Question about RELIANCE ELECTRIC WATER HEATER
Kicks off on high side temperature
Why does the Reliance 606 shut off on high side temperature?
  • Reliance Master
  • 43,501 Answers
one of the thermostats has gone bad and it causes the reset to kick...
Check out this tip and also the other links to tips at the bottom of this one...
Electric Hot Water Heater Temperature Adjustment
http://www.fixya.com/support/r4656190-electric_hot_water_heater_temperature
heatman101
Posted on Jul 16, 2010
Hot water tank wont heat water, how do you relight or resat, its a reliance self cleaning 808
Reliance Water Heater Literature ' Owner's Manuals ...
www.reliancewaterheaters.com/resources/instruction-manuals
Welcome to the Reliance Water Heaters Owner's Manual and Installation ... 9 40 EKRT - 40 Gallon Tall Self-Cleaning Electric Water Heater - 9 Year Warranty . ..... 10 50 DHPST - 50 Gallon Electric Heat Pump Water Heater - 10 Year Warranty .
How to light the pilot on a Reliance 606 water heater ...
? 3:27
https://www.youtube.com/watch?v=VU2PsFVd2ug
Jul 12, 2011 - Uploaded by kilroywashere123
How to light the pilot on a Reliance 606 water heater ... How to fixwater heater, will not stay lit - sealed combustion no hot water - Duration: ...
Reliance Water Heaters - Consumer Affairs
www.consumeraffairs.com > Homeowners > Bath & Plumbing
Rating: 1.6 - ‎84 votes
I purchased a Reliance 606 water heater in 2010. ... That they don't TELL you there's areset button or that I'm having conspiracy thoughts ... After several attempts, I was able to relight it. ... It's heading to the junk pile and I will purchase a new reliable (NotReliance) ... Checked breaker and changed breaker still no hot water!
Dec 28, 2015 | Reliance Water Heaters
How to change thermocouple on model 640YORT
I believe that is a Reliance 606, ehow has instructions on how to change the thermocouple.
http://www.ehow.com/how_6579030_change-reliance-606-thermocouple.html
Aug 24, 2014 | Water Heaters
I have the Reliance 606 and my water has been extremely hot - do I need to change both of the heating elements in it
Are you aware of how to adjust thermostat(s) on water heater? Be sure to shut off power (circuit breaker(s) to water heater prior. Should be behind covers on tank. Both should have screw in center to allow you to back down temperature. Should have an arrow indicating current temperature setting, simply move it slightly toward lower temperature (usually counterclockwise, but just double check ) and try it, until desired temperature is reached.
Nov 30, 2010 | RELIANCE ELECTRIC WATER HEATER
I NEED DIRECTIONS ON HOW TO DRAIN A RELIANCE 606 30 GALLON GAS WATER HEATER
Here is the link for the users manuals for the RELIANCE 606 30 GALLON GAS WATER HEATER, depending on the style you have - tall, short, etc.
http://www.reliancewaterheaters.com/lit/om/g606.html
Oct 02, 2010 | Water Heaters
Model #606 640nort Reliance 30gal gas water heater
this is either the thermocouple lead or the uni control i would replace the thermocouple leed first, these parts can't be repaired they have to be replaced
Jul 13, 2010 | Reliance & 30 Gal LP Gas Water Heater
Pilot won't stay lit in Reliance 606 gas water heater
The Reliance 606 has an enclosed thermal couple. Before you try taking that assembly apart take a wire brush to the bottom opening directly under the burner. There is a metal filter on the very bottom of the water heater. It could be that the filter has gotten filled with dust or animal hair. It took a serviceman 2 days to figure this out for me. The water heater has to have good airflow through that filter to work well.
Feb 13, 2010 | Reliance & 50gal Electric Water Heater
Our 606 reliance electric hot water heater has the letters a b c for the temp control not 120-160 degrees. On what letter a-b or c should the temp be set on to get 120 degrees
We will just assume that "a" is the lowest temperature
to correspond to 120 degrees, while "c" for 160 degrees.
So try setting it at "a" and feel the hot water that flow.
Or it could be the other way. Just feel the hot water that
flow. It will be done in a few minutes. I hope this will help
you.
Nov 26, 2009 | RELIANCE ELECTRIC WATER HEATER
RELIANCE ELECTRIC WATER HEATER Logo
260 people viewed this question
Top Reliance Water Heaters Experts
Mack Baxter
Gil Shultz
Paul Nielson
Paul Nielson
Are you a Reliance Water Heater Expert? Answer questions, earn points and help others
