Question about Makita DCS640120 Commercial Grade 20Inch 64cc 2Stroke Gas Powered Chain Saw
I have a Makita DCS640120 Commercial Grade 20Inch 64cc and when i turn it on the chain automatically moves how do i fix it to where it will idle till i press the trigger?
    Problem Solver:
  • 5 Answers
If clutch springs are not broken turn down idle screw until chain stops spinning
Posted on Apr 25, 2013
    Brigadier General:
  • 4,088 Answers
Turn the idle speed screw CCW till the chain stops turning at idle, but the engine continues to run. Make sure the carburetor fasteners are tight. Remove the chain cover, bar, and chain. Spin the outer drum of the clutch to check the bearing which lies between the drum and internal components. If it doesn't spin freely, try oiling the drum bearing area and work it into the bearing. If no help, plan on replacing the clutch mechanism. Hope some of this helps!
Posted on Jul 13, 2010
Trouble starting chain saw
check for spark and install new spark plug take off air filter check for fuel
Feb 12, 2015 | Makita DCS6421 64cc Chainsaw with 20" Bar...
How to ignition time this?
The ignition timeing on all modern chainsaws is controlled by the flywheel magnets, the flywheel key, and the core of the ignition unit, so other than checking the key has not sheared, and you have the correct air gap between the unit and the flywheel ( 0.3mm ) that is as much as you can do.
Jun 24, 2011 | Makita DCS640120 Commercial Grade 20Inch...
Need the parts brake down for a makita chain saw DCS6401
http://www.makita.com/en-us/Modules/Tools/ToolDetails.aspx?ID=428
Click on the icon that is labeled parts breakdown to the left of the chainsaws picture.
I hope this helps!
Nov 24, 2010 | Makita DCS6401 20 20",64cc Chainsaw 2...
What should the compression be for the makita dcs34?
As far as i am aware it sould be between 60 - 80 PSI, 40 - 60 psi indicates ware any lower than 40 no hope
Sep 07, 2010 | Makita DCS34 Commercial Grade 14Inch 33cc...
Makita DCS6401 wont idle. When the gas is released the chainsaw shuts off.
Try turning the idle speed screw CW (not the jet screw marked L) one full turn to increase speed. Normally, this is set so that the chain stops moving, but the engine continues to run. Hope this helps!
May 13, 2010 | Makita DCS6401 20 20",64cc Chainsaw 2...
Chain fell off
That often creates burrs, this may help with removal, Your OM is excellant for installation, maybe the best I have seen.
http://www.fixya.com/support/r4146814-chainsaw_chain_installation
See pages 19 & 20.
http://www.makita.ca/data/upload/tools/dcs6401%20F-E.pdf
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 08, 2010 | Makita DCS6401 20 20",64cc Chainsaw 2...
How to adjust a mcculloch 610 chainsaw carberator
there are two screws on the card of youy chainsaw one is the slow running jet the other is the full throttle jet start up saw run it till its hot adjust slow running jet first till saw ticks over ok then adjust fast running jet till you have full throttle,, start with both screw turned in to one and a half turns then adjust from there
Mar 28, 2010 | Makita DCS6401 20 20",64cc Chainsaw 2...
We have dcs6400 and this tool is making a huge noise when we start it and also the tool is looked as it gets overheated very soon even on idle running. please suggest the grade of oil to be used along with...
2-cycle oil mixed at 50:1
1 Gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
4 Liters of premium fuel to 80 CCs of quality 2-cycle oil.
Your OM can be found here:
Makita Canada Inc:
Good Luck. HTH
Lou
Feb 23, 2010 | Makita DCS6401 20 20",64cc Chainsaw 2...
Makita DCS640120 Commercial Grade 20Inch 64cc 2Stroke Gas Powered Chain Saw Logo
100 people viewed this question
Top Makita Garden Experts
JOHN LAPIER
Paul Sikkema
Paul Sikkema
Are you a Makita Garden Expert? Answer questions, earn points and help others
