Question about Boating
Yamaha Malta 3hp two stroke. engine works fine.
Yamaha Malta 3hp two stroke. engine works fine. problem is in acceleration at some point it won't accelerate - remains the same speed although the engine gives enough power. propeller is ok.
3 Suggested Answers
SOURCE: I have a 1994 Yamaha 40 HP 3 cylinder 2 stroke
all 3 carbs had A  clogged jet totally dis assembled and cleaned the carbs put them back on and the engine runs great I will need to fine tone the needle valves once I put some fresh gas in it.
Thanks John
Posted on Jul 09, 2009
  • 677 Answers
SOURCE: 9.9 Johnson 2 stroke bogs after running about an
Mate.If its running for an hour before you have trouble,it may not be the motor.What is the motor or on????Sailing boat? tender?Fuel delivery is the main thing I would look at.Its a strange problem.Water in the tank?Sorry.Hope this helps
Posted on Oct 24, 2009
Yamaha Fino scooter won`t start when egine hot. WHY???
Could be a variety of things. Vapor lock from a leaky carb. Carb running too rich. Engine overheated. Heck, could even be some weird wiring gremlin. Hard to tell for sure, but a good solid carb clean and reset should help either way...
Oct 02, 2014 | Yamaha Motorcycles
Yamaha Fino scooter won`t start after having been used and engine still hot. Have to wait min. 20 minutes restart is possibe. What`s wrong???
Hi, Anonymous you may have a faulty CDI box-pulse coil-exciter coil or ignition coil for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
ZUMAFORUMS NET View topic Scooter won start when hot
scooter wont start when hot
http://www.49ccscoot.com/manuals/Yamaha_Vino_125_Service_Manual.pdf
OEM parts for Yamaha
http://www.yamaha-motor.com/assets/service/manuals/2008/vino125_lit-11626-21-54_1538.pdf
2006 TTR125L Starts and Idles fine, but cuts out when I accelerate.
CARB / FUEL LINES/FILTER /ADJUST IDLE/JET PISTON RINGS WORN TOO MUCH AIR ETC
Jun 14, 2013 | Motorcycles
Stumbling on acceleration
You may be cruising down the wrong road with the exhaust idea but then you might be right. An exhaust restriction should also cause the engine to run hot. A faulty cat should also set some codes.
If the injectors are dirty, you may have a very lean fuel mix on one or more cylinders under acceleration, which would go away once you are not under load. And injector problems won't set any codes unless an injector stops working completely. Low fuel pressure could cause the same type of issue.
Dec 04, 2012 | Cars & Trucks
2009 yamaha vino 49cc scooter, (4 stroke) when accelerating from stop engine lulls(hesitates) before taking off
Hi, Anonymous and the usual suspects are:
1. Throttle cables misaligned or misrouted.
2. Damaged or restricted fuel tank venting system.
3. Intake system air leak.
4. Vacuum piston malfunction.
5. Pinholes or torn diaphragm.
6. Accelerator pump leaking or no output.
7. Plugged bowl vent or overflow.
8. Fuel level in bowl too low.
9. Restricted fuel supply passages.
10. Plugged jets or passages.
11. Worn or damaged needle or needle jet.
12. The enrichner valve not seated or leaking.
2002 50cc Yamaha Vino Stalling on Acceleration 49ccScoot com Scooter Forums
What is wrong with my scooter
Yamaha YJ50RAP Service Manual
Yamaha VINO YJ50RAP Owner Manual
Nov 27, 2012 | 2009 Yamaha Vino Classic
How do you check the timing and adjust the carb. My problem is every time I try to start my 75 yamaha 400 endro it will kick over but won't run I have spark and it wants to go and sounds like it will...
Hi, is this still on points ignition? The spark should occure between .5 and 1 mm before top dead centre, on some of the older machines the ignition timeing is not addjustable as the backing plate is fixed, however the ignition timeing can be determined by the correct points gap, the points should open at the correct time as the piston reaches the top of the stroke, if you dont have a top dead centre gauge, you could improvise by making some markings on a thin rod which you will insert into the spark plug hole, rotate the engine in the correct direction by hand until the piston is at top dead centre, that is the piston has reached its upermost stroke before it starts to decend, at tdc turn the engine back the required amount untill your markings point out the required amount, it is at this point the points should just sepparate creating a spark, a test light with a small 9volt battery in line will indicate the separation of the points, i would however like to stress the third most important item to make a two stroke run is compression, spark and fuel alone is insufficiant without it, on machines that have been standing for long periods of time the piston rings can become stuck in the piston, not allowing the rings to seal the bore, remove the exhaust and look up the Port the piston should look as new with no scoring to it, any damage will prevent the engine from running, as will worn crankshaft oil seals which can become soft from old fuel contamination
Oct 29, 2011 | 2001 Yamaha SR 400
Actually i dont want any solutions;i just want to know about yamaha rd 350
Model: Yamaha RD 350 Year: 1986 Category: Classic Rating: 76.9 out of 100. Show full rating and compare with other bikes Engine and transmission Displacement: 347.00 ccm (21.17 cubic inches) Engine type: Twin, two-stroke Power: 63.00 HP (46.0 kW)) @ 9000 RPM Top speed: 190.0 km/h (118.1 mph) Compression: 6.0:1 Bore x stroke: 64.0 x 54.0 mm (2.5 x 2.1 inches) Fuel control: Membrane & power valve Cooling system: Liquid Gearbox: 6-speed Transmission type,
final drive:
Chain Chassis, suspension, brakes and wheels Front tyre dimensions: 190/90-18 Rear tyre dimensions: 110/80-18 Front brakes: Dual disc Rear brakes: Single disc Physical measures and capacities Weight incl. oil, gas, etc: 170.0 kg (374.8 pounds) Fuel capacity: 20.00 litres (5.28 gallons) Other specifications Further information Parts and accessories Our partner CMSNL ships low cost OEM motorcycle partsimage-1696787-10826297 to Australia, Austria, Bahamas, Belgium, Canada, China, Croatia, Cyprus, Czech Republic, Denmark, Estonia, Finland, France, Germany, Greece, Hong Kong, Hungary, Iceland, India, Ireland, Italy, Japan, Kuwait, Latvia, Lithuania, Luxembourg, Macedonia, Malta, Montenegro, The Netherlands, New Zealand, Norway, Poland, Portugal, Serbia, Slovakia, Slovenia, South Africa, Spain, Sweden, Switzerland, Taiwan, Ukraine, United Kingdom, The United States and more. Or check out parts and accessories from our other partners.
Dec 29, 2010 | 1986 Yamaha RD 350
How do i re-shim my 07 yamaha yz250f?
you should hav check the valve spec before taking off the head. now you have to reassemble it to check it. see if your over or under adn replace with the appropriate shims.
Oct 22, 2009 | 2004 Yamaha YZ 250 F
Yamaha warrior won't start
If you are getting a nice bright blue spark then no, the last time I had a problem like this it was sugar in my tank. If you taste a bit off your finger and it is the slightest bit sweet, then some one has sugared your tank. If so just flush the tank with a little fresh fuel and then flush the carb, and fuel lines by spinning the engine over for a bit then try to start again.
Is yours an electronic ignition or points. If points gap could be wrong or even timing slipped. That has happened to me also.
Apr 29, 2009 | 2003 Yamaha YZ 125
Yamaha india
hello Sir,
It was the phase between 1990-1995, when Yahama lost to Hero Honda, as v know, Yahama was an expert in 2-stroke engine bikes, as v know 2-stroke engine will yield higher power but NO good mileage, n emit more smoke.
so...GOV OF INDIA phased out all production of 2 stoke engines in the country, so yamaha had to stop the production of Yamaha RX n RD series in INDIA.
N constantly rising fuel prize, utilizing this need form d public Hero Honda's CD 100 hit the market, with 4 stroke engine n heavily improved mileage.
hence Hero honda won the race...
Although Yamaha came up with some 4 stroke models, but those didnt click it for them, but now its again yamaha's time !!
with introuduction of Yamaha R15, FZR , really yamaha is back with a bang !!
thank u so much..!!
plz vote me/ rate me ..thank u!!
May 22, 2008 | Yamaha RX-V520
Boating Logo
359 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
