Question about Garden
Lawnmower not cutting grass properly or picking up cut grass
3 Suggested Answers
  • 512 Answers
SOURCE: Cut grass clippings does not get picked up by riding lawnmower
When using a bagger, you need correct blades on mower or Worn blades will cause the deck not to get the vacuum needed for the bagger to pickup.
Posted on Aug 22, 2009
  • 623 Answers
SOURCE: Is it safe to cut wet or damp grass with this elec...
Yes, the electrics are well sealed from the wet grass, although wet grass may clog the mower or slow performance.
Posted on May 24, 2010
Why won't my toro model 71225 15 horse hXL m554201196. Will not pick leaves
I do not pick up leaves. I just keep mowing over them until they are very small pieces. Over the winter they decompose and fertilize the lawn.
Nov 06, 2015 | Toro Garden
Why does a riding lawnmower cut unevenly
Sounds like your cutting blade is crooked, loose, or bent. Take it to your nearest small engine repair shop.
Sep 05, 2014 | Garden
Lawnmower problems
if you let grass grow to long will be to heavy to be picked up and go into bag
Aug 13, 2014 | Garden
I have a florabest electric lawnmower, the blades are turning and were sharpened recently but it is not cutting the grass...any ideas?
check that the blades were put on correctly and the sharp side is in the right position . if not then the blades are trying to cut the grass on the back side un sharpened side.
Jun 02, 2013 | Garden
My 21: self propelled yardworks lawnmower leaves a strip of grass about one thiird from the left hand side of the mower when i mulch with it. When I bag it works good.
I'd check your blade and see if it needs sharpening. The mulching mowers need to cut then vacuum the grass up and then cut it again. They must be properly sharpened for this process to work properly.
James
Aug 26, 2011 | Garden
My 24 volt lawn mower is all of a sudden not working, it is just over 2 years old. You can hear it but the noise it was giving off is missing?? It doesn not have the same sound. The blade is turning, I...
If the blade is turning it should cut grass. Try mowing. If it's not cutting the grass then the blade is not turning, or is no longer turning at the proper speed. Look for a fuse or circuit breaker.But after 2 years the battery may have a problem. Try the manufacturers website for help: http://www.blackanddecker.com/en-us/support
Sep 24, 2017 | Black & Decker Black Decker Cordless 24...
Is it safe to cut wet or damp grass with this electric lawnmower? Does it have rcd?
May 20, 2010 | Garden
Aug 22, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Swisher lawnmower wont mow
Yes It would. The belt doesn't just wear it slackens also. It will probably turn the blades when not under load but as soon at it attempts to cut grass there is not enough grip.
Replace the belts first and it should be fine.
Regards
Marc
Apr 17, 2009 | Swisher 60" 13 Hp Trailmower #T1360h
Cannot cut lawn
Go to the attic. Find the lawnmower and tap the button on the lawnmower with your stylus and slide it right to pull the starter. It takes practice.
Oct 25, 2008 | Ubi Soft Entertainment Imagine: Babyz for...
Garden Logo
331 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
