Question about Maytag Performa LAT2500A
Washing machines vibrates and bangs around on the spin cycle
  • Maytag Master
  • 3,740 Answers
Hi and welcome to FixYa. I am Kelly. The banging your washer is experiencing is caused by two things. Either the Tub bearing: (Item 21) http://www.appliancepartspros.com/partsearch/model.aspx?model_id=47786&diagram_id=665652#d665652
Detailed View:
http://www.appliancepartspros.com/part_details.aspx?part_id=4372971
or the damper pads are worn (Item 8) http://www.appliancepartspros.com/partsearch/model.aspx?model_id=47786&diagram_id=695761#d695761
Detailed View: http://www.appliancepartspros.com/part_details.aspx?part_id=4024203
The whole top end of the washer must be disassembled to gain access to the tub bearing. The damper pads can be changed by removng the lower drive pullley and suspension springs then lifting the tub assy away from the base.
There is a possibility that something a simple as the leveling legs just need adjusted. If you can press down on all top 4 corners one at a time and the unit teeters then the legs need adjusted so that they all touch the floor.
If the material condition of the washer is still in good shape I would do any of the above repairs and keep this washer in service even IF I had to call a repair person.
Thanks for using FixYa.
Kelly
Posted on Jul 12, 2010
Near the end of the rinse cycle there was a load noise accompanied with a lot of vibration. I stopped it and took out the wet clothes and fininshed manually. To test i put the machne on spin cycle and...
if the clothes bunch up on one side the tub doesn't spin evenly and goes off balance,the tub will start banging all around,if this happens,open the lid and move the clothes around to even them out so all the wieght isn't on one side,it's a common thing mostly with a few items in the washer but can happen with any size load.if it keeps happening send the brand name and the model number.you should be fine.
Apr 17, 2011 | Washing Machines
I took my washer all appart to clean the gum out of the tub now the spin cycle hits and bangs the sides so much you cant use it
Assume this is front loading washing machine, Check drum dampeners are firm, any cables that were held by cable ties near the drum and were removed in order to remove the cables in order to access the drum need to be replaced with new cable ties, there shouldn't be anything loose dangling around near the drum, as it will strike when the drum vibrates during its spin cycle.
Jan 15, 2011 | Kenmore Washing Machines
On spin cycle machine vibrates and makes a load banging sound especially on the final spin.
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
May 14, 2010 | Washing Machines
Washer vibrates on spin cycle
heatman101
May 05, 2010 | LG WM-2277HW Front Load Washer
Can not run spin cycle bang bang bang
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 04, 2009 | Washing Machines
Washer spin cycle extreme vibration and loud bang when it stops
check the vibration damper rods for breakage - especially the mounts.
Mar 17, 2009 | Kenmore Washing Machines
Maytag performa off balance
Check the vibration dampers and the plastic mounts for wear. They should be solid to the machine.
Jan 05, 2009 | Washing Machines
Wachine machine bangs when on spin cycle.
Unless your top loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Also due to the earlier movements during the spin cycle, the shocks that are used to dampen the spin cycle might have been broken or damaged.
If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
Dec 15, 2008 | Washing Machines
Thumping and banging
make sure all shipping pins are out the tub should move all around from side to side if it level still bangs its eather the balance ring top basket are there 3 slides on a plate above the motor just put some silacone oil on tham move around
Feb 09, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
282 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
