Question about Hotpoint 24 in. HDA3420Z Built-in Dishwasher
My Hotpoint HDA3420Z dishwasher is not draining. I discovered a glass had broken at the bottom. Is there a filter that needs cleaning?
  • Hotpoint Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
Posted on Mar 27, 2011
Hotpoint fdw85 does not drain
sounds like the pump is not working
Jun 11, 2017 | Dishwashers
Will not drain
Hello Keith, thank you for allowing me to assist you!
Often when a dishwasher does not drain, it is because the drain hose may be clogged or you have a faulty drain pump. First, I recommend cleaning the glass trap that is located in the center of the unit designed to collect pieces of broken straws, bones, glass, etc. The filter can be removed for cleaning by simply grasping the handle and lift it out. Once you empty the filter, you may wash it with warm soapy water and allow it dry. Then place filter back. However, if you continue to have water left in the sump and the dishwasher is making a grinding noise, then it is recommended that the drain motor be diagnosed. You can locate a certified technician directly through the manufacturer website or in your local directory.
Jan 09, 2014 | Frigidaire Dishwashers
Our 2 year old Miele dishwasher (G1182/G2182) makes a strange popping/grinding glass noise when draining. We used 1 bottle of Finish Intensive care & clean with no improvement. Any suggestions?
there is a piece of debris in the drain pump. remove the triple filter from the bottom ( the one you are supposed to clean every week to keep debris out of the drain pump) under that filter and to the left hand side you will see the non return valve. squeeze the tab and pull the non return valve out. remove the broken glass or whatever is stuck in the drain pump impeller. replace the non return valve. replace the filter. if you need a picture go to mieleusa.com, and search for your owners manual. it has step by step tutorials on how to free an obstruction from your drain pump.
May 27, 2012 | Miele Dishwashers
Glasses not clean and shiny
Dishwashers have a part usually called a separator or accumulator which traps the dirt from the water during the wash cycles while the water is continuously recycled to clean the dishes. At the end of the cycle the separator is flushed out and the trapped dirt goes down the drain. If it doesn't get flushed out the dirt builds up till it starts showing up on the dishes. Some separators have a hole on top and one on bottom with a valve which stops up one hole or the other depending which cycle it's running. The valve can be stuck or broken causing the problem.
Jul 06, 2010 | Hotpoint 23 in. BFI62 Built-in Dishwasher
We discovered broken glass dish in bottom of dishwasher with some pieces below the bottom pump area. Shortly after the washer is making a louder noise during operation time. The water pump is quite when...
sounds like you have broken glass in the wash pump you will have to remove pump from sump and clear also check the drain pump.good luck let me know how it goes
Jun 22, 2010 | KitchenAid KUDK03ITBK Built-in Dishwasher
Dishes remain dirty, Food particles all over interior of dishwasher. hotpoint dishwasher model HDA2030Z02WW
In the back of the dishwasher at the base there is an indentation. This is where the food particals go when they are washed from the dishes. In this indentation there is a filter and a small wire appendage that is connected to the impeller of the motor. What happens is the dishwasher takes the food off the dishes and it is washed into this indentation area where the wire appendage turns breaking up the food particals to be flushed out during the drain cycle. What it souds like is this filter is clogged to the point no further waste can be flushed out. If you take the bottom tray out and reach into this indentation you will feel the filter. (note) there is a cover over this area that will need to be removed to access this filter. Once the cover is off you can reach into the area and you will feel the filter which should pull up and out. Be very carful when reaching into this area due to broken glass particles that may have accumulated. Once the filter is out clean the area well and replace the filter and you should be good to go
Hope this helped
Dave
Mar 31, 2010 | Dishwashers
Water doesn't drain out of bottom.
Broken glass is caught in the pump. a take apart cleaning of the pump and drain hose is in order.
Mar 13, 2010 | Maytag MDB9600A Jetclean II Built-in...
Water is not draining from the bottom. screen looks dirty, how to clean?
Take out the filter cup screw anticlockwise and lift the filter assembly will lift out also. You may find the blockage there. If you are careful you can take the drain pump cover off from the inside and find a blocked impellor usually broken glass or crockery.
Feb 24, 2010 | Asko D1776 Built-in Dishwasher
I have LG dishwasher for 2 years now. Working perfectly until one day one glass gets broken during washing cycle. Immideatly we get EO error. We check possible reason of error in the manual then decided to...
In order to fix problem we disconnected dishwasher, put it on one of side, opened bottom cover - the one that is outside of dishwasher. We find out the part that is
connected to the drain horse. We take of 3 screw and open that part too. We discover
few small peices of glass that were preventing to rotate one plastic part of dishwasher. We removed that pieces of glass. Put all back and connected dishwasher. All was working fine. I am suggesting to everybidy try these steps before calling for any service.
May 19, 2008 | LG Dishwashers
Dishwasher won't empty
sounds like the hose is blocked (usually with broken glass, followed by larger food particles) that runs from the dishwasher to the sink. You may need to remove this piece to check. If that isn't the problem, it's probably electrical.
Jan 26, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Dishwashers Logo
98 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
