drivers for Win 7. Before attempting to go to Win 7, run the Microsoft Upgrade Advisor and see what issues it lists: http://go.microsoft.com/fwlink/?LinkId=161223 (since laptops have on-board video that may be an issue). You will be doing a custom install from XP and have to reinstall all of your programs and drivers - many will be available. Several XP programs will not install in Win7 without some work (compatability mode or the XP mode virtual machine (in Pro or Ultimate). Upgrading your software may be needed unless you have the latest version that supports XP through Win7 or want to do the work-arounds.
In addition you would be wise to check for any BIOS updates for your specific machine and apply those. Windows 7 is a good OS if you have 2 GB or more of memory. It can run with less but it isn't better than XP in that case. The biggest difference is that Win7 will be supported by Microsoft for updates for a longer period (patches); XP will lose that support in the next few years.
I hope this helps.
(I converted an XP desktop to Win7. However, my video card could handle the OS and I have 2.5 GB of memory and a Windows Experience Index of 3.9 from the system.)
Feb 15, 2010 | Computers & Internet
Problem Installing Windows 2000.
i help tel u one thing actually there s very users for windows 2000 nwdays...so i will recommend u to jus install windows XP or Vista wch r the best nwdays...but i prefer XP s better than Vista...but nw Vista premimum s better...so if installing vista then go for vista premimum...its gud!!!!
Jul 26, 2009 | Computers & Internet
System crashes and i have to reformat after installing msn premium software on new 64 bit vista laptop
you can downgrade to 32bit. you would have to reinstall windows using a 32bit cd. i would recommend it you wont see much of a difference. all programs where originally made for 32 bit. the only difference between the two is that 64bit supports more ram. like xp pro; 32bit will recognize 3.25gb as ram even if you have 4gb installed but other than that not much difference. personally i dont like any 64bit systems nor vista... but with 32bit you will be able to run a wider range of programs with no problem
Apr 16, 2009 | Computers & Internet
Windows Vista Basic or premimum ?
You can find all the details & info here :
http://www.microsoft.com/windows/products/windowsvista/editions/default.mspx
And
http://www.microsoft.com/windows/products/windowsvista/editions/starter/default.mspx
Home Premium
Windows Vista Home Premium is the preferred edition for home desktop and mobile PCs. It provides a breakthrough design that brings your world into sharper focus while delivering the productivity, entertainment, and security you need from your PC at home or on the go.
Home Basic
Windows Vista Home Basic is ideal for homes with basic computing needs like e-mail, browsing the Internet, and viewing photos. Easy to set up and maintain, it enables you to quickly find what you're looking for on your PC and the Internet, while providing a more secure environment to help protect you from an unpredictable world.
Good Luck.
Live, Love, Laugh.
May 15, 2008 | Microsoft Windows Vista Ultimate Edition
Conversion to window xp from vista
create a second partition on your hard drive and install xp
or
format your hard drive and install xp
Dec 11, 2007 | Microsoft Windows Vista Ultimate Edition
Computers & Internet Logo
50 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
