Question about Roper REX4634KQ Electric Dryer
Want get hot
My dryer comes on but want get hot its a roper
  • 5,911 Answers
If your dryer still runs, but does NOT heat, the following two links can give you advice on how to troubleshoot an ELECTRIC dryer with a no heat problem:
http://www.fixya.com/support/r3576548-dryer_runs_but_does_not_heat
http://www.fixya.com/support/r3574266-thorough_dryer_advice
Your problem may or may not be related to a heating element problem as there are numerous factors that can cause a dryer not to heat.
First, begin by unplugging the dryer and verifying the voltage at the wall receptacle. You should read 220-240VAC across the two Hot terminals (left and right slots). If the voltage is incorrect, check to make sure you don't have a breaker tripped. Some homes use 2 separate 120VAC breakers to provide power to the receptacle vice using one 240VAC breaker.
If the voltage IS correct, leave the dryer unplugged and remove the cover plate on the terminal block in the back of the dryer (this is where the power cord is installed). Plug the dryer back in and take a voltage reading across the two hot (RED and BLACK) wires at the terminal block. You should read 220-240VAC. If the voltage is good, you have an internal heating problem. If the voltage is bad at the terminal block, but good at the receptacle, you have a bad power cord.
NOTE: If the wires at the terminal block are not color coded, the outer two wires (left and right) are the hot leads. The center conductor is neutral or ground.
The reason a dryer will still run if the input voltage is incorrect, is because the drive motor only uses a portion of the 220 service. The motor runs off 110-120VAC, while the heating circuits require 220-240VAC. So, if you are missing 1/2 your input voltage due to a tripped breaker or bad power cord, your dryer may exhibit these symptoms.
If you determine the problem to be internal, the heating circuits will either be located in the rear of the dryer on the right hand, or under the dryer drum on the right hand side. Usually, an easy way to determine is by the location of the lint screen filter. If the filter is on top of the dryer, the heating circuits are in the back of the dryer. If the lint screen is in the door, the heating circuits are located under the dryer drum.
On a Whirlpool Duet or Kenmore Elite model, the heating circuits are located inside the dryer under the dryer drum on the right hand side. You will need to remove the lower toe panel under the door to access. The toe panel comes off by locating and removing the screws under the bottom front edge of the panel.
The Heating Element is located inside a heater box. The Thermal Cut-Out (TCO) will be located on the outside of the heater box on the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals.
If either the TCO or Hi-Limit Thermostat are determined to be bad, replace BOTH components at the same time. That is why these components are commonly sold as a set. Failure to do so may result in premature failure of any parts you replace.
Replacement parts (if required) may be found at the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average cost of these components varies, so shop and compare. The first three websites I listed have helpful exploded view parts diagrams that can help you locate and properly identify any parts you may need. The heating components are usually listed under the "Bulkhead" section.
NOTE: In many cases the problem is not the heating element. The heating element has protection devices that are designed to regulate the heat and internal temperatures. If the dryer overheats the Thermal Cut-Out (TCO) typically will blow BEFORE the heating element. The replacement kit is much cheaper than purchasing a new heating element that may or may not be the problem.
Read through the information I provided and, if you have any questions, please post back and let me know. I hope you find this information is helpful.
NOTE: If your model number is not listed on some of the websites, use the part numbers from the Sears website and use that as your search criteria. Some model numbers will not reference on some sites, but the part numbers will.
Repairclinic.com has a repair manual that you can purchase that will also help repair any Whirlpool manufactured gas or electric dryer. The part number is 1159257.
Posted on Jul 12, 2010
Dryer model Roper RED4340SQ1 rmy heater don't stay hot all the time during a drying cycle is it normal or i need to change it
You may want to do a thorough tuneup on your dryer. I worked on a couple and wrote a pictorial on it. ROPER DRYER TUNE-UP
My Home movie of a Roper dryer with a heat problem:
Sep 06, 2012 | Roper Dryers
The heat coming out of ny dryer is to hot , the duct is way to hot to touch .model # yrel3613b(maybe 8)w2 thank-you
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Sep 06, 2011 | Roper Dryers
My Roper dryer heats way too much. I have changed the t stats ang cleaned lint and exaust vent.
heatman101
Aug 10, 2011 | Roper RGX4634KQ Gas Dryer
Roper dryer res7646k replaced heater element , cleaned duct system & blower ,still not drying clothes on an 80 min. cycle. Checked vent outlet on dryer , good hot air coming out.
If you replaced the element then you are familiar with the "housing" where the impeller is located. Check to see if there is a significant amount of lint and/or debris around the impeller. I have found all kinds of debris around the impeller and the volume of air circulating can be significantly reduced.
Feb 11, 2011 | Roper Dryers
Dryer (Roper, electric) won't heat
Its probaly gone open circuit, however there is a thermistor that prevents it shorting out, you need to locate it and test it with an ammeter
Mar 25, 2010 | Roper REX4634KQ Electric Dryer
Dryer isnt get hot but it come on
Here is a tip that I wrote about the problem you have with your dryer
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
Heatman101
Mar 09, 2010 | Roper REX3614KW Electric Dryer
Roper dryer gets hot and turns but the heat is
remove the front cover of the unit and make sure the dryer wheel is hooked and turning,while in there check for any pipe ductwork thats disconnected
Feb 27, 2010 | Roper RES7646KQ Electric Dryer
Have a Roper gas dryer and there is no heat coming from it.
If you try it again tomorrow and it works at first but quits again then you need to replace the coils. I have repair photos HERE
Bonus HERE
Jan 15, 2010 | Roper REK2950W Electric Dryer
Dryer not drying
Check your lint filter. Put it under running water to see if the water goes through it. Chances are it is clogged up. Wash it and put it back. Should do the trick.
SGt 48
Jun 18, 2008 | Roper Dryers
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
Either the heater element is breaking or is loose and getting only 110V instead of 240V.  First I would check the wall outlet with a voltmeter for 240V between Line1 and Line2.  Also check the connections and continuity for the heater element.
Oct 11, 2007 | Roper REX4634KQ Electric Dryer
Roper REX4634KQ Electric Dryer Logo
221 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
