FixYa.com
Tags:
Jenn-Air JES8850 Electric Kitchen Range
Ticking noise (by 3 users)
posted by aglaiad on Apr 20, 2008
Range made constant ticking noise by left knob. Was repaired 3 times, still same problem. Range was just replaced, and still same problem.
Review of JennAir range with same problem burning: http://www.dealtime.com/xPR-JDR8895AAS~RD-419165605508
Breaker has 2x 40 Amp connected.
Comment by aglaiad, posted on Apr 20, 2008
P.S. Ticking noise is there when range is OFF!
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by Guest, posted on Aug 14, 2008
I think I have the same problem. I have the same ticking noise from the custom control switch, but the ticking comes and goes. Most of the time it clicks on and off like a 'normal' burner, but at times it clicks on and off very fast (every second) for 15 seconds or so then goes away. Then a while later it does the same thing. Is this considered 'normal' for this burner?? Help
S
Comment by terfdol, posted on Jun 19, 2008
I have the same trouble with my NEW Jenn-Air down draft electic range. I have had someone out, but they could not find a problem. It clicks constantly, like it is trying to turn on. I am afraid it will start a fire!
Best Solution
posted on Jun 25, 2008
Helpful (85)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
PROBLEM MAY BE WITH ELETRONIC CUSTOM CONTROL. IT MAY BE CAUSED BY ELECTRICAL LINE NOISE. YOU CAN TRY A LINE SILENCER ON THE WIRES RUNNING TO SWITCHS' JONES PLUG. THERE IS ALSO A SOFTWARE UPDATE FOR THE NEWER CUSTOM CONTROLS. HOWEVER THE PART NUMBER FOR SWITCH STAYED THE SAME. I HAVE ORDERED THE SWITCH AND STILL HAD SAME PROBLEM. tRY THE LINE SILENCER. . . THE PART NUMBER I USE IS 12001500 MAYTAG NOISE SUPPRESSOR. IT WORKS IN SOME INSTANCES.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Kitchen Ranges problems?
no power to my jenn air oven...
i disconnet the front panel to... Answer This...
spilled and cooked on food...
I spilled some grease and it... Answer This...
re: radiant cooktops
A bowl in my microwave leaked... Answer This...
replace admiral stove burner...
I have an Admiral stove. I need... Answer This...
Igniter keeps on sparking
I have a Baumatic gas hob,... Answer This...
Repair Service
Find Kitchen Range Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
