Question about RTO Atwood DSI-RV Water Heater-6 Gallon
We can not locate the switch for the hot water heatr in our 2009 Fleetwood Terra LX Morothome, can we get a manual for this unit?
  • RTO Master
  • 6,674 Answers
Wall by kitchen counter, or end of kitchen counter, near cabinet or counter on same side of motorhome as water heater, as well as a switch on the monitor panel itself. Some hide them on underside of kitchen cabinets as well.
Posted on Jul 14, 2010
Rennai hot water heater very slow to heat up!
I would check the gas pressure at the burner. It should be 3.5 inches water column on the manifold. Hope this helps.
Sep 09, 2014 | Water Heaters
1999 fleetwood prowler 25 5b
You need to visit a local dealer...any RV dealer. They should provide a general walk through as a courtesy. Pay them for a maintenance inspection and they can provide a detailed explanation of their work. After that you might be able to troubleshoot/repair simple problems yourself.
Feb 15, 2014 | Water Heaters
Fleetwood rv
your electric water heater has one or two switches located under a panel or, panels be sure the power is off and open the panel(s) lift up the insulation and you should see a big rectangular black switch with a red button the button is a re-set switch press it then re-apply power
and, see if that fixes it if not you will have to replace the heating elements which is a difficult job
Dec 03, 2013 | Water Heaters
Which is cold water connection on the boiler
Incoming cold water usually connects to nipple marked with C, and/or the nipple that feeds into water filter (if unit has built in filter)
If unit has shut-off valve, then shut off is located on cold line.
If unit is operable, then turn on hot water and see which pipe gets hot ... and then cold is other pipe.
read your product manual.
Search your brand and model on internet to locate product manual.
Otherwise re-post question and include brand and model number so product manual can be located and information can seen first-hand.
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jul 18, 2013 | Water Heaters
Fleetwood rv 2009
Copy following link to identify valve:
http://waterheatertimer.org/Repair-water-heater-valve.html
Add a comment and give more specific information, and add what you have tried so far.
Jul 16, 2013 | Water Heaters
We have a 2006 31 ft fleetwood prowler trailer. We can't find in manual switch for water heater. We see the switch with electric and gas on wall but which symbol is "on" &...
I do not have specific answer.
Open following links to identify product, download service guide and download manual for the different model numbers, plus parts list and other resources:
Page 3-4 of following manual shows switch settings for LP gas.
On-line manual can be word-searched for 'switch.'
This water heater has remote switch, which is the switch you are talking about. It also has limit switch and ECO (energy cut-off switch)
http://waterheatertimer.org/pdf/Atwood-installation-maintenance.pdf
http://waterheatertimer.org/pdf/Atwood-Water-Heater-Service-manual.pdf
http://waterheatertimer.org/Atwood-water-heater-resources.html
Jul 26, 2011 | RTO Atwood Water Heater - 6 Gal LP
Our atwood heater is firing up ok and running for a good while then turning itself off but we dont get any hot water out of the hot taps. Our water pump is working ok but we have this funny tap within the...
Cold goes in bottom fitting of water heater, so that valve has to be open, and hot comes out the top, so that has to be open, if there is one there, but any valve in between needs to be closed. There are a few variations so if you can explain where your valves are located in the system more precisely, I can help better. Perhaps you can send a digital picture with reply?
Nov 11, 2010 | RTO Atwood Water Heater - 6 Gal LP
No hot water from bosch tankless heater
  1. If the display is blank, verify power to electrical outlet. (120VAC/60Hz properly grounded circuit required). Verify that the heater on/off switch is in the on (I) position.
  2. Verify the fuses in the control unit are good.To access fuses, the control unit must be removed. See BULLETIN TWH-G2-24 Two spare fuses are located inside lower access panel of control unit.
  3. Make sure cold water inlet connection is plumbed to the right side of heater when facing unit.
  4. A minimum of 0.8 gallons per minute (GPM) (3 l/m) is required to activate the heater. A quart container should fill in 20 seconds or less to activate heater.
  5. Clean inlet filter screen per chapter 5.2. of the installation manual.
  6. Inspect the water path for obstructions. Make sure all showerheads, faucet aerators and whole house filters are clear of debris.
  7. The heater activates when the water flow through the unit is at or above the required minimum of 0.8 GPM (3 l/m). A crossover creates back pressure on the water flowing through the heater. Therefore, a higher flow rate than normal is needed to force the heater to activate. To check for a plumbing crossover, shut off the cold water supply feed to the water heater. Then open all of the hot water taps served by the heater. Wait 10 minutes and check for water flow at taps. There should be no water flowing. Any continuous flow of water indicates a crossover is present and must be corrected. Consult a professional plumber for help in correcting a crossover. Failing single lever faucets and mixing valves are common causes of plumbing crossovers.
  8. With the ON/OFF switch turned to OFF (O) position and the power supply cord unplugged, remove theunit's front cover (See Page 5. Fig 3 of installation manual). Check wire connections between the water valve, control unit and electrode set. See chapter 9.2 of installation manual for location of these parts.
Feb 14, 2010 | Bosch & Tankless LP Hot Water Heater
Hot Water Heater in 1991 Pace Arrow RV is not working
If you look on the outside of the RV, you will find the vent for the water heater behind and access door. There usually is a drain plug and valve located as well. Generally they will be tucked away under the kitchen sink area with internal access as well. You will need to find where the valve that shuts the water off to the unit is and turn it on. Most times the water heater is either electric or propane. But sometimes they are only propane. Once your find the access door, you will know where the water heater is. You can also contact Fleetwood who makes the Pace Arrow to see if they have any information on your unit. Usually your unit info or trim number will be located on a little plaque right by the entrance to the RV. You will need this when you contact them. Hope this helps.
Mar 31, 2009 | Water Heaters
Crystals Forming On Gas Hot Water Heater
You need a new anode rod in the water heatr. You will probably be looking at a new heater soon.
Feb 15, 2009 | Whirlpool Water Heaters
RTO Atwood DSI-RV Water Heater-6 Gallon Logo
207 people viewed this question
Top RTO Water Heaters Experts
Jim Goldsmith
Jim Goldsmith
Donni Steen
Are you a RTO Water Heater Expert? Answer questions, earn points and help others
