Question about Canon PIXMA MP210 Photo All-In-One Printer
Brought new ink and when i try to print it says ink is put in wrong or not compatible
    Brigadier General:
  • 4,044 Answers
Make sure you removed all the tape from the contacts on the cartridge and that they are clean.
Posted on Jul 12, 2010
  • 2 more comments
  • aharmon2005 Jul 12, 2010
    all tape is removed and everything is clean. I took the ink out and put it back in however it is still doing the samething
  • James Young Jul 12, 2010
    Something is in the way of those contacts either on the cartridge or on the print carriage. If any of those are not making contact you will get that error. If this is a refilled cartridge it is a very common error and you'll need to replace it.
    the cartridge is new, how can i check to see if something is blocking it?
    and what does E 1 4 mean?
My lexmark x3470 wont recognise compatible ink Cartridges any know of a way round this
If the ink cartridges you purchased are not Lexmark - that could be the problem. I used to have a Lexmark printer and I did the same thing - I purchased ink cartridges that were compatible but not Lexmark brand. Everything seemed fine until I tried to print and then I would get the same error sign and low ink message and it would not print. I kept thinking I was doing something else wrong and tried everything. In the end I broke down and got ink cartridges from Lexmark and that solved the problem. Now I have a Brother printer and I never buy anything other than Brother ink cartridges because I'm always afraid of that same thing happening again. I wish I knew which printers WOULD accept those non name brand ink cartridges, but thus far I do not know of any printers that do. Hope this helps you.
Mar 24, 2012 | Lexmark X3470 All-In-One InkJet Printer
I have a HP Designjet100 Plus. The black went from ok to light to nothing. I have cleaned the printer head manually and thru the maintainance setting on the machine. Any suggestions? Do i need to buy a new...
You can try to disassemble the printhead and check for contamination.
First remove cap 1
than using a small flat screwdriver disassemble printhead (engagement points 2 and 3)
Warning - a printhead is filled with 8 ml ink
After disassembly - clean the printhead with fluid compatible with pigment ink (for black color) or compatible with water based ink (color printheads)
during reassembly - don't forget to fill the printhead with ink (2/3 of its volume)
May 19, 2011 | HP DesignJet 100 Plus InkJet Printer
I have a Canon MP460 printer and its telling me that it doesn't recognize my ink cartridge. I have even brought new ones but still tells me that it don't recognize ink cartridge. I have cleaned contacts...
U must be using PG40, CL41...
Well.... if you put brand new one, (not the compatible one) and see the same problem... that's something needs to be cared of by A/S center.
However, if you put in the compatible or refilled cartridge (anther one), still u will c the same e5 error.
E5 errror is something can't be solved....
Apr 26, 2011 | Canon PIXMA MP460 All-In-One InkJet...
Black not printing
Canon Bubble Jet i560 Ink Jet Printer not printing black
Aug 01, 2010 | Canon BubbleJet i560 InkJet Printer
I put new ink in my mp390 and it is not printing anything it says the printer is online and when I hit print all that comes out is a blank sheet
Hi, i suspect the ink you bought is not compatible with the printer, try print test page and see what happens.if it is still blank,then, change the ink cartridge.
Compliment and wish you best of luck.
Jan 02, 2010 | Canon MultiPASS MP390 All-In-One InkJet...
Put in a compatible red ink cartridge but no red ink printed. Can't put in the original cartridge in to verify the printer as it is detected as empty. However, for other colors that I replaced with same...
So, is the new cartridge "compatible", or is it not as compatible as they claim?
Try a "genuine" replacement cartridge.
Start the software that came with the printer.
There is a "ink-jet test" utility, and a "head-cleaning" utility.
Run each of them, to see if anything is "clogged".
Dec 05, 2009 | Office Equipment & Supplies
Ink cartdge issues w/ Hp C4180 all-in-one brought from US 2 UK.
don't forget U.K. use 220v we using 110v. can't be compatible!
Dec 13, 2008 | HP PSC 1510 All-In-One InkJet Printer
Canon pixma mp210 and compatable ink cartridges
Try pushing the reset button for about 5 seconds. This has worked for me.
Oct 27, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Epsom R200 COPY INK DOESNT WORK
There is no solution, I have tried this myself, there are compatible inks for this product, you just got the wrong ones, However it may only be down to one of the inks, check the ink levels before removing, if all empty, then they are not compatible.
swampduck
Jan 07, 2008 | Epson Stylus Photo R200 InkJet Printer
Compatible ink
yes i have a epson rx560 i brought a contiouous ink system the thing you must watch out for when buying copy ink is that they work with all modles or rx560 as some ink will only work befor printer made before 1 march 2007 and some will only work after made 2007
but the continuous ink system will work wit all models i can get cis for £45 plus postage and come with 6 x 100 ml ink contact me if your intreasted
Oct 11, 2007 | Epson Printer
Canon PIXMA MP210 Photo All-In-One Printer Logo
146 people viewed this question
old marine
old marine
