I'm looking for a wire harness diagram for a "1971 Yamaha 250 Enduro. Free would be best. Thanxs!
  • 4 more comments
  • Christian Hagner Apr 20, 2008
    From what I know its a DT1 and I need the entire wire diagram, thanks, -Gadget man
    Yes I am trying to restore the entire bike, and for that I need the wire diagram so Thank you so much.=)
  • Christian Hagner Apr 23, 2008
    Thanks!!!=)
  • brian c
    brian c May 11, 2010
    I didn't forget about ya. I'm in the process of moving, and most everything is in boxes, and of course they aren't well labeled.
    Just keeping you updated.
  • brian c
    Ok. Sounds like you have a nice little restoration going on!
    I will check either tomorrow (it's already midnight here and was about to sign off) and see what I can dig up for you. If I have the correct one, I will scan them, and upload them to tinypic.com for you (that way you don't need adobe, etc), and you can just view / download / print them.
    I will get back to you soon.
  • brian c
    Which exact model is it? A DT? I have several old Yamaha service manuals outside, and I can probably be of some assistance. I know they didn't have a very complicated wiring system back then.
    Which exact area are you looking for (lighting, ignition, etc)?
  • 1894 Answers
SOURCE: Wiring harness diagram
this can be found only in the service manual.
also this manual is not found for free..buy it here
thank you
Posted on Mar 24, 2008
  • 2336 Answers
SOURCE: 1979 Maico 250 Enduro Wiring
with Steering lock on headstock and correct tank using the plug in black connector Bosch ignition - she looks great and pulls like a train.... My problem is that I am entered into an Enduro in France (I am in England) on the 14th October and the bike must have working lights.....It has a headlight and Tail light but no wiring connecting them. There are several spare wires taped up under the tank I am quite happy to carry out the wiring I just need to know the colours to use...and how to check them I have a multimeter available. It has a horn attached and I have bought a high/low /horn switch , as well as a rear brake light switch...,I have written this motoplat instruction quite a while back: http://www.ktm495.mxbikes.com/motoplat.htm Right at the bottom is the color coding for the lightning wires.,,,
Posted on Nov 10, 2008
  • 245 Answers
SOURCE: i need a wiring diagram for a 1980 2strike 400cc
I think the Service Manual has the wiring diagram in it, but you
will have to increase the size (zoom in) to read it. Get a free
manual at
http://www.yamaha-motor-europe.com/community/service/manuals.jsp
Posted on Nov 21, 2009
jrhampson
SOURCE: i need a free wiring scamatic for a 1975 yamaha
http://www.slimduck.com/index.html cheers!
Posted on Nov 27, 2009
  • 37 Answers
SOURCE: 1971 yamaha 175 motorcycle electrical problem
ill do a list of things that can help or be the problem.
1) Pull the coil off and wire brush down all the bare metal. then do the same to the frame where it bolted on. Make sure there is a grounded wire that bolts back onto the coil if there was one, Replace the wire end for the ground peice.
2) Pull off the spark end cap and cut the wire down a few mm until you see new wire then screw it back on. (if its NGK)
3) follow the wire from the kill switch and make sure it isnt grounding out.
4) Hotwire - find the kill switch and unplug it. if this doesnt help unplug the ignition key wiring. on older bikes it will work for ignition but not lights for the key part. if this helps you need a new Ignition barrel / Kill switch.
5) check your wiring harness make sure it isnt grounding anywhere exept where its ment to.
6) make your your engine to CDI is plugged in and has no oxide in it
7) try and find somone with a running bike the same as yours and borrow there CDI, if this helps you need to buy a new CDI or check yours for wiring shorts.
hope this helps if not buzz me (skuly@Hotmail.com)
Posted on Feb 17, 2010
Yamaha enduro DT100 wiring diagram
Hi, Anonymous for this scenario you will need your service/owners/ manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Yamaha enduro DT100 wiring diagram Google Search
Yamaha DT 100 DT175 Enduro motorcycle wiring schematics diagram
1974 Yamaha DT100 Enduro Repair Manual
OEM parts for Yamaha
1974 1975 Yamaha DT100 Owners Manual DT 100 Enduro Paperback 1974
Jan 13, 2014 | 1974 Yamaha DT 360
Wiring diagram for 1984 it490 for magneto to coil
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $25 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
1984 it 490 enduro wiring diagram Google Search
Yamaha Motorcycle Wiring Diagrams
Clymer Yamaha IT Enduro Workshop Manual $25
http://www.yamahait.com.au/files/1984%20IT490.pdf
http://mybikemanuals.com/yamaha/yamaha-it-owners-manuals
Jun 14, 2012 | Yamaha Motorcycles
Schematics 1973 dt3 yamaha 250 enduro magneto
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $ you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
http://www.wiringdiagrams21.com/wp-content/uploads/2008/07/Yamaha-DT250-Wiring-Diagram.jpg
Yamaha DT250D Service Manual
Yamaha DT230 Owner Manual
Jun 07, 2012 | Yamaha DT 360 Motorcycles
Anyone have the wiring diagram for 1973 dt1 250 yamaha enduro ? mucho thanks.........
Hi, Tipalow for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $15 you can download another one.
1973 yamaha dt250 wiring diagram Google Search
DOWNLOAD NOW Yamaha DT250 DT360 DT 250 360 Service Repair Workshop Manual... $15
http://mybikemanuals.com/yamaha/yamaha-dt
Aug 29, 2011 | 1973 Yamaha DT 360
Yamaha DT 250 Enduro wiring diagram
Hi, Keith1171 for this scenario you will need your service/owners manual if you can't find the best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Yamaha DT 250 Enduro wiring diagram Google Search
Jan 26, 2011 | 1972 Yamaha DT 360
I need 1974 Yamaha DT 250 enduro Parts Diagram and part numbers. Where can I find a parts diagram for 1974 Yamaha DT 250 enduro motorcycle?
GDay mate
Took a bit of scrounging bout the net, but I eventually found it!!
You can look at the parts diagram/part numbers for the old girl here
A rating and feedback is a great way to reward me for my efforts to find this for you. Cheers mate!!
regards
robotoek
Jun 20, 2010 | 1974 Yamaha DT 360
1979 Yamaha DT 175 Enduro wiring diagram
Hi, Rasmussenave for this scenario you will need your service/owners manual if you can't find the best tool you ever bought for your Yamaha, despair not, for a mere $9 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
1979 Yamaha DT 175 Enduro wiring diagram Google Search
DOWNLOAD Yamaha DT175 DT175D DT 175 92 Service Repair Workshop Manual... $9
Apr 16, 2010 | Yamaha Motorcycles
Online access to the manual for the 1979 Yamaha Enduro 250
Hi, Itvoasis the vast majority of service, parts, and owners manuals on the internet are "FREE" to download and all service manuals contain wiring diagrams in the back pages. The rest usually charge a modest fee around $10 and there is a handful of obscure, rare, obsolete, and very old models that are no longer or never were available, for these rare occasions I shall look on eBay and find the cheapest one available. Most of the manuals will cover your exact make, model, and year otherwise one will be provided that comes as close as possible to your bike and will have most of the same info that an exact manual would have. To download your manual please click on the blue links below. Good luck and have a wonderful day Yamaha 1970 HS1 Service Manual
http://mybikemanuals.com/yamaha/yamaha-rd-owners-manuals
Yamaha RD 250 1979
https://en.wikipedia.org/wiki/Yamaha_RD250
May 03, 2009 | 1979 Yamaha RD 250
Computers & Internet Logo
250 people viewed this question
David Payne
David Payne
