Question about Kodak EasyShare M1093 IS Digital Camera
My Kodak m1093 is will not turn on. i tried charging the battery, as i though it was dead. The battery indicates a full charge when, however when i press the power button, the camara attempts to come on but then turns off again as if the battery is dead. this camara is less than 2 months old and has never been wet or dropped.
    Brigadier General:
  • 11,967 Answers
If it's only 2 months old, it is still under warranty...you should take advantage of that.
Posted on Jul 12, 2010
Kodak easyshare m1093 is shuts off
This is either an indication of a faulty battery or a more serious camera fault. Try replacing the battery, if that does not cure the problem it is camera service time.
Nov 28, 2012 | Kodak EasyShare M1093 IS Digital Camera
Kodak easyshare m320 charge light is green, but not charged
Hello Dead Battery, Well this sounds pretty easy compared to most questions I get. If the camera says the battery is dead, then the battery is dead !! the problem with batteries is they loose their capacity over time. The charger can not put any more in it and says it is charged. Just get a new one and give it a full charge and this should do the trick.
Best Regards, Russell
Sep 29, 2012 | Kodak EasyShare M320 Digital Camera
My Kodak m1093 stops charing in 5 minutes on a new battery. The old battery was dropped due to i thinked it goes dead but that was an lens error that i fixed later. when i used a new branded battery, it...
Hello, try putting in more expensive re chargeables. And if that doesnt work, get yourself a discharger. This machine discharges the batteries safely and allows them to fully charge to their full potential. There are more stronger batteries coming out every week, just try a couple and see how you go. Also have you tried using a different charger? Perhaps the charger may not be 100% all of these things make a difference. I hope I have helped you.
Mar 28, 2011 | Kodak EasyShare M1093 IS Digital Camera
My m1093 kodak camera won't turn on, it turns on briefly and then turns right back off again. i have tried charging it but nothing works
try taking out the battery and memory card, then put back in the battery, and try turning on again
then if that works put in the memory card and turn on
or try connecting to ur computer and transferring the pictures and then disconnect and try turning on again
Aug 04, 2010 | Kodak EasyShare M1093 IS Digital Camera
My kodak easyshare m1093is turns itself off when i turn it on.
OK, try getting the LiIon batteries recommended for it if you haven't done so already. Charge the battery pack and install in the camera.
If the correct batteries are not used, the camera will function in this way. i.e. if you use alkaline, NiMH, or other types of AA batteries in this camera, the battery voltage is not compatible with your Kodak camera.
The whole line of Kodak Easyshare cameras is this way.
Hope this helps.
Jul 13, 2010 | Kodak EasyShare M1093 IS Digital Camera
Kodak digital camera M1093 turns on and then off suddnely
Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 17, 2009 | Kodak EasyShare M1093 IS Digital Camera
I plugged in the charger and after an hour the blinking power button stopped blinking and the camera now does not turn on? M1093 IS camera
If the cam. was plugged into the cam and on. Then it doesn't charge it only transferres pics.
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
Nov 12, 2009 | Kodak EasyShare M1093 IS Digital Camera
My camares lcd screen went blank.. i can not see snap in it...though i can see them on my pc while trnfering them.
For this problem try the following:
Make sure that you are installing a fresh/ full charge battery
Remove the memory card and the battery
Use the camera w/o the memory card
If problem still persist call the Tech Number
1800 235 6325 op 12 op 2
Hope this will help
Thanks
Byron
Oct 02, 2009 | Kodak EasyShare M1093 IS Digital Camera
Batteries are kodak li klic 7001 cameras areeasy
The batteries may just be "dead" and beyond charging. Before you toss them though, clean the contacts by wiping them firmly with a soft cloth and then try charging them again. If the problem persists, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Aug 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
Problem switching on my Kodak m1093 IS
Fixing your problem could be as simple as cleaning the battery contacts in the camera, or the solution could be a lot more complex and expensive. Here's a link to the Kodak Help Center - it provides a simple Q&A format to diagnose the problem and propose a solution.
Aug 03, 2009 | Kodak EasyShare M1093 IS Digital Camera
Kodak EasyShare M1093 IS Digital Camera Logo
327 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
