Worked fine on Wednesday night. Thursday morning would not come on, plugged in or with battery. No lights, no beeps, no noise, no nothing. Simply a dead computer. What happened?
if the system is completely dead,theres a possiblity that the problem is with the power supply or the motherboard itself, try to use another AC adapter and if it still the same,contact manufacturer...
Check the DC Power Jack where the Power Cord Plugs into the laptop.
Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.
try removing the battery and removing the adaptor press and hold down the power button for 5-10 seconds then let got this will power drain your system board noy turn the system on using the battery only without any adaptors to charge or power the system, try turning the system on if the system turnes on leave it turned on for a couple of hours then conenct your sysem adaptor monitor if the battery light and the battery indicator on the lower right of the screen in windows woll indicate that the system is chargin if it is then I believe everything should be fine the blue indicator is for your system if it is blue then your system is turned on and has power if it turned orange and blnking then the battery will be more likely be almost out of juice or may need charging.
the bad news is that most likely, your MB is dead. the good news is that you can try to enter BIOS by hitting DEL or F2 and that way to fix your problem
