Question about Dell Computers & Internet
If you erase the hard drive what does it get rid of that might need to be backed up.
  • 748 Answers
If you erase the hard drive (i.e. format it) you get rid of everything, including the operating system (Windows), all your installed software, and of course all files you have created, downloaded or otherwise put in.
This means, that you will be left with a computer that can't do anything.
If you have a Windows installation disc (CD/DVD) that came with the computer, you can then re-install Windows on the computer and then gradually install all the other needed software. If you don't, there's still a chance that your DELL has a "system restore partition", that will be able to restore the disk to a "factory" state, with Windows and all the necessary drivers installed. But you'll have to specify your exact model if you want further advice.
Posted on Jul 12, 2010
How to completely erase the hd
A hard drive is the brain of a computer. However, over time, that brain can become overworked and overly saturated with old software and outdated information. It becomes clogged and needs a fresh start. By erasing a hard drive, you can give your PC that fresh new beginning. With a few steps you can erase your hard drive manually, without the aid of expensive software.
Make sure your data is protected before you proceed. Whatever you do not save will be lost once you erase the drive. Use a CD or jumpdrive to save your information. Boot with a system disk. Before you continue to erase the hard drive, use the system to create a system disk. Use a 3-1/2 inch floppy disk and format it with the command "format a: /s"; this will create a bootable disk that contains system commands. Place it in the drive of your system and turn it off, then back on. Reformat the hard drive. Once you've booted with the system disk, type "format c: /s"; this will reformat the hard disk, virtually destroying the old hard drive you used to know. Depending on the of the drive, the formatting may take a fairly long time. Once the formatting is over, use the command "fdisk" to create partitions (which are logical sections for your hard drive's storage). Given the newer hard drives and operating systems of today, you can fdisk the drive and use all of the space. or if you dont have a floppy drive Download a disk wiping utility, such as Darik's Boot and Nuke (DBAN) or KillDisk. DBAN is an open-source product, while KillDisk is available as a free, closed-source download. http://www.dban.org/ http://www.killdisk.com/ Once you download the file, save it to your computer somewhere easy to remember. Insert a blank CD into your computer and use a CD writing program to burn the hard disk wipe utility to the blank CD. If you are using Windows Vista or 7, there is a built-in utility that will perform this task. Back up the data on your computer that you want to save, if necessary. Insert the CD that you created into the computer that is attached to the hard drive you wish to erase. Power on the computer and choose the setup option to boot from the CD. Once you have booted from the CD, you will enter into the hard disk wipe utility. Depending on which utility you chose to use, this screen will vary, but the choice you want to select is to erase or wipe a disk drive. Choose the hard disk that you wish to wipe and confirm that you wish to permanently erase the data on it. Before confirming this, you may wish to physically double check and ensure that you are erasing the correct drive. Once you start the erasing process, it cannot be halted, paused or reversed. You will have to wait for anywhere from a few hours to even a few days for the process to complete, depending on how large your hard drive is.
or you could just reinstall another operating system this will automatically delete the old wrong one you installed.
Hope this helps.
Jan 02, 2013 | Western Digital WD Scorpio Blue WD5000BEVT...
How do you erase hard drive
Hope this helps.
Dec 20, 2012 | Computers & Internet
Reformatting toshiba portable hard drive for mac, since the one i have says for windows pc
Note: I'm assuming you have a working mac; if you don't, then post back to this solution with that information.
1. Connect the external hard drive to your mac.
2. Open the system drive, usually titled "Macintosh HD." Open Applications, then Utilities and double click the "Disk Utility" program to open it. A window will open giving a list of all the drives currently mounted on the computer.
3. Select the external hard drive that needs to be formatted on the left.
4. Click on the "Erase" tab to the right of the list of drives. The window will now display the options for erasing the hard drive and formatting it to work on the Macintosh computer.
5. Select the Volume Format from the pop-up list. In most cases it's best to leave it at "Mac OS Extended (Journaled)" as this is the default. This setting is the best option for running Mac OS X.
6. Name the hard drive. Type a name for the disk in the field where it asks for the name. This name will always appear when the disk is mounted on a Macintosh computer.
7. Click the erase button. A window will open asking to verify the erase procedure. Click the erase button in this window to start the process of erasing the disk. Once the process is complete, the drive will appear with the name it was given on the left side of the window with the list of drives and on the desktop of the Macintosh computer.
Good luck, please post back to this solution if you have any difficulties, and thanks for using FixYa.
Apr 28, 2011 | Computers & Internet
I want to erase everything on my external hard drive. How do I do this?
If you aren't sure what you're doing, bring it to a service tech or you may render that external hard drive completely useless:
Before you start cleaning make sure you back everything up onto another disk. If you are giving your computer away check with the person or organization to see if they plan on cleaning your hard drive for you. However, the best thing to do is to clean it yourself.
Download a hard drive cleaning program or go to a computer store that sells computer software and buy the program. This is the safest way to make sure the hard drive is all wiped clean. Running the software program over writes all the data on your drive, making the hard drive impossible for anyone to read. The software works by over writing the drive many times.
Make sure you give yourself plenty of time in wiping your hard drive clean because if you have a lot of stuff it will take longer to clean.
Once your running your program and the box comes up to erase your hard drive don't forget that this process is irreversible. You will now type in the word format drive letter and hit confirm that you want to erase everything on your computer.
Installing a new external hard drive if you are not getting rid of your computer, is another option you have. You still go about erasing the old drive because you're getting rid of your hard drive. Install the new one.
Jan 01, 2011 | Toshiba HDDR320E04XW 320 GB USB Hard Drive
I cant erase the files in my hard disk, if i erased it, it's keep on comimhg back..what will i do?
INFO:
Files are never really erased from a hard drive.
At various stages files are always recoverable.
RECOMENDATION:
To truly erase your hard drive take it out and completely destroy it down to many small parts.
Hope this tip helps.
r/
David
Mar 11, 2010 | Seagate 250GB Maxtor DiamondMax Plus 21...
I recently had to have my hard-drive completely erased in order to rid a virus I contacted. In the cleansing, I lost my program for MegaSTOR 20X Triple Format Drive program. How do I go about reinstalling...
u can perform a system restoration by following this steps: START-ALL PROGRAMS-ACCESSORIES-SYSTEM TOOLS-SYSTEM RESTORE.then follow the steps thereafter.and try to back date the system to restore it to a week back later u perform the operation especially those dates that are bold
Jan 17, 2010 | Computers & Internet
How do i get rid of the music on my ipod?
Delete them from your itunes library and then sync it with your ipod.
Sep 11, 2009 | Apple iPod MA446LL/A MP3 Player
HOW DO YOU ERASE A HARD DRIVE
Fastest, and most efficient way to erase an hard drive is by formatting it.
If the hard drive is the one in which the system is installed, then you will need to boot the computer using the system install disk (eg. Windows XP disk) to format the hard drive.
Oct 26, 2008 | Maxtor Hard Drive
Computers & Internet Logo
46 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
