Question about Furman PL-PLUS SERIES II (PLPLUSII) Power Supply
Furman PL-8 series ii lights on front flickered for a while and now they wont come on at all (talking about the lights that light up the other rack gear)
MY HEADLIGHTS ARE BLINKING AND MY HORN IS TOO AND RELAYS ARE BLINKING TOO.
Search Results
    2002 saturn l200 headlights and dash lights blinking - Saturn ...
    www.saturnforum.com/.../saturn-l-series.../2002-saturn-l200-headlights-...
    Mar 6, 2013 - My wife told me that on occasion the headlights and the dash lights willblink when she lets off the. ... 2002 saturn l200 headlights and dash lights blinking.... 2000 LW2 dash lights Inop, spotts56, Saturn L Series Sedans & ...
    Saturn l-300 wagon has flickering lights - Car Forums at Edmunds.com
    forums.edmunds.com > Saturn > Saturn L300
    My wagon 2003 l-300 has flickering lights and when the radio is off you can hear the ...My Dad has a 2002 Saturn Lw series wagon. the transmition has been ...
    why a green light always keep flashing when running? - SaturnFans ...
    www.saturnfans.com > ... > Models > Saturn S-Series > S-Series General
    Apr 17, 2007 - 20 posts - ‎14 authors
    S-Series General. ... A green light alwyas keep flashing when my saturn 2002 sl2 .... I had a similar issue with the headlights of a 2002 Impala, but it was an .... I never noticed on my SL2, my L200 or on my Ion now if they come ... Flashing Dash Lights
    Oct 20, 2008
    Flickering lights?
    Nov 21, 2007
    L300 2004 - Lights Flickering - Have some help
    Nov 2, 2005
    Flickering Lights
    Feb 5, 2005
    More results from www.saturnfans.com
Feb 09, 2016 | 2002 Saturn L-Series
Land Rover Discovery II, Dashboard Orange light next to the red break light what is it on?
Are you talking about the orange lamp to the right of the brake light in the upper left of the cluster? If so, that is the Malfunction indicator light (Check Engine light for those in the States) or at least it is on mine. Have someone scan it to retrieve and clear the error codes. Google the retrieved codes and you'll find a myriad of hits containing troubleshooting advice. Or post them here and we'll try to get you pointed in the right direction.
Oct 03, 2014 | Safety & Security for Land Rover Discovery...
Bosch 100 series wont start... lights stay on for wash rinse spin, but door lock doesnt light
Turn program selector to "off". Turn selector to Drain or Spin. Press the start / pause. Wait until program ends. Open door.
OR
Press "start / pause" until the start / pause light flashes.
OR
First, unplug the machine and turn off the water supply. On the lower right of the front panel is a 6" / 15mm cover. Near the bottom of this cover is a small hole. Insert a piece of wire into this hole, and push in gently. While pushing, turn the cover clockwise, it will came off.
The door release is a narrow white plastic strip hanging down on the right; Pull down on this strip while pushing in on the door, the door lock will release.
Pl click if helped
Mar 26, 2013 | Bosch Nexxt 100 Series WFMC1001UC Front...
S light & m light
Which lights are you talking about? Signal light and ? light. Also what is your question? Do you need to know how to replace them?
Jan 18, 2011 | 2002 Land Rover Discovery Series II
Bose 321 series wont play region 1 dvd
To convert Bose 3-2-1 GS Series 2 DVD system to Multi-Region playback
1. Press the Right button on your remote control
2. Press the Up button on your remote control
3. Press the Shuffle button on your remote control
4. Press the Stop button on your remote control
5. Press the Mute button on your remote control
6. The disc tray should eject twice to confirm the region change
7. Press the Standby button on your remote control to power off your machine
8. After one minute, press the Standby button on your remote control to power on.
Done!
Nov 29, 2010 | Bose 3 2 1 GS Series II DVD Home...
The CD Player is a Furman Pro Series II and it seems to be cuing the wrong song. What could be wrong or would it be an operator error?
Kindly provide with Few More Details :-
1. How old the Unit is?
2. Is this a Problem with same CD's or with all CD's?
3. Have you tried to use a CD that might had worked well before on this?
Let me know, so that we could proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Mar 16, 2010 | Audio Players & Recorders
I have 8 outputs on my Furman SPB-8 power supply for 9 volt guitar pedals. I moved the power supply to a bigger pedal board, drilled a few holes to anchor it it to the board. Now none of the 9 volt outlets...
How are you at soldering? Do you have a voltmeter? Is there a fuse in the unit? Did you make sure no metal chips from drilling shorted anything out? The donut shaped part could be a transformer, or it could part of a filter. To get DC for the pedals, there are usually these components: a transformer (to decrease the line voltage), a rectifier bridge (turns AC to DC), a filter capacitor (to get rid of AC ripple from the rectified AC) and a voltage regulator (futher reduces ripple to eliminate hum). The filter capacitor is usually the most likely component to fail. The manual states that the maximum current draw for any pedal is 100mA. It also states that their is an 'electronic fuse, called a PTC (probably a positive temperature coefficient device. From what I've found, it uses 7809 regulator, which is one of the key components. I found a page about building an effects regulator. In the picture, the regulator is the little black square device towards the right. There is a metal tab, that should really be mounted to a heat sink. I'm including a link to the page for designing this supply. They're pretty simple, and I can find you the parts pretty cheap, if you you want to try building one. Another possibility is to find a prebuilt supply that would fit inside your case. You can get a schematic from furman if you have the serial number. In the picture the big 'can' is one of the devices I'd suspect. See if it's bulging on the end. Anywa, here's the likely culprits: the biggest capacitor (big can, voltage regulator, ptc. The ptc is probably square or rectangular, and rather small, probably about the size of the regulator, but thinner, and maybe tan or yellow, but could be some other color. Before you try any repair, if you have a voltmeter see what happens with no pedals. Then if you can read 9 volts, try the pedal with the lowest draw. The current draw will be listed on the pedal near the power supply plug. If that doesn't work, Check the voltage on the ouput pin of the regulator. It should be on the right, viewed from the front. I'm including a link to a page with a 7809 that shows the pins. There are several different versionsa I think, with different current ratings. Anything over 1 amp should have the metal tab mounted to a heat sink. The fixya format is not so conducive to solving this. You can go to ecurrencyparadise.com, and click the email me link to contact me. I'm a BSEET who has been playing with this stuff for years. There's plenty of ways to get this working, probably even better than the way they designed it.
http://www.furmanpower.com/sites/furmanpower.com/files/_/Furman-Pro-AV/spb-8_manual.pdf https://hotbottles.files.wordpress.com/2014/05/2013-12-04-21-22-59.jpg real effects pedal power supply 7809 9V Voltage Regulator
May 26, 2017 | Furman PL-PLUS SERIES II (PLPLUSII) Power...
Furman pq4 (NEED A manual) Black face
I have the exact same two questions. Did you ever figure it out?
May 17, 2009 | Furman PL-PLUS SERIES II (PLPLUSII) Power...
Furman PL-PLUS SERIES II (PLPLUSII) Power Supply Logo
173 people viewed this question
Top Furman Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Furman Computer and Internet Expert? Answer questions, earn points and help others
