Question about Whirlpool Duet GHW9150P Front Load Washer
My front load washer has some water in it most mornings
My front load washer has some water in it most but not every morning?
  • 5,911 Answers
This problem is commonly attributed to a water inlet valve leaking by or a pressure switch malfunction. The following link explains how to diagnose the problem:
http://www.fixya.com/support/r3753262-front_load_washer_fills_when_not_in_use
If you live in an area that has hard water, or if you use well water, the water inlet valve can clog with sediment, rust, or calcified deposits over time causing the valve not to close properly. This can cause leak by when not in use.
The pressure switch has a small air hose attached that, if it has any holes in it, will cause the pressure switch to malfunction. This can also result in a washer that fills when not in use, but will also cause the washer to overfill in most cases.
Read through the link provided and let me know if you need further assistance. I have included parts resources and procedures on how to replace each part in the link. If you have any questions, please post back and let me know. I hope you find this information helpful.
Posted on Jul 12, 2010
Water is in the washer the next morning
The inlet solenoid valve is dirty and doesn't shut off completely so there is a tiny leak over time. Generally this will get worse over time. You can simply turn off the water at the tap after each use or replace the solenoid, pretty cheap part. Some solenoids can be opened and clean the grit out.
Jul 09, 2013 | Kenmore HE2 Plus Front Load Washer
Sometimes the next morning after I have washed a load of clothes that evening, even though at night there is no water in the bottom of the machine, the next morning there is a small puddle in the bottom. ...
i think the drainage of your washing machine, is not functioning well,or it has a leak, that's why some water remain in the bottom of your machine..
check this one..
http://www.washingmachineadvisor.com/
Feb 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
About 1-2 times a month, my front loading washer fills up with water (sometimes a little and sometimes about half full) without being turned on ... any ideas?
Leaking water inlet valve. Turn hot water valve off one night n see wether any water in drum in morning. Then try turning cold valve off at hose as well to see which one is letting the water in. Either way its only a $5 dollar bit thats passing water
Nov 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore HE3 Front Load Washer - Leaking Water into wash tub
THE WATER VALVE IN THE WASHER HAS TO BE REPLACED THE COST OF THE WATER VALVE IS ABOUT $25.00
Dec 14, 2008 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet Front end Washer
you have a bad water inlet valve. its not seating properly allowing water to trickle in when not in use. youll need to replae the water valve. in mean time turn water off between uses.
Mar 15, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
35 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
