Question about Boating
Replace exhaust maifold gasket on 2.0 liter, 140
How do I replace exhaust maifold gasket on 2.0 liter, 140 hp GM mercruiser boat motor?
  • 252 Answers
Hi
Locate the exhaust manifold, there will be 8 bolts attaching it to the engine block. Remove these bolts, they may need penetrating fluid to loosen them. Slide the manifold off the exhaust studs.
Remove the gaskets, scrub where they have been with a wire brush and refit new ones. Use some gasket sealant to affix them and replace the manifold. Start at the middle studs and work outwards in a criss-cross formation.
Torque up the studs to the correct settings (check the manual) and don't overdo it as you could crack the cylinder head (been there done that).
Start the motor and check for any leaks around the manifold, if so, check gaskets again for a good seal then try again.
Hope this helps and please vote for me :)
Posted on Jul 13, 2010
Test power trim motor on 1988 mercruiser on invader boat
the motor gets wet and goes out try running a hot to hot side of motor and ground if it works its your wiring if not its the motor
Feb 13, 2015 | Boating
My 1985 4-winns mercruiser 4 cylinder boat runs great for twenty minutes to a half hour then the motor misses and stalls out. After about thirty minutes the boat starts back up and runs great for anot
Check the torque on the head bolts. I can't tell you what it is, been a long time. If they are good, run it till it dies. Then check for spark at the plugs or coil/s. No spark replace the coil/s. My guess would be coils. But I have seen the head loosen up.
Sep 28, 2014 | Seloc Tune Up Repair Manuals Type...
Torque specs chart for a 165 hs pwr in line 6 mercruiser
That should be a Chevy 250 Cubic inch block. I would look in a manual from the late 70's
Aug 04, 2014 | San Juan Engineering Freshwater Engine...
Reverse gear
Make sure all connections on the rear shift assembly are connected.
Jul 02, 2013 | Mercury Marine Mercruiser 120 140 3.0 470...
Getting water in pistons and of course oil.Is it
There are Flapper plates in the exhaust. They can burn out especially when running with the Muffs for winterizing. Then problems shows up first time you take it out. Usually this problem does not show while boat is moving. The bad flapper allows water to draw up into the engine like having a straw in a drink.
Sometimes when decellerating or Transom to the waves a rush of water goes past failed Flapper and into engine. Instant Hydro lock.
Its easier to change the Flapper than removing a head and you know which exhaust to target. When you get the Flapper out, the parts guys can easily tell you if its junk.
May 10, 2010 | Boating
Where can I download a free repair and maintenance manual for a 1992 mercruiser 3.0 liter boat engine
I believe you will have to call mrecruiser and request it personally. this is an oldie book now. none avail.
Apr 15, 2010 | Boating
Are my water jackets plugged
hi there is a water inlet on one side this takes cooling water up to the engine block then the water circulates through the block then into the exaust manifold then out into the drive along with the exaust gases and comes out through the prop blockages usualy occour in the maifold but they can be almost anyware dissconect the big hose going into the drive and put a hosepipe up the smaller one water should circulate /put big hose back /water should come out of prop if it is possible put the leg in a cut down 50 gallon drum make a solution of 10lb caustic soda to 30 gallon HOTwater run the engine in that for half hour or so then run it in CLEAN water for an hour the last thing youi want is any caustic left in the motor hope this helps merlin v1`2
Aug 26, 2009 | Boating
When we put boat in reverse in makes a banging noise.
If its a mercruiser 3.0 liter 4 cylinder motor, they are an old block design and will give a pretty healthy clunk when dropped into reverse. Especially if you are shifting from forward to reverse without stopping. Let the throttle hang in neutral for a minute before shifting into reverse.
Mar 28, 2009 | Boating
Boating Logo
155 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
