Question about HP F4480 All-In-One Printer
My F4480 does not recognize that I put in a new ink cartridge and refuses to print.
  • 50 Answers
JUST PUT IN NEW INK WILL NOT PRINT
Was it a genuine brand cartridge, or no-name type? Some printers refuse to recognize anything but a genuine brand cartridge.
Alternatively you could try reseating it, but you likely already did that.
Dec 06, 2014 | Office Equipment & Supplies
Hp 4480 how do you unpause it
The HP F4480 likely has a malfunctioning ink cartridge which is causing the printer hang (i.e. internal micro-electronics damage inside the HP 60 color or black ink cartridge). You can verify the electrical condition of both HP 60 ink cartridges by activating the Tap 41 diagnostic test report (see video here for complete instructions):
http://inkjet411.com/?page_id=440 (HP 60 - Deskjet F2400/F4400/F4500 models)
    1.While holding the Power button, press Cancel (X) button 4 times, then press the Color Copy button once.
    2.Release the Power button.
    3.The 'Tap 41' diagnostic test print should print.
    Providing the color cartridge is partially functioning the Tap 41 diagnostic test print will be printed (this is a forced service print test which is mainly used for the evaluation of ink cartridge electrical health). A good HP 60/60XL color cartridge should display 1248 good nozzles, while a good HP 60/60XL black ink cartridge should show 336 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to 2nd video on how to read the printout.
    http://inkjet411.com/?page_id=444 (HP 60 - Deskjet F4200 model)
    If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink.
    For additional support please visit http://www.inkjet411.com
    -Thank you
Dec 09, 2013 | HP F4480 All-In-One Printer
I have a f4480 hp printer. Used it about 3 times in last 6 mos. It was not printing with the black ink so I just bought #74 & #75 ink from Staples. Now the yellow light on the front of the printer...
If the ink cartridge in the printer is 6 months old, it maybe dried out and would need to be replaced with a new cartridge. When buying new cartridges from places like Walmart, Target etc. check the dates on the packages before buying. Sometimes the cartridges will set in the store too long and dry out.
Jun 17, 2011 | HP PhotoSmart C4480 All-in-One Printer ...
How do i remove ink cartridge hp deskjet F4480
Here is a short tutorial about hp deskjet F4480:
http://www.inkjet-laser.com/hp-deskjet-f4480-error-print-cartridge-is-missing-incorrectly-installed.html
Feb 17, 2011 | Computers & Internet
I have a f4480 hp deskjet. How do you reset settings when you refill the ink (black) cartridge? Because even after injecting the ink, I still get the exclamation mark and orange light. And when even...
Some Hp printers, like Epson, require the cartridge to be reset. There is a chip on the cartridge that needs resetting.
This might work;
Place the HP 60 cartridge on a covered surface so that the metal contacts on the cartridge are facing you. Put tape over the top metal contact in the second column from the left-hand side, making sure the other contacts do not get covered. Put the HP 60 cartridge back into the HP printer. Print a test page when prompted. Take the cartridge out of the printer. Leave the tape on the contact that is already covered and also cover the top contact in the column at the far right, making sure no other contact gets covered in the process. Return the cartridge to the printer again. Print a test page. Remove the cartridge from the printer again, remove the tape from the metal contacts, and return the cartridge to the printer. Print the test page and the printer should read the cartridge as full.
Jun 18, 2017 | HP F4480 All-In-One Printer
Refuses to recognize ink cartridges
Apologies for not responding earlier, forgot all about it. Solved problem by switching printer on and off many times. It eventually recognized cartridges. Now leave it switched on.
Jan 07, 2010 | Epson Office Equipment & Supplies
Cartridge
did you do a clean cartridge and re alignment first?
http://tinyurl.com/6qcpgy
Aug 08, 2008 | HP PSC 1410 All-In-One InkJet Printer
Epson R1800 printer won't recognize new ink cartridge
You can remove magenta & double check that some tape was not left behind on the contacts. Take a clean ragg & dampen it with alcohol. Clean the ink cartridge's (copper contacts & inside the the ink carrige). Re-install the magenta, (tight fit). Power off the printer. Wait a few seconds & power it back up. If it fails a second time with no other errors. Like the above. Than the magenta may be defective. Have a recipt? Return it for a replacment.
Feb 07, 2008 | Epson Stylus Photo R1800 InkJet Printer
HP F4480 All-In-One Printer Logo
460 people viewed this question
Seeker5211
Seeker5211
