Question about Tanaka 22" Pole Hedge Trimmer - 25cc
Tanaka tph230s ran lean
The family shared tanaka tph230s appeared to run lean after i put fuel in it (revved higher than normal then stopped) appeared to be very weak if any mixture it did not seize but will not run cleaned carb and new plug compression appears no less than before any clues ?
4 Suggested Answers
  • 76 Answers
SOURCE: will start and run 20 secs at working speed and
Hi
Did you change the fuel cap .
consider changing it , if the cap is old or not sealing well air comes in and causing this problem.
Posted on Jul 17, 2009
SOURCE: brand new tanaka weedeater, ran fine for 10 minutes,
Just had the exact same problem there is a washer located in there that needs to come out then turn the bras thingy around #18 in parts diagram then put the washer on the outside to space cutting attachment. Manufacturer is an idiot!! Make sure your clutch didn't burn out in the process.
Posted on Aug 16, 2009
eugbug
  • 479 Answers
SOURCE: i have a tanaka tbc
Have a look at these tips:
http://www.fixya.com/support/r9200607-problem_starting_hedgetrimmer
Posted on May 13, 2011
My 98 ford zx2 has the service engine soon light on, and the code says it's running lean, and my revs get stuck up 500-1000 rims higher than normal, what usually causes this?
Look for vacuum leaks.. look at the hose that connects the air cleaner to the throttle body.. looking for cracks, disconnected hoses, broken hoses.. Could be a OX sensor.. but usually that will set a code. Lean means you have a high ratio of air to fuel.. so you are looking for air leaks.
Aug 21, 2014 | Cars & Trucks
Fuel system running rich
Sounds more like it's running lean. Have you checked fuel pressure at the rail? Could be the filter. Also try pulling the vacuum line off the regulator to see if the diaphragm is split and leaking fuel into the manifold.
Mar 05, 2017 | 1995 Ford Escort
Loss of power
Some things to check since it has sat so long.
Bad gas Fuel filter dirty injectors dirty throttle body
The p300 code is a multiple cylinder misfire code. It sounds to me from what you described, that you are having some type of fuel pressure issues.
Dec 11, 2009 | 1999 Dodge Ram
Homelite xl chainsaw revved up & quit and won't start now
I suspect you have a fuel delivery problem or a dirty carburetor. As a chain saw runs out of fuel they often revv slightly (running lean). HTH
Lou
Oct 06, 2009 | Garden
Just put a new cylinder and psiton on an Echo
Pin hole in fuel line can cause lean running condition. Also, be SURE the fuel is fresh and 89 octane or higher. Stale fuels can will give you pre-ignition and detonation issues that are nearly impossible to chase down. Ethanol blended or Oxygenated fuels are a NO-NO in high reving 2-strokes!
If fuel type and fuel line check good, go to carb inlet needle settings and then on to carb passagways.
Sep 26, 2009 | Garden
Brand new tanaka weedeater, ran fine for 10 minutes,
Loosen gearbox at the business end of the shaft. Turn the head slowly until it aligns itself with the driveshaft. Do the same thing with the engine side if this does not fix the issue. It sounds like the dealer did not assemble it correctly. I would take it back where you bought it and have them fix it under warranty.
Apr 04, 2009 | Tanaka 30" Double Sided 24cc Hedge Trimmer
2001 MPV Runs Rough at Idle and Low end Throttle
This could be a bad fuel injector. Lean implies low fuel to the cylinder which will cause a misfire.
Feb 01, 2009 | 2002 Mazda MPV
Tanaka 22" Pole Hedge Trimmer - 25cc Logo
42 people viewed this question
Top Tanaka Garden Experts
john h
wadingriver
wadingriver
Are you a Tanaka Garden Expert? Answer questions, earn points and help others
