Question about Logitech X-530 Computer Speakers
I have all speakers hooked up but i only hear sound out of the left and right frond speakers. The center and both right and left rear speakers i hear no sound
  • 40 Answers
You`ve connected only the green jack from the system,you need to connect all the tree of them using the adapter you got in the package
Posted on Dec 24, 2010
Front speakers 5.1
Turn up the volume on the left or right speakers or turn down the center channel volume to meet your preferences. There should be a setting for that in most receivers.
Jan 17, 2014 | Pioneer VSX-454 Receiver
I have connected by Bose accoustimass 10 series speakers to Yamaha amp and not getting any sound from from front left and right speakers.Checked the spreakers by swapping and they are in working...
hi,
First off all you have to check the frond L/R out put of your Yamaha AVR. One more thing is check the is the speaker A/B option. you can see the selection button on the frond panel of your receiver. If the out put of the AVR is ok then you have to check the Network circuit inside the acoustimass sub. You have to remove the back panel of sub. There you can see a network circuit board. first of all you have to check the 5 lamps at its input stage. It is used as a protection for the speakers. check the continuity of the five lamps. If any one found open then you have to replace the same. Have added the picture of that network. you can see the five lamps in the left side.Also check the fusible resistors in the board. its value will be written on its top.
ok
Jul 19, 2011 | Yamaha HTR-5930 Receiver
In dolby digital mode i can not get any voice volume. All other sounds are ok
Assuming that you mean Dolby digital 5.1, confirm that you have a center channel properly connected and perform the following;
Using the remote, enter the menu on the receiver and navigate to the selection labeled "LEVEL." Toggle through the selections until you reach the "CENTER CHANNEL". You will be able to use the remote to increase the volume of that channel in .5dB increments.
Feb 01, 2011 | Denon AVR-589 Receiver
Yamaha 5560 no sound from front left and right speakers. There is sound from center and back surround speakers.
hi,
just check by fault switched of the frond speakers. power on the receiver play some thing listen sound is coming from the other speaker except frond. press the speaker A button in frond of the receiver. listen is it become on. if not got to the menu of ur receiver surf for speaker configuration . find out the whether the frond speaker is off. if it off turn it on.
Dec 15, 2010 | Yamaha HTR-5560 Receiver
I have a Denon AVR587 running in 7.1. I have an unusual problem as the rear channels seem to play all sounds at a higher pitch and lower volume than all the other speakers on the system. I am using a voice...
Hey ajn1n1 we need to fine where the tinnyness is coming from Lets do a test shall we,
hook up your voice matched polks to your front left and right speaker outputs on your amp to see how they sound as mains. if you hear tinny then its the speakers. sometimes speaker need to be broken in a bit.
hook up your main front left and right speakers to your rear outputs. if you hear the tinnyness then its the output of that channel on the amp or a setting. Newer amps let you change speaker sizes in the menu so that it can change over the crossover for that channel.
Dec 11, 2009 | Denon AVR-587
I don't have any instructions so i don't know how to hook up my speakers and the t.v for surround sound i have a carver avr 100
You should be able to online to the manufacturer of your products and download manuals. However, I will try to help.
Connect the sound output cables from your DVD player including, left/right(white/red) as well as the Coax output/input if your DVD and your Carver each have this feature for enhanced sound on certain DVDs, and connect to the matching DVD inputs on your Carver.
Then, connect your DVD video output either by use of your RGB(RED/GREEN/BLUE cables or an S Video cable to your the matching video inputs on your t.v.
On the back of your Carver, you will find outputs for left and right speakers, connect to the left and right speakers with proper wire. Make sure that the 2 conductor wire is connected with the same side(polarity) on all speakers for the best sound quality.
You will also find rear channel left and right outputs on your amp, connect those to your rear right and left speakers.
Connect the center channel speaker to the center channel speaker output on your amp.
If your Amp has a sub-woofer output and you have a subwoofer, make the connections on that as well.
Test all of the speakers with a feature that many amps have on the menu using your remote, simply called test. if all speakers are connected correctly you will be able to hear each one as they are individually tested by the amp. Hope this helps out.
Oct 05, 2009 | Audio Players & Recorders
DVD plays partial sound
Check your speaker connections it sounds like you have a 5.1 or higher sound system. 5.1 means left front speaker, right front speaker, center speaker, right rear speaker, left rear speaker and subwoofer.
Voices in movies all get channeled to the center speaker (you can usually hear it a bit from the right and left front speakers as well). If your center speaker is disconnected or not working, you will only hear the background sounds.
Sep 20, 2008 | Compaq Presario 5000 PC Desktop
Audio receiver!
When I watch movies, most of the talking is directed to the center speaker. During surround sound, this gives a more realistic environment, with voices coming from the source (center where your tv is) and ambeint noise coming from the left/right corners.
Get a small center speaker to solve your problem.
Jul 20, 2008 | KLH R7000 Receiver
Back speaker sound
Why would you only hook up one speaker for the rear channel? in 7 channel stereo, all speakers have 100% signal sent to them as "stereo" in Dolby digital, rear speakers are for "effects" not dialog. like a plane flying past you or a car driving by, that's when you hear a rear speaker. It also needs to be placed behind you, not next to you or in front of you. Unless you are using zone 2 & 3 the receiver's surround back will work. if you only have left,right,center,sub & rear; the rear speakers should go to surround speakers not surround back. If you still have questions, post a comment and I can explain further. Hope this helps
Feb 04, 2008 | Yamaha RX-V2600 Receiver
Surround Sound Center Speaker/Sound Card issue
You need to use a digital interface cable between the sound card and the speakers to get all of the 6 channels to work properly.
Sep 24, 2006 | Inland 58019 ThunderSound 5.1 PCI Sound...
Logitech X-530 Computer Speakers Logo
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
