Question about Pacific International Water Heater Thermostat - Single Element
Pacific water heater light dims and water does not heat up
Model pacific gas water heater model jds189l
hot water cutting out after less than a minute running -
unit is set on summer setting
help
Posted on Dec 27, 2011
    Scholar:
  • 122 Answers
Sounds like an electrical problem, consult an electrician
Posted on Aug 06, 2010
Have 40 gallon electric hot water tank 10 gauge wire 20 amp double pole breaker federal pacific fuse box red black ground wire shows power on 2 hrs now not even Luke warm water what could be wrong
I'm an electrician and can help. Federal Pacific equipment is tough stuff. The company went out of business decades ago - due to faulty equipment they made. Aside from that..
There may be no power out of the breaker, bad connections between the breaker and water heater, bad thermostat, bad hi temp sensor, bad heating element and more. I wrote the article linked below - that will help you find and fix any of these problems and more - assuming you have the equipment and ability to work on electric water heaters. If not - call a licensed electrician.
How to Repair an Electric Water Heater
Jun 05, 2015 | Water Water Heaters
Why do lights flicker
An electric water heater will draw a lot of electricity. Your house may not be wired well, and when the heater kicks on, your lights will dim some. If your house is over 25 years old, it's likely normal.
Nov 02, 2014 | Rheem RTE 27 Tankless Electric Water...
No heat from heater
Copy following link to help identify water heater.
http://waterheatertimer.org/How-to-fix-water-heater.html
Add a comment and describe water heater in detail. Attach video with clear description.
If unit has blinking lights, then check product manual for error codes from blinking lights.
If unit is delivering no hot water, check for cross connections
http://waterheatertimer.org/Crossover.html
Call service technician and catch up on routine maintenance, such as cleaning water filter, etc
Jun 10, 2013 | American Heat ADK-2 - Electric 8.2KW...
Reliance gas water heater 640ycrs pilot light will not stay after 1 heat period replaced thermal couple has gas thermal switch
if water heater will heat a tank of water before the pilot light goes out you need to replce the gas thermostat
Mar 04, 2010 | Reliance & 30 Gal LP Gas Water Heater
No heat, no light, has flow and power?
I'm experiencing the samething it's been installed 3 years and christmas day nothing. Please help.
Feb 07, 2010 | Bosch & Tankless LP Hot Water Heater
Reliance water heater has a loud pop and somthing
YOU ARE PROBABLY HEARING THE WATER PERK DUE TO CALCIUM AND LINE BUILD UP.. YOU CAN DESCALE WITH ACID BUT IT TAKES A CIRCULATION PUMP AND A LITTLE PLUMBING SKILL.
Sep 25, 2009 | Water Heaters
How do you know if it is the element that is bad or the therm-o-
Disconnect the electric for the unit. Disconnect the two wires from the two eliments. Place a battery type test light or Ohm meter is more conclusive if you have one, Light should light when placing the two test leads to the two eliment contacts(while they are disconnect for the water heater wiring) should be dim but glowing. If no light the the eliment is open. If an Ohm meter the Wattage is written on the heater the heater. E=IR P=IE. It should work out to about 1200 -1400 ohms if 220 volt heater. If the light is bright just as if you had put the two test leads together,then you can say that the eliment is likely shorted. Either no light or a Very bright light requires the eliment to be changed.   To check the thermostats, Raise the ajustment one one at a time, until it clicks. Listen for the heater to be heating. Turn that one back down and do the other one the same way. I hope I have been clear enough. About one gallon of water should be drained for the bottom of the tank once a year along with checking the preasure/tempature safety relief valve by  operating it ,using the leaver,for  a few moments as preventive maintenance.
Feb 11, 2009 | Element Chromalox SG1353-430326 Electric...
Pacific International Water Heater Thermostat - Single Element Logo
189 people viewed this question
Top Pacific International Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Pacific International Water Heater Expert? Answer questions, earn points and help others
