Question about Roper Dryers
Dryer will not start. Roper REX3514PQ0 - Roper Dryers
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. It seems to be the issue with the Thermal Fuse going bad and needs to be replaced. It is mounted to the exhaust duct inside the back cover panel. Also, often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 12, 2010
  • spates753 Jul 12, 2010
    Thank for your response. How do I find the Thermal Fuse and Heating Element? What do I need to do to replace them? And where can I find replacement parts?
  • Rylee Smith
    Rylee Smith Jul 12, 2010
    Thanks for accepting the solution. You can check this link for the parts and diagrams. The thermal fuse is located on the blower wheel cover inside the back cover panel.
Roper dryer will not start
How to Troubleshoot a Roper Dryer That Will Not Start ' Home Guides ...
homeguides.sfgate.com > Real Estate Advice > Basic Real Estate Advice
Jul 14, 2016 | Roper Dryers
My Roper dryer, model RED4100sq0, will tumble but not dry. Also, the timer does not run so the dryer runs continously after starting. There is no heat from the element. Both of these problems started at...
I fixed a roper dryer with a no heat problem and I did a youtube video you can google Roper Dryer no heat if my movie does not show but I gonna post it for you.
Sep 30, 2013 | Roper Dryers
I have model REX3514PQ0 that I purchased from Lowe's in 2005. It is a Heavy Duty, Extra Large Capacity, 3 Cycle dryer. The dryer will turn on and will blow but only cold air. A friend suggested I check...
There are three switches :: high heat thermostat, low heat thermostat, and thermal limit switch.
Could the the thermal limit switch is opened because the dryer overheated -- these cannot be reset -- need replacing.
Could also be a faulty heating element. To test these components you'll need an ohmmeter (multi-meter) and will need to remove the back of the dryer.
More info, let me know.
Charlie
Feb 20, 2011 | Roper Dryers
I need a wiring diagram for a Roper Dryer REX3514PQ0. Is ther e any place on the web that this can be obtained?
Many of the appliance parts websites also have wiring diagrams..
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Jan 05, 2011 | Roper Dryers
I have a Roper Dryer Model #REX3514PQ0 and it's about 5 or six years old. I was drying my laundry. The first load dryed fine. One the second load I notice that the setting nob up top was not moving and...
What I would do is pull the dryer out and unplug the power cord. I would remove the rear cover and check the components back there for continuity.f08dda1.jpg83a4f65.jpg15ccca9.jpgIf all of that is good then the timer or breaker might be bad. Why? The timer calls for heat through the RH leg. The amp draw from the heating element arcs up the contact point inside the timer. The motor runs on 120 volts the heater runs on 240 volts. So the breaker will take a beating on the heater side of it. The dryer will hower still run. To recap It could be the heater the limits the time or an electrical problem.6db32c2.jpga2de035.jpg
Rate it or Hate it:
Jul 15, 2010 | Roper Dryers
What would the value be of my used Roper REX3514PQ0 dryer?
Usually a little less than half of original price paid as new, on working appliances, that is. I would advertise the bad one as free, with the purchase of the running one. You should do well with these on craigs list.
Jun 20, 2010 | Dryers
I have model number rex3514pq0. While drying it
Most likely a broken heater coil wire. It is common. When you open the unit up you can easily see if this is the problem. It should show a damaged section
Mar 20, 2010 | Dryers
Roper electric dryer wii not start
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Jan 05, 2009 | Roper RES7646KQ Electric Dryer
Dryers Logo
83 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
