Question about Dell 1600n All-In-One Laser Printer
It doesn't scan at all. I installed several scan sofwares but all those softwares don't reconize this printer scanner. It prints fine though
  • 1,511 Answers
Hello and Welcome to FixYa!
Here is the link from where you can download the driver/applications of the quoted model of printer. ( From manufacturer Website)
Click here for the link.
Select your operating system from the list and download the driver/management pack from there... Install those driver/management application and then check for the working...
If still the problem persists, I would recommend you to download the firmware from the quoted link and update your device firmware.... This will definitely help you out (if there is no hardware problem in the scanner).
Best of Luck,
Please do RATE the solution, if found helpful,
Concerned.
Posted on Jul 12, 2010
Scanner not found on computer
Try un-installing your 8500 related software, re-boot and re-install from disk.
If you don't have the installation disk go to:-
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3752459&lc=en&cc=uk&dlc=en&lang=en&cc=uk
and start by entering your operating system details
Nov 21, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
HOW DO I MAKE A COPY FROM A COPY ON MY HP 2420
You cannot make a copy if you are thinking of it like a photocopier. It doesn't have a scanner built into it .
If this is what you are thinking there are several quite excellent scanners out there fairly cheap. The scanner will come with software that will make it and the printer behave like a photocopier. The scanner we use at home even has a button that we just press to scan and print a copy as well as software that gives more options.
If you want to just print multiple copies of the page then this you can do. You just have to go to print options on a program menu and tell it to print the page how many times you need. You can also change the number on the printer driver but if you don;t set it back after everything after is going to print a few extra copies.
Sep 13, 2011 | HP LaserJet 2420 Printer
Scanner says sorry an unknown error occured The scanner seems to reconize it is connected to the computer, but it will not complete the scan
You don´t give enough information in order to allow us to help you (How are you trying to scan? What exactly happens? What OS is installed in your computer? Which software/driver did you install? Does your printer otherwise works?)
Start by reading these HP FAQs to see if you can solve the problem (2 are meant for Vista systems and one for XP). Post again if you still can't scan.
Sep 02, 2009 | HP Photosmart C4280 All-in-One InkJet...
My printer doesn`t react
Hi there, " Unplug the printer cable from the computer. " Unistall the printer drivers from Device manager and also unistall the all the printer appications " restart the computer " try to download drivers from the website " after installing drivers and software it will ask you to connect the printer. " then you can connect the printer and and try to Print the test page.
Scanner: Hi there, " Unplug the Scanner cable from the computer. " Unistall the Scanner drivers from Device manager and also unistall the all the Scanner appications " restart the computer " try to download drivers from the website " after installing drivers and software it will ask you to connect the Scanner. " then you can connect the Scanner and and try to Scan.
Aug 19, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Printer and copier work fine- scanner says USB not connected.
I had this same problem and it is fixable, but not the way you would probably like, though you can still scan with the printer. You just have to open the Paint program and click from scanner or camera, and then choose your printer and click scan preview, and then scan, it works just fine but its a little time consuming.
Jun 01, 2009 | HP Photosmart C4280 All-in-One InkJet...
Can't install printer
Hello you can go here and download your driver. choose OS and then choose HP Photosmart Software and Drivers: USB Support you can also just download HP Print and Scan Drivers: USB Support to get print and scan function without other softwares.
Dec 16, 2008 | HP DeskJet F380 All-In-One Printer
Lexmark 1270 scans but will not print
With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
To fix a fouled install :
(1) Uninstall the Lexmark drivers in Add Remove Programs
(2) Shutdown the computer
(3) Disconnect the printer from the USB port
(4) Restart the computer
(5) Run the Driver Installation software
(6) Cancel ALL attempts by windows to auto install the printer
(7) When the sofware asks for the printer connect it and continue
Dec 13, 2008 | Lexmark X1270 All-In-One InkJet Printer
All in One Scanner/Printer problems
Go to this link and type "cannot communicate with scanner" in the search box. Click Search. Then select the "ERROR: Cannot communicate with scanner" link. You will see several things to try to correct your problem. Usually, this error shows up if there is another USB device connected which prevents the computer from "seeing" the scanner, even though it can print without problem. So do try to disconnect any other USB device (except mouse or keyboard) and reboot the system.
May 20, 2008 | Canon PIXMA MP160 All-In-One InkJet...
HP OFFICEJET J5740
you probably don,t have the correct or all of the drivers installed.
The second possibility, is the software scanning program.
You could try 1 called paperport.
Hope this helps Mike@Compurepair.
Feb 20, 2008 | Office Equipment & Supplies
Hp deskjet f4180 all in one
i have a hp deskjet f4185 all in one printer but i lost the cd. i need the sofware or it will not connect to print or scan please help me where can i get the sofware?
Feb 15, 2008 | HP Deskjet F4180 All-in-One InkJet Printer
Dell 1600n All-In-One Laser Printer Logo
46 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
