Question about GE JGRS14 Gas Single Oven
Temperature varies Temperature will vary sometimes 100 degrees above setting before it shuts burner down
    President:
  • 1,891 Answers
Very normal but only during pre heat / once the oven is stable tempt should be 5 to 10 deg above and below the tempt setting and if not replace the oven temp sensor located inside the oven on the back ..mm
Posted on Jul 16, 2010
Riello 40 gasG900 burner that will ignite but when oven reaches temperature it turns off completely. After temp drops by 4 degrees it turns back on and reheats back to temp then turns off.Why is this?
that would be normal. if it didnt shut off, it would go above the set temperature. the heat is either off or on. it cant me in the middle. it turns 'off' so that the temperature doesnt go too far above 250. when it senses the temperature falling too low below 250, it heats it up again.
Sep 03, 2017 | Ovens
Baking in the convection oven, do you set the temperature 25 degrees lower than the recipe calls for?
temperature settings in ovens vary make to make
set around the receipe recommended temp but remember that most on tv cooks always say around the temp ( around 180 or around 250 for about 1hour or about 10 minutes
When cooking , nothing is set in concrete so to speak
Jun 04, 2017 | Ovens
I have a New World Double oven, dual fuel range cooker - NW 90DFD0 The main oven isn't heating up.
Hello Ally;
My name is Peter. I am a retired field service appliance technician.
You may not have a problem. Normally your oven will rise about 40 degrees F. above the set temperature and then shut down, until the oven temperature falls 40 degrees F. below the set temperature, then the oven turns back on.
Your oven temperature is controlled by you oven thermocouple.
You also have a high temperature limit switch, which turns the fan on when you go too far above the set temperature to vent the oven. This may be bad.
Mar 10, 2016 | Ovens
Oven temperature is offf by 30 degrees
It does vary some by model yet the control can usually be calibratied by;
Pushing and holding the BAKE button until the tempature that is displayed changes to 00 then push the up/down arrows to adjust the temp. +/- up to 35 degrees once ya have selected the ajustment all be it up, or down 30 degrees push the cancel/off button and the change will be saved
Oct 02, 2011 | Maytag Ovens
The oven cannot keep a consistent temperature. It is mostly about 100 degrees above the selected temperature. My landlord replaced the stove about a month ago and the problem is worse now than it was...
It sounds to me like the oven thermostat is faulty, as this is what controls the temperature.
If you can , get a thermometer and place it in the oven and check the temp against the seting with the thermometer, if as you say it is 100 degrees above setting , then you need to replace the thermostat.
Feb 06, 2011 | Hotpoint Ovens
I'm a landlord and my tenant's oven will not heat up to the proper temperature intermittently. I had a guy come out and test the oven and it works fine, yet my tenant is still complaining the oven is not...
Absolutely. That is the first thing I would think that would cause such a fluctuation of temperatures. BUT if it is a gas oven (WITH A PILOT FLAME) then FIRST consider the thermocouple needing to be changed. If the thermocouple keeps faulting it will shut off gas sporadically and keep the gas off until it resets temporarily on its own.
Mar 13, 2010 | Ovens
I have a frigidaire stove that heats to 50 degrees hotter than the know setting. Can it be adjusted to read correctly?
There is a calibration method to adjust the oven thermostat plus/minus 35 degrees if it is a digital display. The method varies depending on the model range. This calibration method is used to adjust the thermostat if it is not keeping proper tempature. For example if you are setting the oven to 350 and the actual temp it is keeping is 325 then you could use the calibration method to adjust it plus 25 degrees to correct the temp. Just so you know electric ovens will keep a pretty even temp but gas ovens will vary by 40 or more degrees to keep an "average" temp. For example the burner will come on when the oven is 330 degrees and turn off at 370. 330+370 then divide by 2=350. So a oven thermometer may not show you the temp you set it at in a gas oven but does not mean the oven temp is off.
Jan 14, 2010 | Ovens
Oven shuts down before reaching correct temperature
You will need to check the oven calibration using a thermocouple based thermometer(the one you stick in the oven is not reliable). Electric ovens should keep a near constant tempature so if you have it set to 350 the oven should stay around 350 once temp is reached. Now gas ovens are a little different. Most use a on/off thermostat and that means the temp can vary from 320 degrees to 370 degrees to keep an average tempature of 350. So if it is a gas oven you will need to let it warm-up for 10 minutes then start taking the lowest and highest 5 consectutive readings. Then add the 5 reads together and then divide the number by 5 and it should be within 10 degrees of the set tempature. If it is off by more than 50 degrees then you might not be able to get it back to proper calibration. The calibration methods are different for each range and depend on the type of thermostat you have digital(push button controls) or manual(knob). The owner's manual for your range might contain the instructions or consult the manufacture's website for the instructions.
Dec 21, 2009 | Whirlpool Ovens
Oven temp. is off at times, varies how many degrees
Replace the thermostat, and it should solve your problem.
Please rate my solution.
Thanks.
Nov 09, 2009 | Kenmore Ovens
GE JGRS14 Gas Single Oven Logo
116 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a GE Oven Expert? Answer questions, earn points and help others
