Question about Toro Garden
Lawn Mower Deck Shredding Belts
I have a toro riding mower and I am continuously having to replace deck belts because the lawn mower keeps shredding them. I have tried different kinds of belts. Its to the point its costing a lot of money and becoming a headache. I know people talk about adjusting the pulleys but I do not see any way of being able to adjust them. They have always been off. Please tell me what I can do because I cannot afford replacing it with a new mower or for someone to repair it.
Thanks
  • 15 Answers
SOURCE: I need the part number and diagram for the deck
Contact your local dealer. They can give you the belt number and the routing diagram.
Posted on Apr 24, 2009
rockitman187
  • 2559 Answers
SOURCE: i need a manual to show me how to adjust the belt
Here is a link to the manual
Please rate this a fixya.
Posted on May 15, 2009
SOURCE: MTD Lawn Tractor: Constantly shredding deck belt...
I have the exact same model MTD tractor with same problem. It began when the bolt that extends through the idler arm assembly broke and subsequently damaged the pulley. Upon examination of the broken bolt, I found that the threaded end that extends below the deck is significantly smaller that the rest of the bolt. I got a larger bolt with the same size threads, bored out the hole through the deck and it made the whole idler assembly much stronger. the deck still has some vibration and some unusual belt harmonics, but it appears to be working. Compared to most other tractors of this size, this deck is very complicated.
Posted on Jun 15, 2009
RonPark
  • 855 Answers
SOURCE: my deck is way too low. How do I adjust it?
Your mower should have a lever on it that you move to raise or lower your deck. The lever will normally have the slots that it locks into numbered like the trans gears if yours is not automatic.
Posted on Nov 06, 2009
agent91
  • 2100 Answers
SOURCE: 42" deck belt shredding
One of your pulleys is frozen and the belt is just going around it without it turning. Pull the belt out, remember where it goes, and find the pulley that is frozen. Get it replaced. Hope this helps.
Posted on May 04, 2010
Belt is to long, is there a deck adjustment?
Jim, Double check to make sure you have correct belt for the deck and are installing it in the correct configuration as per manual or drawing on deck. Very few lawn tractors have deck belt adjustment, most do not, most deck belts have a spring loaded tensioner to take up the slack.
This could be some of your problem, the tensioner/idler pulley sometimes seize up and must be lubed up till they move freely, or your belt could be loose. Look in your manual or try google searching your make, model #, deck belt adjustment.
How to Change Riding Lawn Mower Deck Belt
Mower belt tensioner repair question to the Garage Gang
lawn mower deck belt routing Google Search
May 20, 2016 | Garden
Will an older 42 inch murray riding lawn mower deck interchange with an older rally riding lawn mower deck ?
Mower decks are very specific to the tractor. Unless it was the same manufactured mower, and just branded differently, then not likely! Belts are your next problem as even an inch longer or shorter will cause problems.
May 07, 2016 | Murray Garden
I have a Toro model number 20622 auto start go forward and backward the blade won't turn it's like it's got a break on it how do I get this to work when I pulled the lever nothing happens
Anon, a lot of these Toro decks do have a type of brake on one of the idler arm and pulley to stop blade. You will have to get a repair/service manual if your owners manual does not show it. Normally can be seen in deck belt installation diagram. If blade brake checks out OK, it is possible one or both blade spindles bearings are seizing.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Riding Lawn Mower Spindle Assembly Replacement Craftsman Lawn Mower Repair...
How to Replace Brake Pads on Mower Cutting Deck
Mower Deck Return Spring Replacement Craftsman Riding Lawn Mower Repair...
Apr 18, 2016 | Toro Garden
Need to know what size deck belt it takes for a roper lawn mower the model number is yT140Dr
Electrolux 532106085 (replaces 106085X) BELT-V.79.1.MWR : This is the OEM belt number for the yT140Dr mower deck. Length = 79.1" ; Width = 0.5" (1/2").
Welcome to VBELTS4LESS COM Belt Supplier For Industrial Belts Lawn...
The above link is for VBELTS4LESS, an excellent web site for belts. I've used their belts for two mowers, and the belts are excellent...
Jun 15, 2014 | Garden
Mower deck drive belt keeps breaking
I HAVE A CRAFTSMAN 18 H.P. 3 BLADE 46" MOWER DECK.
1. THE PLASTIC PULLEY COVERS ON BOTH SIDES OF MOWER...WILL TRAP STICKS AND DEBRIS WHICH VERY RAPIDLY WEARS THOSE BELTS..I REMOVED MINE
IF IT IS RUBBING:
1. EITHER THE BELT HAS STRETCHED-REPLACE
2.THE SPRING MOUNT (WELDED TO DECK) GOT BENT...STRAIGHTEN
Jul 21, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My deck mower(craftsman 917.271530)keeps shredding deck belts
You either have a bad bearing on one of the pulleys or one is loose and moving up and down drawing the belt when it is engaged. I would pull the mower deck off and go through it .
Apr 17, 2012 | Sears Garden
I have a swisher ride king mower that keeps shredding belt from moter to deck. dose anyone have solution?
I have been told if the parking brake is engaged and you try to drive the mower it will instantly put a burn spot on the belt. I hope this helps.
Aug 11, 2010 | Swisher Ride King Zero Turn Mower 23 Hp,...
Shredding belts
first make sure the belt is not hitting anything when the blade is engaged (engine off), the if ok remove belt and look in pulley grooves for rocks or chips., then run finger all around groove to make sure there is no catches or spurs. If that is all ok then with belt on and engine idleing as slow as possible and blade engaged look and see if pulley is wobbling, BE CAREFULL !! look at the engine pulley first then with EXTREME CAUTION look under deck from opposte side of chute. ( Check with deck at highest setting)
Jul 24, 2009 | Mtd Garden
Garden Logo
223 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
