Question about Astar LTV-32BG 32 in. LCD HDTV
No power to my tv LTV32bg can u help - Astar LTV-32BG 32 in. LCD HDTV
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From what you have described it seems to be an issue with the power supply board which is the board where all the power cords plugs into. If that is fine then check the main board, a component on any of these boards might have gone bad and needs to be replaced. If it was working fine earlier then don’t think that the issue is with the LCD Panel and/or inverter board. To start with you’ll need to open the back of the unit and check/test the components and replace the one that has gone bad. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 12, 2010
  • asapcraftsme Jul 13, 2010
    It was the on/off switch that was defective you should allways try the easyist way frist thanks for the help
    Eric
  • Rylee Smith
    Rylee Smith Jul 13, 2010
    Good to know that the issue has been resolved.
Old GE 27GT615 TV won't power on
Could be an open internal fuse or power supply failure
Dec 19, 2017 | GE Televison & Video
Plasma TV
did you hear the sounds? or maybe you have defective power source in hot side..
Oct 02, 2007 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Looking for a power supply for a NEC PX-42XRA4 plasma tv?
Paul, Check the attached links, not much on this power supply.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
NEC TV Power Supply Board
NEC Plasma TV Repair Part Number Guide for NEC Hitachi Fujitsu Plasma...
Repair KIT Capacitors FOR NEC Plasma TV P506Y1 FOR Power Supply Ypsu J011A...
REPAIR SERVICE FOR POWER SUPPLY BOARD OF NEC 50XP10 50 PLASMA TV
Mar 08, 2016 | NEC Televison & Video
TV will not power on. Red light flickers sometimes when I try to turn it on.
TV Will Not Turn On - Troubleshooting Help for Finding ...
? 2:32
https://www.youtube.com/watch?v=kEDVc-BXf0I
May 1, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV that Will Not Turn On - Troubleshooting Tips for finding symptoms and causes of ...
SONY ' eSupport - The TV will not turn on or does not have ...
https://us.en.kb.sony.com/.../the-tv-will-not-turn-on-or-does-not-have-an...
Aug 15, 2015 - The TV may not turn on if there is a power issue. Often power issues are caused by a drop in voltage in an electrical power. The power outage ...
TV has power but will not turn on - Page 2 - Community ...
community.insigniaproducts.com/t5/.../TV...power...will-not-turn-on/td...
Feb 1, 2015 - Our tv has power to it but will not turn on. The red light in the corner is lit but when we try using the remote or the power switch on the unit.
32" LCD Flat screen TV, no power, can someone help save it ...
budgetlightforum.com > Forums > Miscellaneous > Off-topic Chatter
Feb 2, 2012 - 20 posts - ‎10 authors
The tv will not power on manually or with the remote, there's no clicking noise, no LED light on the front, no signs of life. There is no obvious ...
TV Will Not Power On
Jan 26, 2016 | Televison & Video
TV does not turn on. Power on light code is 2 long and 5 short flashes. I replaced the power board, main board and the T-con board and the problem still Exsist.
Jan 19, 2016 | Televison & Video
TV WILL NOT TURN ON
      NOTE: If the TV turns on and off using the POWER button on the TVbut does not respond to the POWER button on the remote control, troubleshoot the remote control. Unplug the TV power cord from the electrical outlet for 30 seconds. Plug the power cord into a known working electrical wall outlet.Aug 15, 2015
      The TV will not turn on or does not have any power. - SONY
      https://us.en.kb.sony.com/.../the-tv-will-not-turn-on-or-does-not-have-any-...
    Feedback
    ? 2:32
Jan 14, 2016 | Televison & Video
14 month old samsung 32in 530 series lcd tv will turn on fine, then after a few minutes start turning on and off repeatedly for ever...until i pull the power. What do i do, call samsung?
its possibly dry joints on the power supply-the heat generated causes the solder to crack,and when warm creates a "crater" on the affected joint and expands with heat,and loses contact until cool.(retraction).should be easy if you are handy with a soldering iron!.failing that,take it to a repair shop as its out of warranty,and samsung will not want to know! (unless you got extended warranty,of course!)
good luck,steve
Sep 12, 2011 | Samsung LN32C530 32 in. TV
I need a manual for an Astar LTV32BG. I just acquired the tv without any documentation. Just connecting it to an antenna doesnt seem to acquire signal.
it should be in your settings for what kind of signal the ant is to accept good place to start manuals can be hard to find hope this helps also try hooking another coaxial source to rule out faulty input
Nov 17, 2010 | Astar LTV-3201 32 in. LCD Television
Sony kp-65wv600 projection tv error code. My tv blinks 7 times.
The Standby LED blinks when the TV is turned on, then shuts off when the picture is displayed. If the LED blinks continuously, this may indicate that the TV requires service. Before getting the TV serviced, try power resetting the TV and factory resetting. Try the below steps also: Connect the TV to a different wall outlet and check if it helps. This is to check if the issue is with the Power. Disconnect the TV from the Power Strip or the Surge Protector and connect it directly to the Wall outlet and check if it helps. To Power Reset the TV, disconnect the Power cord for a short period of time (approximately 1 minute). Then, reconnect the Power cord and power ON the TV. To factory reset the TV, turn it ON. Then while holding down the RESET button on the Remote Control, press the Power button on the TV front panel. The TV will turn OFF and then turn ON again. Then release the RESET button to complete the reset procedure. If the issue persists, service may be required.
Good Luck!!
Nov 09, 2010 | Sony KP-65WV600 65" Rear Projection...
RCA 32" SDTV
27V530t......my TV powers off and on all by itself and wont stay powered.Can you help ?
Jul 09, 2008 | RCA 32F531T 32" TV
Astar LTV-32BG 32 in. LCD HDTV Logo
23 people viewed this question
Top Astar Televison & Video Experts
Jaime Hernandez
ted dux
Are you an Astar Televison and Video Expert? Answer questions, earn points and help others
