Question about Toshiba Satellite A135-S2276 Notebook
I was trying to hook up the vga or s video to my tv but the tv is still saying no signal how to i change the setting on the laptop so it will show on my tv
    President:
  • 2,571 Answers
This guide shows you how to do it
http://www.think.org/conference/setup_laptop.html
Posted on Jul 12, 2010
I have a sony trinitron and trying to hook up to a dell laptop latitude to watch nexflick.I have a 7 pin s vedio cable to 3 rca.what is the problem that the picture not showing up?
Did you Press the FN (Function Key) + F8 keys on the laptop to display the video on the Sony? Press the FN Key and hold it while you press the F8 Key, this toggles the video into 3 different modes each time you press the keys. The modes are display on laptop only, display on laptop & TV or display on TV only. Also Make sure you have changed the TV's Input Source so that it can know to receive a signal from the laptop. On my setup I go S-Video to S-Video because my tv and laptop have S-video, therefore I tell the TV that the input is S-Video. I installed a VGA to VGA at an Event Center because both the TV and Laptop were using VGA, so I set the Input on the TV to PC since it did not have a VGA Option.
Mar 16, 2012 | Dell Computers & Internet
I have a Sharp LCD TV and a Toshiba Satelite laptop. I have never had any problems connecting my laptop to the tv using a vga cable. It isn't working anymore however. I checked the cables and...
I would check the video setting on your laptop. The resolution or refresh rate might have been changed and the LCD TV might not be able to process the signal. Try changing the laptop's resolution to the lowest setting(right-click on desktop and pick properties) and see if the TV produces a picture. Also verify the video output on the laptop is working by hooking it up to a computer monitor if available.
Jan 09, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
I am trying to hook up my tv with a vga to av(rca) cable,but I can't get it to work.What do I have to do to get it to work?
If your notebook has RCA composite video out, you need to hook it up to TV composite video input jack, usually the color of this RCA jack will be yellow. Why do you not use the VGA port on the back of the note book to feed the signal into the TV's VGA connector, just mke sure to set the resolution of the laptop to be at TV native resolution.
Sep 26, 2009 | Toshiba Satellite A105-S4334 Notebook
VGA connection just reads "no signal" Brand new TV and VGA cable.
i have a 26" insignia lcd tv that i use as a montor uou musr set the screen resolution on your computer to 1024x768. if you use a higher resolution it will say no signal.so use your montor to set the resolution to 1024x768 then hook it to the vga and it should work. bob griggs
Jun 15, 2009 | Insignia LCDTV26 26 in. Television
No images from laptop to pc hook-up
you need to change the tv to pc and you have to go to display properties and under settings click on the little monitor with the 2 on it and check one of the boxes that say use this device as my primary monitor or extend my windows desktop onto this monitor. try that
May 07, 2009 | Dell Inspiron B130 Notebook
Why won't my tv display my computer screen
Hi. The best way to hook your computers display to your LCD screen will be to use the VGA input socket. If your video card can support both S-video input and VGA, you can use either one but, the VGA is best for optimal resolution. This is the easy way to do this. Step one, connect the VGA cable to the computers video card and then, run the other end of this same cable to the VGA input slot on the LCD screen.Step 2, next you will make sure that the LCD's input selection is selected to show what is being transferred from the CPU video card by using the input button on the lcd remote control. The lcd(your tv) should be on VGA or PC input signal. Step 3, now, you Will have to also make sure that your video card is set to transfer this signal as well by pulling up your video cards software window and switch to the proper options. once this is done, you should get a signal. Be sure to use the VGA input/output ports on both the lcd television and your cpu for optimal transfer of the video stream. Here is a pic of your back panel. use the input port labeled I for good PC input quality.
Mar 24, 2009 | Proscan 32LB30QD 32 in. LCD TV
Hook up laptop to computer
Your computer may be running at a higher resolution than is supported by your TV. Lower your laptop's resolution to 800x600 and try again. If it works, you may be able to raise the resolution higher, perhaps 1024x768.
To change the laptop's resolution, go to the desktop and right click and select "Properties". Select the "settings" tab. You will see a box labeled "Screen Resolution", slide the slider to the left as far as possible. Then, plug in the laptop to the TV and select the appropriate input from the TV.
Hope this helps.
Jan 03, 2009 | Dell Latitude D600 Notebook
Connect LG 42LY95 LCD to Toshiba Laptop
Hiran
can you use the vga source from your laptop to the pc input on the LG a standard vga monitor cable will do then set your laptop to output the vga signal
Scott
Mar 22, 2008 | Televison & Video
Vga to tv, to show presatations
you need to have VGA WITH TV-OUT!!!
Oct 29, 2007 | Compaq Presario Notebook
Toshiba Satellite A135-S2276 Notebook Logo
42 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
