Is special video card required to use Panasonic BT-LH2550 monitor with pc?
    President:
  • 2,571 Answers
Looks like you do need special equipment to use it, here is some info that may help http://discussions.info.apple.com/message.jspa?messageID=10260493
Posted on Jul 12, 2010
AOC CT720G (Black, Silver) 17" CRT Monitor driver
The monitor probably doesn't require any special driver. There are drivers for your motherboard video chip, or if you have a graphics card. If you need to make adjustments to the monitor, the manual is here... http://www.manualslib.com/manual/8152/Aoc-Ct700g.html
Jul 10, 2014 | AOC CT720G (Black, Silver) 17" CRT Monitor
Bt-lh1700we when putting any input format a glitching come over the input source such as many squares in different siizes , what could this problem be ??
The problem is either your graphics card or your monitor. Try a replacement monitor/flat screen tv and if that works, it's your monitor. If that is the same then your graphiocs card may be faulty.
Jan 18, 2013 | Panasonic BT-LH1700W Monitor
Where can i find delium drivers for LM2213 DELUIM??
For the most part monitors don't require drivers. Windows will just add, because the connection is coming from the video card. Unless this is some special sort of monitor (USB?), look for video card drivers instead.
Nov 02, 2012 | Computers & Internet
Hi,i bought an aoc 2243fw2k monitor with dual hdmi ports,n i hav an nvidia geforce 220gt 1gb ddr3,i instaled the drivers n graphic card drivers n kept all the conectins properly,bt i wont get the video in...
http://www.nvidia.com/object/win7-winvista-32bit-285.62-whql-driver.html
this is teh driver you need (windows 7 ) If you need it for windows xp ..you have to select the os first .
Also if you need it for a 64 system select it ..and install it after download.
Use the hdmi for to have a hd image ..and select the correct port in the monitor ..
restart after finish the driver installation .and make the settings
after..Also check the board in device manager to be proper installed (right click on computer icon ..select properties than device manager (for xp select first hardware ) ..and in helist look under display ..and the driver should be present by name and not with yellow color and exclamation or ask sign ..
Also it may need some settings in the video card ..so open the settings for video card in control panel and look up for what should be set ..specially related with the secondary monitor and the hd mode..
Dec 15, 2011 | Computers & Internet
I can not get actual laptop screen to turn on, its says that it is hooked to contected monitor ? what to do
Press the Fn key + the F3 key - FN+F3 to switch to the built in Video card mode, seems the video is set to provide video to an external monitor.
Sep 03, 2011 | IBM THINKPAD L412 I5520M 24G 2GB 160GB...
Need a video card that will allow us to hook up a new wide screen monitor that requires 1080dp. Don't know which video/graphics card will work.
The short answer is no. The belief that widescreen HD monitors require special video cards derives from a combination of two sources. First, most Windows users know that you can change the display resolution by right clicking on the desktop, clicking on settings, and then choosing a resolution from a drop-down menu. What most users do not know is that the choices displayed in that drop down menu are what Windows, the Video Card manufacturer, and the Monitor's manufacturer want you to see. The fact is, most video cards are capable of displaying popular widescreen resolutions such as 1680x1050 dpi and 1920x1080 HD which are 16:10 and 16:9 resolutions.
Feb 15, 2011 | HP Compaq Presario SR1500NX (PX786AA) PC...
I have dowloaded drivers for samsung syncmaster P2050 but still cannot get the resolutions to adjust
Your monitor doesn't require any special drivers to work properly. If your monitor is a widescreen monitor, your video card needs to be able to address the monitor's resolution, not the other way around. You'll need to either update your video card's drivers to obtain different resolutions, or you'll need to replace your video card with a newer one that does widescreen resolutions. Good luck!
Jan 14, 2010 | Samsung P2050 Monitor
Monitor turns off when i play game,usually it goes off after a few minutes or it simple freezes my pc,bt i've got a 256mb graphics card and a gig RAM!
256mb its quite poor for a graphics card so it may be that your graphics card does not meet the games requirements did you check that they matched? can you tell me the specific model of your card and the game your trying to play and if you can find it the system requirements for the game they should be on the box or in the manual that came with it
Aug 21, 2009 | MSI K8MM-V (MS7142-010) Socket 754 Micro...
Dual monitors
You'll need a dual-monitor video card in your computer. The GVLM1928 is basically two monitors on a shared stand. Each side of the monitor has a separate video connection.
Feb 26, 2008 | Computers & Internet
Tv/pc
Your Panasonic TC-26LX20 26 will only allow video inputs through the:
1. composite video/audio input ( RCA phono x 3 ) - front or rear
2. S-Video input ( 4 pin mini-DIN ) - front or rear
3. component video input ( RCA phono x 3 ) - rear
4. HDMI ( 19 pin HDMI Type A ) - rear
Depending on the output(s) available from your PC, you can use any of the following:
a. the yellow RCA female
b. S-Video output ( 4 pin mini-DIN )
c. VGA (which normally goes to the monitor) but would require a VGA/HD to HDMI Format Converter such as the one here
Should this be not enough information, please post back with what PC brand/model that you have. Additionally please specify what Video Card are you using if your PC is a desktop.
Good luck and kind regards.
Nov 17, 2007 | Panasonic TC-26LX20 26 in. HD-Ready LCD...
Computers & Internet Logo
20 people viewed this question
Alun Cox
David Payne
David Payne
