Question about RCA D52W19 52" Rear Projection Television
Capasitor ok i had a problem of the power light flashing 3 times then turn off for 2 min..then it would do the same.fixed that by changing the cap.but mean while i had pulled cap to get # off of it .when i got new one week later i replaced it and tv came on.but now the blue flashes across screen.my question is the markings on cap.look different than orig.if i put in wrong polarity would this cause this or do i have another problem?
  • bubba Jun 09, 2008
    ok the caps it said to replace it with is 2200uf 16v 105 13x26 radial
    part # htrl16v2200 is this the right one for the D52W19 52 in? or would that cause the blue tube or light to flash like a strobe light? thanks!
  • jose_luis_av Jan 20, 2009
    Does any one have a pictucre of the capacitor or exactly where is located on a d52w19b? Thanks
  • RCA Master
  • 5,138 Answers
If you had put cap in wrong it would have blew up.also it must be same micro uf. 100uf 50 volts you can use 100uf 100 volts.
Posted on Jun 06, 2008
I have a DeLongi DNC65 which is about 6 yrs old. Last year I found it would occasionally turn itself off completely. Now this is happening all the time. There are no lights it just goes off. Any tips?
check your powersupply for bulging electrolytic capasitors may be an easy fix change the bad caps with right value and it will fix your problem,butler
Oct 02, 2016 | Televison & Video
Hl1440 drum indicator flashing
ok turn it off take the toner out clean all the terminals put them back in make sure everything is closed properly turn the machinie back on and let me no what happenes then
Sep 12, 2008 | Brother DR-400 Replacement Drum - 20000...
Where can I find a manual online for a Defiant heavy duty timer 1000-014-198?
Programing:
Set Time
Press and hold OK for 2 sec.
When the Day flashes, press + or - to set the day.
Press OK - it moves to the hour.
Do the same for hour, min.
When done, press Menu.
Set Timer
there are 16 different times you can set. Most people will use 1.
Press Menu, the 1 on flashes. We will set that setting.
Press OK to select 1 On, the week day flashes. The first selection is ALL days. Use the + or - to set day.
Press OK, the hour flashes. Use the + or - to set hour.
Do the same for min. The 1 off flashes.
Set the off time.
When done, press menu.
Rcl button
Press Menu and select the on/off setting you want to delete.
Press Rcl. It clears it
Press Rcl. again, and it will restore the old setting.
Turn on manually
Press + to change from
Auto OFF (timer is on, light off)
ON (light is ON)
Auto ON (timer is on, light on)
OFF (it's off)
Daylight Savings Time
Press Rcl to activate DST. +1H displays.
RND Random
Turns lights on and off within 30 min of your time - for a "random" appearance.
Press RND to turn it on/off.
There is a countdown setting too - not sure why anyone would use it.
Press Menu twice. CTD displays.
You can set the time interval from 99hrs out.
Click OK to confirm. The CTD flashes during countdown.
You can set it to turn on or off.
Dec 12, 2015 | Hardware & Accessories
I think i may have a few bad capasitors on my LCD screen mobo. Its 4 of them that has bulging on the top of the capasitor and the bottom of one of those seem to have been deformated or something like it,...
You can swap the capacitors with same value but new one.
Only if you can get all done by 1/4 of the price of a new LCD, if not it is not worth your time to fix.
Another problem might be from the ccfl lamps open circuit.
You need to identify your problem. Cheers.
Jan 03, 2011 | ViewSonic VX2235WM Monitor
Hello. I got a Lg tv which i brought 3 years ago. After putting it on standby usually the red light falshes 3 times until it turns blue and comes on. since last week the red botton just flashes...
First disconnect all power to the TV for about 30 minutes this gives the filter caps time to discharge as this resets the logic section upon power-up. After 30 min try powering back up if you still have the same problem then there's a problem with the power supply board. You may have some caps with high ESR levels which can cause this kind of fault. But it could other components on the power board causing a similar fault like switching transformers that have shorted, or opened either which can cause EDDY Currents which will cause feedback in opto-couplers and shut the TV down. Let me know what results you get after the 30 minute power-down.
Oct 18, 2010 | LG 37LG30 37 in. LCD HDTV
Wont power on
caps on main board may be defective. power supply may be defective if the caps on the MB arent bubbled
May 27, 2010 | Philips 50PFP5332D 50 in. Plasma...
Identifying which capacitors might need changing in a Philpips PHP-X19I have looked for swelling/distortion but they all look good to me, so are there a common capacitors that go, and if so which ones are...
ok, you need to do
1) check all capasitors at power supply (filter) and inverter (there are some smaller capasitors, see is there any color or swelling (even very tiny). change them.
2) most common the inverter board problem with some driver components wrong. need check the condition
3) if the monitor use over 3 years that one of lamps could be overlife, it should be a sympton like this,
hope you fix it, any ask to me please
May 12, 2009 | Philips 19 in. CRT Monitor
Screen flashing
What I have done in the past is to change to project to high power mode for some time and then change it back to low power mode after 20-30 mins. This fixes the flashing light issue, at least temporarily.
Mar 08, 2009 | InFocus ScreenPlay 4805 Multimedia...
Pover up trouble
sounds like something is drawing down on your 12 volt supply drives or on board regulators. Try it without the drives connectged, and see if you can get the system to boot up(you'll just get a notice that your drives are unavailable, but you'll already know that, right?
got backup for your Dell?
Feb 15, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Mitsubishi flashing light replaced capasitors that were blown tv still has flashing light
The four cap replacement in DM module repair is simplistic
and incomplete, as you found out. ALL defective DM modules
have bad SMC's ( small "top hat" caps) AKA surface-mount
capacitors that can be changed only by the most highly skilled
bench techs. We used to change out hundreds years ago in
camcorder circuit board repair.DM board repair is a much more
accessible,thus more "do-able". For more info.............T.
Sep 26, 2007 | Mitsubishi WS-55513 55" Rear Projection...
RCA D52W19 52" Rear Projection Television Logo
59 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
