Question about Pioneer A35R 2-Channel Amplifier
Pioneer SA100 integrated - low, distorted output
Pioneer SA1000 integrated amp - low, distorted output to headphones and speakers. I loaned this out and I believe it was overdriven or overloaded with too many speakers. I replaced all 4 output power xisters with no discernable improvement.
Thanks
  • 4,234 Answers
At this point, I would be looking at the main power suply for the final output stage. You may be attempting to drive the output with the driver section rather than the final amp stage. The center pin of the output transistors should have B+/B- on them. Measure that to ground and report the value here.
Dan
Posted on Jul 13, 2010
  • 7 more comments
  • jamesvalenza Jul 13, 2010
    Thanks for your input. I have a very rudimentry meter so measurements are approximate. There are 4 transistirs and there is no center pin - the 2 pins are base and emitter; the case is the collector; measurements are transistor# then Base, Emitter, Collector -
    #1: 0 0 45
    #2: -40 -40 -25
    #3: -40 -40 0
    #4 0 0 45
    Thanks again and standing by . . . Jim
    #1: 0 0 45
    #2: -40 -40 -25
    #3: -40 -40 0
    #4 0 0 45
    #1: 0 0 45 #2: -40 -40 -25 #3: -40 -40 0 #4 0 0 45
    #1: 0, 0, 45 #2: -40 -40 -25 #3: -40 -40 0 #4 0 0 45
    Thanks for your input. I have a very rudimentry meter so measurements are approximate. There are 4 transistirs and there is no center pin - the 2 pins are base and emitter; the case is the collector; measurements are transistor# then Base, Emitter, Collector -#1: 0, 0, 45 #2: -40 -40 -25 #3: -40 -40 0 #4 0 0 45
    Thanks for your input. I have a very rudimentry meter so measurements are approximate. There are 4 transistirs and there is no center pin - the 2 pins are base and emitter; the case is the collector; measurements are transistor# then Base, Emitter, Collector -#1: 0, 0, 45 #2: -40 -40 -25 #3: -40 -40 0 #4 0 0 45 Thanks again and standing by . . . Jim
  • ABRsvcs Jul 13, 2010
    The voltages are wrong. You are missing a voltage somewhere. If the outputs are not shorted, then you should see either a 0.6 or 1.2V reading on one of the legs (plus or minus). Given the readings you posted, there is a supply problem in the driver area or bias circuit. I don't have the schematic for this model handy, so I can't give you specifics, but there is a problem between the preamp section and the final stage. Lift the center pin of the output transistors and look in the driver circuit for open resistors or open transistors.
    Dan
  • jamesvalenza Jul 18, 2010
    Dan,
    there is a protection circuit governed by a 4-pole relay. I cheked measurements hre and only fqund input power - nothing on the output(s). I found one of these on line and am takeing a flyer that this is the source. Your prognosis about a supply problem kind of points here, also in the past another volume freak (while house sitting) also overdrove this amp and my recollection is the relay was replaced. I have very limited knowledge and tools for this kind of work but trial had error can sometin=mes get me through. I'll let you lnow the outcome.
    Jim
I have a Pioneer VSX-520 receiver and was told I need a pre-amp to hook up my record player.I purchased a technics integrated power amplifier from a flea market and was wondering if it is compatible with...
IF the unidentified new Technics Integrated Amp has a PHONO section it will support the turntable.
IF the unidentified new Technics Integrated Amp has, say, a Tape Output, that could feed any Line Level input on the Pioneer. OUT to IN.
Aug 07, 2011 | Pioneer Audio Players & Recorders
My Pioneer SX-780 Receiver has very low volume and distorted. Are the output IC Amps bad? They use (2) STK-0050
A little more triage would be in order before you take a knife to it. What source(s) produce the distorted sound? How about test tones? Same? It's sick. Not same? Something else is going on. Have you referred to the manual(s)?
Apr 07, 2011 | Pioneer VSX-D457 Receiver
My DJM 400 one of the outputs is louder and has distorted sound what do I do?
First verify that one channel is bad by swapping the output leads and seeing the bad audio comes from the other speaker. Assuming it does, you probably have a bad output driver on one side.
This can happen if one powers part of the system from different receptacles in a venue and electrical disturbances destroy one or more audio interconnects. ALWAYS power ALL interconnected equipment from the same source, even if you have to run an extension cord between power amps and the mixer.
You will probably need to take the unit for repair. The parts cost should be nominal, however labor could cost a bit.
Find out is SAME distortion is present in the headphone output. The circuitry shows a bunch of muting transistors and one of them could be bad... but we can do some troubleshooting externally with testing at headphone jack, etc.
Oct 14, 2010 | Pioneer DJm 400 Professional DJ Mixer
Does the PD957 have a speaker output or only a line output for an attached amplifier.
its a cd deck only,but,it does have a headphone output..optical and analog outputs to the amp
Jun 17, 2010 | Pioneer PD-F957 101-Disc CD Changer
I have a pioneer gm-x 304 amp. I want to know what are the lpf-off-hpf switches for< and what sdhould I set the input levels to?
Hello packs6,
The lpf-off-hpf switches control the "low pass" and "high pass" filters. When driving full-range or component speakers the filters are usually operated in the "off" position to send all frequencies to the speakers. When driving a subwoofer, the best position is "lpf". If you have a separate amp to power a subwoofer, this amp can be used just for the high frequencies by putting the switches in "hpf".
Input levels should be adjusted to match your receiver output. You don't want the levels so high that distortion results. But you want it high enough for the amp to be able to produce maximum output. Start at about midrange and adjust the receiver volume to a little higher than a comfortable listening level. Adjust the amp gain (level) counterclockwise until you begin to hear the speakers distort. The turn the control slightly clockwise until the distortion disappears. That's the best setting.
Hope this helps.
Sep 02, 2009 | Pioneer Car Audio & Video
I have a Pioneer SA 1050. All the lights come on
check your speaker selector switch to see if its on the correct setting ie; speakers one ( not speakers 2 ) also check your speaker cables by reversing them, ie; put right speaker cable into left channel and vice versa with the left etc? check also to see if your amp is set to headphone output by mistake in which case no sound will come out until you select the speakers instead? good luck.
Jun 24, 2009 | Pioneer Audio Players & Recorders
No Audio when disconnect from external amp and hook to speakers
In a radio like your Pioneer and all similar units there are always a pre-amp circuit that feeds a power amp circuit,In some players there are more than one pre-amp circiuts. It is possible and highly probable that the power amp circuit in your Pioneer is shorted, so you still get some audio output , but very little. I believe this is your problem and I suggest that you bring it to a repair shop for an estimate or replace the unit. Good luck and please rate this answer, Thanks.
Apr 12, 2009 | Pioneer Car Audio & Video
Speakers not playing correct on a Pioneer SX-550
It could be the speaker output or the amp input. If you have a headphone socket on the amp try headphones and hear if it's the same problem.
If it's the amp's power output then this can be repaired. It's a case of unsoldering the blown transistor or integrated amp chip and soldering in a new one. It's not hard but you need to find someone competent.
Apr 28, 2017 | Pioneer Audio Players & Recorders
No sound from speakers?
This is likely to be th output relay having corroded contacts. The headphone output is taken directly from the sepaker output but fed through resistors. The output relay has failed.
Dan
Mar 09, 2009 | Pioneer Audio Players & Recorders
Pioneer A35R 2-Channel Amplifier Logo
376 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
